Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 02-07-2004, 10:36 PM   #1
senomar
Member#: 47636
01 rsti v7
blue
OMGHi2U sti/RA gears into RS transmission housing
did some searches on the subject, but couldn't find if this combination will work (well). i thought i read something a month or so ago about someone here doing it, so maybe ya'll can direct me to the thread if you remember it. it seems to be a much cheaper way of beefing up the transmission without getting a whole new transmission or KAAZ gears or whatever.....
thanks
cody
:edit: the reason i put this in this forum is cuz it's for my 01 rs that already has a ej20 in it.... thanks guys.
senomar is offline   Reply With Quote
Old 02-07-2004, 10:52 PM   #2
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
A Subaru mechanic buddy of mine says it can be done and there are STi gearsets made for this application. Rallispec.com has some. There are also a coupleother places that escape me at this point. I will need this same swap soon as I am in the same boat.
Kreeger is offline   Reply With Quote
Old 02-08-2004, 12:38 AM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
me too...but rallispec doesn't know for my car and said they will be researching it...I wonder if they are
Old 02-08-2004, 12:43 AM   #4
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Well at wost a blow wrx tranny isnt giong to cost you much and rallispec kit will replace most of the parts.
Dave from rallispec has a thread on the ra gear set in the tranny forum.
Old 02-08-2004, 01:04 AM   #5
senomar
Member#: 47636
01 rsti v7
blue
OMGHi2U ...
thanks. i guess we'll have to make a group effort to get to the bottom of this mystery...
cody
Old 02-09-2004, 09:39 PM   #6
Greg Sharpe
Member#: 741
95 GF8 uber-wagon
Arctic White
Senomar: There are just subtle differences between the various 5MT transmissions, so the STi & STi RA gearsets can easily be fitted into your gearbox. It's been done numerous times.
Greg Sharpe is offline   Reply With Quote
Old 02-10-2004, 12:28 AM   #7
RS22b
Member#: 5413
#15 2-Subaru
Rally Cars !!! Fiesta!
yes Rallispec should have a set that is Kryo treated. It will go right in your RS tranny.
Fortunate for me i was able to get my hands on an RA gearbox for the same amount of money.
Ask Lachute Subaru as far as getting a used gearbox if you are goin to go that way. I have had nothing but good results from that tranny. And with the wrx motor the sweet spot will be right around 4K RPM. Great power feel from those gears, totally drifferent monster.
Billyqua
rally driven..................
RS22b is offline   Reply With Quote
Old 02-10-2004, 09:54 AM   #8
senomar
Member#: 47636
01 rsti v7
blue
so you would suggest the RA gears over the STI? i was kinda leaning the other way, because i do tend to hit the highway quite a bit, and may appreciate the extra fuel economy in the pocketbook.... hmm...
thanks guys
cody
Old 02-17-2004, 01:56 PM   #9
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
thanks guys
cody
dude don't listen to them, with your 4.11 final drive and turbo application, the STI not the STI-RA gearset is ideal for you to keep the torqueband linear....
I agree with you on the highway speeds....trust me do the STI gear ratio.
Kevin
latinskllz is offline   Reply With Quote
Old 02-17-2004, 02:20 PM   #10
senomar
Member#: 47636
01 rsti v7
blue
the gear strength and build is the same, right? ... i think i agree with you.
thanks
cody
P.S. do you have the STI gears installed?
Old 02-18-2004, 12:37 AM   #11
Greg Sharpe
Member#: 741
95 GF8 uber-wagon
Arctic White
senomar: Just to clarify, the Ver.6 STi gear ratios are very similar to those in your RS trans, so the gas mileage would be similar as well. The Ver.6 STi gears are, however, much beefier just like the Ver.6 STi RA gears.
Old 02-20-2004, 05:34 PM   #12
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Exactly, and yes I will be putting these gears into a RS Tranny next month by rallispec with the stainless steel shift fork, new synchros etc.
I see some people getting used STI Tranny, but then there are other costs involved such as new clutch, master and slave cylinder if they are the pull type etc...plus your final drive too!
