Old 02-07-2004, 08:30 PM   #1
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
Default F U SUBARU... coolant leaks continues!
had my water pump / timing belt replaced 1500 miles ago with OEM parts and i'm leaking in that general area (tstat housing area leaking on manifold heat shield, smells GREAT)
what is the problem!?, we had determined it was escaping the weep hole in the water pump last time, can't be the case now
what is going on!
car is a 02 wrx w/ 70k
overdose is offline   Reply With Quote
Old 02-07-2004, 08:32 PM   #2
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Who did the work?
Old 02-07-2004, 10:46 PM   #3
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
CC Imports in Holland, MI... it appeared the weephole was seeping coolant causing the problem, i don't feel the water pump has failed again this soon, however I am thinking possibly one of the lines that attaches to the housing is... guess we'll see monday
Old 02-08-2004, 02:44 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Did you put an STi radiator cap or other aftermarket hi-pressure cap on your car?
Old 02-08-2004, 03:04 AM   #5
esteve
Member#: 28716
2006 STI
Have them pressure test your cooling system.
esteve is offline   Reply With Quote
Old 02-08-2004, 05:47 PM   #6
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
installed a new OEM radiator cap when tbelt/wpump were replaced
Old 02-09-2004, 01:02 AM   #7
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Watch your subject lines- you are not immune from the rules.
Brian
Old 02-09-2004, 01:15 AM   #8
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
yeah yeah i know, i've just been fighting this coolant leak from the same area since i bought the car and i'm very frustrated
Old 02-09-2004, 07:05 AM   #9
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I had a leak in the same area - turned out to be where the lower radiator hose went onto the tstat housing - the housing is a cast part and had a ton of flashing along the knit line which would cut into the radiator hose and cause a small leak which would drip as I drove the car and vaporize on the exhaust manifold - it wasn't until it got bad enough to actually leave a drop or two of coolant that I found it (all of the coolant residue was on the underside of the hose - impossible to see until I put a mirror under there to check). They replaced the lower radiator hose and ground the thermostat housing smooth (under warranty). No leaks since.
Old 02-09-2004, 08:36 AM   #10
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
that's my next move, it doesn't leak a significant amount but the harder you drive the car the more it worsens
very embarassing to see nasty smelling coolant vaporizing
Old 02-09-2004, 12:13 PM   #11
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
anybody ever seen EJ20T head gasket failure? hopefully that's not the issue!
coolant leak, but without the leak iloveturbos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 03-30-2003 12:30 AM
coolant leak drboost2002 Bay Area Impreza Club Forum -- BAIC 4 02-07-2002 02:15 AM
serious coolant leak ColinL Normally Aspirated Powertrain 12 11-21-2001 03:48 PM
Coolant Leak KKL Vancouver Impreza Club Forum -- VIC 2 11-03-2001 11:26 AM
