Old 02-07-2004, 07:56 PM   #1
voyagerman
Member#: 42133
Chapter/Region: PRSIC
2002 Impreza WRX
Rally Blue Pearl
Default Morettes wiring need help
I just bought a pair of morettes and I wonder how many wires comes in the kit but many of the wires are disconnected and I don't want to toast my morettes did anybody have the diagram for connecting the wires?
I put a picture at imagestation as a reference if you need it I can't put it here cuz is a big file hope this help....thanx
http://www.imagestation.com/album/?id=4287762881
voyagerman is offline   Reply With Quote
Old 02-07-2004, 08:02 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I saw your other post over on i-club, the response you got there seemed to explain pretty well how to connect them. Have you at least tried to follow those instructions?
If you make a wiring mistake you won't toast anything, it's just lights and relays. The worst that might happen is blowing a fuse.
Old 02-07-2004, 08:25 PM   #3
voyagerman
Member#: 42133
2002 Impreza WRX
Rally Blue Pearl
Old 02-07-2004, 08:29 PM   #4
ciscofreak
Member#: 33176
06 STi
wow, I was just getting ready to post about this as I am in the middle of my install. I did search for diagrams..
http://www.pbase.com/ciscofreak/morette
ciscofreak is offline   Reply With Quote
Old 02-07-2004, 08:51 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Cisco- unfortunately it looks like your Morettes didn't include the plug-in harnesses which are almost always included when you buy them from a vendor, so I'm assuming you bought them used? I suggest you try to get a set of the harnesses so you don't have to cut into your wiring. Those clip-on taps are a very, very bad way to wire headlights.
If my assumption is wrong and you did get them new from a vendor, contact them and ask for a set of harnesses. Otherwise check with some of the vendors who sell Morettes and see if they will sell you the harnesses separately.
Now, as for the general info on Morette wiring-
The two wires with ring terminals go to the battery. The one with the fuse goes to the positive terminal, and the other one goes to negative/ground. Disregard the color of these wires, the positive/fused wire may be black.
The two long wires that come out of the driver side light go over to the passenger side light and plug into their mating connectors there. One is a male spade connector and the other is female. There should only be one open mating connector in the passenger side light for each of those.
Other than that it's just a matter of plugging the headlight and parking light connectors into their mating plugs on the car.
If the lights are used, check the fuse in the battery wire to be sure it's good. If it's blown for some reason replace it with a 15A.
Old 02-07-2004, 08:57 PM   #6
ciscofreak
Member#: 33176
06 STi
Well I am kind of in a bind now. Would you happen to know what wire connects to what on the stock harness. I don't have an issue soldering the wires and using shrink tubing. I just need to get these installed soon.
Thanks for the help by the way
Old 02-07-2004, 08:59 PM   #7
voyagerman
Member#: 42133
2002 Impreza WRX
Rally Blue Pearl
Thanx everybody the pic show at Iclub is ok I found the problem of my headlights ,a little wire ,the one that turns the relay, is cutted inside I discover it with a DMM, "thanks to god"!
now is working perfectly
Old 02-07-2004, 09:12 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Ok, one down
Cisco, here's the wiring info. If you want to do it this way rather than wait for a set of harnesses, just be sure to make the connections sound and permanent. Soldering and heat shrink is fine, properly crimped and insulated butt splices are ok too. My personal preference is to leave the factory wiring intact and use a plug-in solution whenever possible, but of course it's your car and up to you.
The Subaru headlight system is common positive, switched ground. The wiring of the headlight connectors in the car is as follows-
Driver side- common positive = red/light blue (center terminal on connector)
low beam switched ground = yellow/red
high beam switched ground = red
Passenger side- common positive = light blue/white
The wiring on the Morettes-
Common = gray
Low beam = yellow
High beam = blue
Both sides on the Morettes are the same colors. The gray common should be connected, through the harness adapter, to the common positive for each side. The low and high beam wires should go to their respective switched grounds.
Old 02-07-2004, 10:00 PM   #9
ciscofreak
Member#: 33176
06 STi
Mulder, You da man!!!! I really appreciate your help...
You saved my butt!!
Old 04-28-2004, 04:56 AM   #10
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
hey mulder, or anyone,
is there anywhere online that i can order a plug and play harness from?
AK_2002_WRX is offline   Reply With Quote
Old 04-28-2004, 07:36 AM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you need a harness for Morettes, check with the vendors who sell them. The two that I know of who are most likely to have them are Z1, www.z1auto.com , and AllSubaru, www.allsubaru.com
I do not know if they have the harnesses available separately, you'll have to ask.
Old 06-08-2004, 08:04 PM   #12
rlhobbs
Member#: 16576
I tried z1 performance and allsubaru, neither one sold the plug n play harness' separately.
Anyone else know where to get or make a harness. I just want a clean installation.
Thanks!
rlhobbs is offline   Reply With Quote
Morette Wiring Harness...HELP! mrubino83 Electrical & Lighting 3 09-10-2004 06:15 PM
Morettes broken, need help. (56k warning) Erudition Southern California Impreza Club Forum -- SCIC 8 01-25-2004 02:36 PM
Morettes Broken, need help (56k beware) Erudition Electrical & Lighting 5 01-25-2004 12:24 AM
Hella wiring? Need Help Quick!! Vostok 7 Electrical & Lighting 11 05-11-2003 11:34 PM
Busted Morette Lense...need help TXBlueBeast Interior & Exterior Modification 4 01-26-2003 03:24 AM