I see it like this, for $2500 you will have a brand new tranny with STI gears that are wide, hardened and retain similar gas mileage plus hitting 60mph a lot sooner!
your choice, but to me it's definitely worth going through rallispec as they know what they are doing and what it will take to build you a solid tranny with all the right components.
I have done sooo much research in this, and this is the best route for a RS tranny in my opinion if you are on a moderate budget.
Kevin
Old 02-20-2004, 06:02 PM   #13
Homemade WRX
Member#: 33782
96 bastard child
well now I'm going to buy an RS tranny
Old 02-20-2004, 06:20 PM   #14
senomar
Member#: 47636
01 rsti v7
blue
was that a joke? i can't figure it out by the winking yellow face? i think it sounds like the right thing to do as well...
Old 02-21-2004, 01:34 AM   #15
Homemade WRX
Member#: 33782
96 bastard child
well I would if I knew of a way to keep the meachanical speedo in the 93-96 impreza's...I would really like to do it but the whole gauge cluster delima arises....
oh well.
Take it easy, Micah
Old 02-21-2004, 11:31 AM   #16
senomar
Member#: 47636
01 rsti v7
blue
Default that sucks... but
i'm not quite sure i understand what you mean... are you saying if you got an RS tranny, you could do this and everything (gauge cluster included) would match up??? and if you got these gears for your current tranny, your gauges would be off..????
thanks
cody
Old 02-21-2004, 03:28 PM   #17
Homemade WRX
Member#: 33782
96 bastard child
no...if I were to use a RS tranny my speedometer wouldn't work...plain and simple...I wish I could use these gears on my current tranny though...rallispec said that they would research it for me.
Old 02-23-2004, 12:53 AM   #18
senomar
Member#: 47636
01 rsti v7
blue
Default ah...
good luck with that man. in the meantime, i hope my tranny holds up for another few months until i can afford this upgrade. good talk guys, and thanks for the 411...
cody
Old 02-23-2004, 11:56 AM   #19
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
I think that the RS transmission will hand the power fine. I just finished putting about 340 miles on my WRS at VIR this weekend and all seems well. I was running it all the way to the limiter and then downshifting two gears at a time on the front straight. I was doing 13 shifts per lap and I did over 100 laps. My car has also been EUCTEKed too so there was significantly more load on the car.
Ultimately I would like to get a different gearset in the car but I'm in no rush to do it.
Z
Zephyr is offline   Reply With Quote
Old 02-23-2004, 12:00 PM   #20
senomar
Member#: 47636
01 rsti v7
blue
i'm in the same boat. maybe when it's time, we can get a group buy on these things....
Old 02-23-2004, 01:30 PM   #21
Homemade WRX
Member#: 33782
96 bastard child
yeah I would be down with a group buy....too bad rallispec has no clue on my tranny though
Old 02-23-2004, 06:28 PM   #22
Greg Sharpe
Member#: 741
95 GF8 uber-wagon
Arctic White
Homemade WRX: Send a reminder email to RalliSpec. I'm sure they'll have something of interest to tell you!
Old 02-23-2004, 07:22 PM   #23
Homemade WRX
Member#: 33782
96 bastard child
so maybe the good guys up a t rallispec found something out
just sent Dave a follow up message
Old 02-24-2004, 11:52 AM   #24
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
I have two trannies that want STI gears, so count 2 for me LOL....
Old 03-04-2004, 01:05 PM   #25
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
hmm, i may be able to get a group buy on the gearsets...talked to rallispec and asked me to compile a serious interested party....
Swap is done. WRX tranny with v6 RA gears into Legacy SS. Innovative Tuning Subaru Conversions 3 03-06-2011 08:51 PM
WRX Tranny case/ RA gears into an RS- what's needed? mpaone Transmission (AT/MT) & Driveline 6 01-21-2005 02:09 PM
STI RA gears vs STI non RA gears rexorama Transmission (AT/MT) & Driveline 8 12-14-2004 07:36 PM
WRX 5 MT Transmission With STi RA Gears MisterX Private 'For Sale' Classifieds 12 07-02-2004 11:34 PM
do v6 sti ra gears fit rs gearbox? akcel Transmission (AT/MT) & Driveline 2 04-14-2004 03:51 AM
