Welcome to the North American Subaru Impreza Owners Club Friday March 27, 2015
Old 02-07-2004, 08:23 PM   #1
romoranger
Member#: 14701
94 camaro
big cam/heads/slicks
Default coolant 60: 40 water mix bad?
basically i put all the subaru coolant (4 qts) in my wrx and figured it would take factory specs. it didn't. i onnly got about 3 qts distilled water in there. is this a problem, or will i be fine.
romoranger is offline   Reply With Quote
Old 02-07-2004, 09:19 PM   #2
cvalle-sd
Member#: 420
2001 Cr-V
Hail Satan, that's a lot of anti-freeze. I'm in San Diego, and I'm only running 20% and a bottle of Hyperlube (green water wetter)
The label says 50-70%, but in the southwest, we're definitely in the warmer end of the scale. I'd go 50% tops.
Unless it gets below 40deg there at night (it might), I'd cut back. You're definitely going to want water's higher heat content, come summertime, and the livin's easy. Yes, as a matter of fact, I AM drinking. You could just siphon off a little more than half of the radiator's contents, refill with distilled or deionized water, and that'd give you 20-30% antifreeze. If my arithmetic is intact..which it most likely is not; but you see where I'm going with this.
cvalle-sd is offline   Reply With Quote
Old 02-07-2004, 09:57 PM   #3
nicrfe1370
Member#: 52292
20-30%? Wow, that seems wrecklessly low for a street car. Hopefully some other people with good material to reference will jump in here.
nicrfe1370 is offline   Reply With Quote
Old 02-07-2004, 10:48 PM   #4
romoranger
Member#: 14701
94 camaro
i like the siphoning idea, if i siphoned about 1 quart, then replaced that quart with distilled water i would be at a perfect solution of water and coolant. thanks!
Old 02-07-2004, 10:50 PM   #5
cvalle-sd
Member#: 420
2001 Cr-V
If you're replacing the coolant at the proper intervals, and are in no danger of freezing, that is hardly reckless. Plus the water wetter/hyperlube adds its own corrosion protection.
Pure water is going to remove heat more efficiently, close to twice as well as pure antifreeze. Antifreeze has a much higher boiling point and lower freezing point, though, and slows corrosion. Pure water is fine for short-term applications like racing, especially since they wouldn't want anything slick to get dropped on the track. Pure water is no good for the road, since your service intervals are long enough that your coolant is going to start eating the metals too soon. Pure antifreeze would only prevent boil-over, not really keep the system as cool as it needs to be. Thus the concept of a mixture. The directions on the antifreeze bottle are intended to give an average user, Maine to Mexico, a trouble-free experience. It is not going to give everyone the best possible result. If your daytime highs are like the Upper Peninsula in January, you'll be wanting 70% antifreeze...maybe more, I dunno. If you are in Southern California, Arizona, Texas, etc. in deep summer, especially stuck in traffic at 3pm, you might find that 50% water isn't cutting it. Especially if you're already in a turbocharged, octane-limited environment. Regardless of the percentages, you have to know what mixture does what best, what you need done, and most of all, you have to be as thorough about coolant maintenance as you are about engine oil, tire pressure, battery levels, gear oil, etc. None of it should be accidental or random. If I had a turbo setup, I'd mix for maximal heat removal, and just count on having to flush/replenish more often. If you're going to just do what the bottle says, and leave it in for 30-50k miles, then you're not really being very careful there either.
Old 02-09-2004, 02:10 AM   #6
jlevy
Member#: 15696
2015 WRX 6 speed
Just for reference, I'm running 35% antifreeze and watter wetter year round. Of course I'm in Houston (actually south Houston) where it's very rare to see temps below about 28 deg F.
-my 0.02
jlevy is offline   Reply With Quote
Old 02-10-2004, 01:42 AM   #7
romoranger
Member#: 14701
94 camaro
this weekend i am reflushing with a 30 coolant/70 water premixed so i do not run into this problem again. thanks for the help
How much Meth/Water mix should I bring. 07WRBSTI Water/Methanol Injection, Nitrous & Intercooler Cooling 6 03-01-2008 09:16 AM
What would a 50/50 meth/water mix do for my traps? karl750 Water/Methanol Injection, Nitrous & Intercooler Cooling 11 10-23-2007 03:58 PM
2 gal coolant vs. 50/50 mix runwrxrun Service & Maintenance 11 09-12-2006 12:07 AM
Tips on Changing/Flushing Coolant?--Brand, How Much, Mix? clsmooth71 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-24-2003 03:16 PM
alcohol/water mixes for cooling intercoolers jmott Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-16-2002 02:39 PM
