South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 02-07-2004, 11:27 PM   #1
az ej20 fan
Member#: 45278
Default Post your setup...
I am trying to get some ideas on what to add/delete from my car. Just wanted to see if people are willing to post what they have done so far.
Year/Model
Engine/Trans Mods/ECU upgrade or swap
Suspension
Wheels/Tires
Pros/Cons
I'll go first:
02 WRX
Engine: 2.0 stock -
Trans: 5spd (STi short throw)
Mods: K&N drop-in
HKS Downpipe
Prodrive Axleback
Suspension: Nothing yet
Wheels/Tires: 17" Rota SDRs / 225/45/17 Bridgestone S03s
Pros: Fast for the street/pretty quick at the track [email protected]
Cons: Car pushs A LOT at the limit, brakes are shot (replacing w/ Stoptechs/H6 Conversion)
az ej20 fan is offline   Reply With Quote
Old 02-07-2004, 11:46 PM   #2
GriffinREX
Member#: 36054
Year/Model: 02 WRX PSM
Engine: 2.0 stock
Trans: 5 spd, Kartboy SS with poly bushings
Mods: gutted uppipe, Bosal twin dump DP, Bosal catback, VR underdrive pulley, TXS MBC (1.05 Bar), GFB Hybrid, intercooler water spray, Blitz DTT
ECU upgrade or swap:saving for an AccessPort
Suspension: none yet
Wheels/Tires: stock (honestly, I'm still on the RE-92s, I know, I know... )
Coming soon: Tein springs, short ram intake, STi hoodscoop
GriffinREX is offline   Reply With Quote
Old 02-08-2004, 12:24 AM   #3
az ej20 fan
Member#: 45278
GriffinREX: Where do you get your intercooler water spray?
Everyone: Try to list Pros/Cons in your set up...might help people
Old 02-08-2004, 12:34 AM   #4
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
00 2.5 RS
Short ram intake under hoodscoop
revolutions motorsports header (borla copy) High flow muffler
Trans stock
Suspension KYB AGX + Eiback springs , tein camber plates front /Pillowball rears , FHI 20mm rear swaybar , whiteline sway bar mount , whiteline endlinks .
Brake DBA crossdrilled and slotted rotors akebono pads
Street wheels 18in rotas w Sumitomo HTR+
Auto x wheels 17in Prodrive Speelines w S03's
just love the 2.5 grunt , W 3 deg neg up front tire wear sucks but she goes where she's pointed . rides a little ruff .
imprezzakc is offline   Reply With Quote
Old 02-08-2004, 12:52 AM   #5
DubuRX
Member#: 24307
05 Evo MR
AWD LUV
03 WRX - WRB
2.5l... the rest is secret for now.
DubuRX is offline   Reply With Quote
Old 02-08-2004, 12:55 AM   #6
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
Sound like an STI swap ...
Old 02-08-2004, 12:59 AM   #7
az ej20 fan
Member#: 45278
imprezzakc: How do you like the ride with the AGX/eibach's?
I was thinking Prodrive/AGX (need to find rates on both first.
I am over in Glendale as well...are you planning to run at Firebird next weekend?
Old 02-08-2004, 01:03 AM   #8
GriffinREX
Member#: 36054
ej20fan: I made the water spray myself for about $20. If you are interested, PM me for details.
Old 02-08-2004, 06:55 PM   #9
AzSandSlinger
Member#: 32684
2015 STi
Ice Silver
Default The l3itch ride (aka Suby2) Suby1 is G-14 classified..lol..
PSM 02 WRX
Engine: 2.0 stock
Trans: 5spd
Mods:
TXS Stealthback
Race-pipe In lieu of HF Cat
Straight-pipe axle-back
TXS short-ram-pod intake.
Suspension: Stock
Wheels/Tires: Stockers.. just replaced my RE-92's that had 45K on them!! They still worked!!
Pros: Fast for the street, GREAT gas mileage..
Cons: Can be very loud outside.. Inside is ok though...
-Shane
AzSandSlinger is offline   Reply With Quote
Old 02-08-2004, 07:09 PM   #10
L2W
Member#: 31090
02 dubrex
black and loud
I'm new down here from ak. heres my setup:
02 blk wrx
m2uppipe, txs dp, txs racepipe, txs midpipe, blitz nurspec muffler,
gfb pullies, blitz dropin filter, walbro pump, sti injectors, old txs unichip, PE1820 turbo. spec stage3 clutch and sti-ra gears going in as I type. no suspension work and cooper cobra tires.
It ran [email protected] good power up top, very loud, some flat spots in the unichip map, overall great setup.
L2W is offline   Reply With Quote
Old 02-08-2004, 08:54 PM   #11
Golden
Member#: 36341
2004 Accord EX V6 MT
This will probably not help you but I like replying to these posts anyways
03 WRX
Engine: 2.0 stock -
Trans: 5spd
Suspension: STi replica strut bars that were on the car when I bought it
Wheels/Tires: 17" Rota Subzeros - 225/45/17 Kumho Ectsa Supras
Pros: I haven't spent much money on the car and I'm going to Hawaii in April because of that.
Cons: I'd prefer the car to be MUCH faster and have some torque down low. I personally don't see either happening... ever.
