Old 02-08-2004, 12:54 AM   #1
manman99_99
Member#: 54553
Default Heat Shield on up, down and mid pipe
Hi All,
Plan to change up, down and mid pipe.
Origina, there is heat shield on them, after the change
is the heat shield necessary? any negative effect?
Thks
manman99_99 is offline   Reply With Quote
Old 02-08-2004, 01:09 AM   #2
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
After the up/down pipe install, the only heat shield that was left to use was the one that covers the turbo and part of the DP. It did need to be modified to fit, but I would at least keep that one on. There may be a way to keep the others but I didnt.
StarDogChampion is offline   Reply With Quote
Old 02-08-2004, 01:27 AM   #3
industrial
Member#: 7250
2017 WRX
Some kind of heatshield for your pipes would help greatly extend your CV boots for one thing. I wraped my uppipe, modiflied my turbo heatshield and wrapped my downpipe. Wrapping will most likely decrease the life of the uppipe and downpipe but will overall be good for the engine / performance in the long run...Custom heatshields or high temp coating would be ideal.
industrial is offline   Reply With Quote
Old 02-08-2004, 01:49 AM   #4
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
If you keep the turbo heatshield supports in place, you can re-install the turbo to downpipe heatshield. Acually, you don't need the supports, but just need to reinstall the bolts than didn't involve the supports ( two little gold "L" shaped brackets under the heat shield. You can reinstall them with the aftermarket downpipe if it is not a bellmouth, or a wastegate seperate pipe, without modifying the heat shield. You just put back three or four bolts IIRC, and this will hold the heat shield on with no problem. I think two of them are down by the uppipe outlet (by the bottom of the turbo, but I can't remember where the other one or two go into.
Andy
DonkeyPunch is offline   Reply With Quote
VF36 twin scroll set up / OEM JDM twin scroll down- and mid-pipe SC WRX Engine/Power/Exhaust 5 02-07-2007 07:44 PM
FS: VF36 set up; OEM JDM twin scroll down- and mid-pipe SC WRX SCIC Private Classifieds 1 01-13-2007 07:55 PM
STi ver 7 Down and mid pipe 4sale jimbo1972 Private 'For Sale' Classifieds 0 05-08-2004 02:49 PM
Will Oil Temp Increase aft changing up, down and mid pipe manman99_99 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-08-2004 02:05 AM
'02 WRX Gutted Up, Down and Mid pipes. gern Private 'For Sale' Classifieds 0 12-20-2003 12:17 AM