Bottom line... I'd love to dump $20k into this thing but considering I'll be bored with the car in another year or so I will continue to resist any and all mods. (except maybe that Ecutek upgrade from DynoComp )
Golden is offline   Reply With Quote
Old 02-08-2004, 11:37 PM   #12
brentlz
Member#: 12057
2002 Impreza WRX
WR Blue Pearl
2002 WRX Sedan WR Blue
Engine: 2.0T stock with Prodrive/WR Sport axle-back (muffler)
Suspension: JDM STi v8 Spec C
Wheels/Tires: Stock + 15" OZ gravel(soon to have Nokian WR's)
Other: Primitive F/R skid plates. Cobb SS brake lines. ATE blue brake fluid. EDM STi headlamps. Defi 52mm Boost, EGT, & oil pressure gauges in modified OEM pod. STi hood scoop. GT Spec scoop splitter & radiator shield. Full sized spare.
Soon to be: Cobb AccessPort, better asphalt rims/tires, ?STi grill?.
Pros/Cons:
+The sound of the WR Sport muffler. Nice rumble down low, not "blatty", enough volume to hear when to shift, yet not overly loud.
+The handling improvements with the Spec C struts/springs.
+Looks/lighting of the EDM projector headlamps.
+Skidplates & full sized spare are a _must_ for offroad trips.
+Improved pedal feel of SS brake lines.
-Spec C suspension can be a bit bouncy/rough on crappy asphalt.
-Really need better tires & wheels to fully take advantage of Spec C suspension on asphalt.
-Stripped a hard brake line fitting when installing SS brake lines.
-I need to get that EGT sensor mounted.
-Full sized spare sticks up into trunk (though it is a good place to stash 12v air compressor, tire plug kit, tool kit, camp stove, etc.)
brentlz is offline   Reply With Quote
Old 02-09-2004, 12:12 AM   #13
SonicWRX623
Member#: 47181
Sonic Yellow
2003 sonic yellow wrx
vf34 turbo
helix up pipe
helix dp
hks hi power exhaust
txs utec
sti injectors
walbro fuel pump
(i need an intercooler)
18" gunmetal enkei rpm2
ran a 13.00 @ 104 on the 18's....prolly good for +/- 12.8 on stockies
SonicWRX623 is offline   Reply With Quote
Old 02-09-2004, 12:43 AM   #14
22bsport
Member#: 44582
2007 Audi A4 2.0T
outback sport turbo
tein RA
T03/04e
RC550
2.5 heads
ej22t motor
JE pistons
and a lot more
www.highaltitudemotorsports.com
22bsport is offline   Reply With Quote
Old 02-09-2004, 01:30 AM   #15
az ej20 fan
Member#: 45278
22b...dang...your car looks amazing!! I saw someone selliing a white OBS turbo not too long ago and his looked great as well.
Nice job!!
Now I only wish I could figure out how to post pics on this board!!! (I'm slow like that)
Old 02-09-2004, 01:31 AM   #16
DubuRX
Member#: 24307
05 Evo MR
AWD LUV
Old 02-09-2004, 01:37 AM   #17
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
v7 Motor/ECU
TXS stealthback +race cat & prodrive wrsport muffler
PWR/MRT radiator
v5 Suspension + alumn cntrl arms
v4 Front seats
v4 front end
DoctorNick is offline   Reply With Quote
Old 02-09-2004, 11:06 PM   #18
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
www.kingpinperformance.com
Kingpin is offline   Reply With Quote
Old 02-10-2004, 01:03 AM   #19
THE ONE
Member#: 43918
2002 Scooby Wagon
Here is what I'll have on Wednesday...
Stock airbox with drop-in filter (Taking the AEM CAI off)
Gruppe-S Header
Invidia DP
Gruppe-S UP
HKS Carbon Ti Exhaust
Perrin Crank Pulley
VF-30 Turbo
STi Injectors
Walbro Fuel Pump
ECUTEK Reflash with 2 maps
I think thats it.
THE ONE is offline   Reply With Quote
Old 02-10-2004, 11:53 PM   #20
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
Car: Sedan RS
Stance: Low and Slow
Mods: All kinds of dumb stuff
E.T.: Not that fast because the car runs on a non-turbo ecu (not for long though)
bobturismo is offline   Reply With Quote
Old 02-10-2004, 11:59 PM   #21
AZ2004STi
Member#: 43761
2004 WRX STi
403AWHP & 360AWTQ (Sold)
04 STi Java Black Pearl
*APS 3.5" TBE
*APS CAI
*HKS FCD
*Apexi AVC-R
*Worx Tuning BOV
*STi Hardened Mounts(Tranny, Engine, and Pitch)
*STi Short Throw Shifter
Ran 13.2 @ 102 missing 5th and coasting thru trap. Should be good for a 12.6 @ 104-107
AZ2004STi is offline   Reply With Quote
Wagon Suspension- read and post your setups 03ShrtBus Brakes, Steering & Suspension 5350 10-23-2015 07:19 PM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 10:40 PM
PROTOOLS LE users - post your setups Caddy Daddy Off-Topic 4 08-09-2004 05:43 PM
Post your SM setup!!! Davenow Motorsports 66 01-10-2004 03:12 PM
Anyone upgraded their speakers, only? Post Suggestions and your setup vapore0n New England Impreza Club Forum -- NESIC 21 05-28-2003 07:04 PM
