Old 02-08-2004, 01:27 AM   #1
blaznc
Member#: 41862
0000 99L 2.2T, dead
93 Wagon 1.8L of fury!!
Default Increase stock boost
How would you increase boost with all stock components on a wrx? Thanks
Brandon
blaznc is offline   Reply With Quote
Old 02-08-2004, 01:28 AM   #2
Teep
Member#: 33529
4 LIFE!
MBC or ECU.
-tp
Teep is offline   Reply With Quote
Old 02-08-2004, 01:42 AM   #3
blaznc
Member#: 41862
0000 99L 2.2T, dead
MBC??
Old 02-08-2004, 01:51 AM   #4
audioize
Member#: 42496
2002 Cobb Stg 2 WRX
Midnight Blue
manual boost controller,
ebc = electronic boost controller...
as far as mbc, I've heard a lot of people recommend turboxs mbc.. personally I used to have a blitz sbc idv2 (ebc), and loved it..
audioize is offline   Reply With Quote
Old 02-08-2004, 01:53 AM   #5
audioize
Member#: 42496
2002 Cobb Stg 2 WRX
Midnight Blue
oh i realized the previous posted said ecu.. that means either aftermarket ecu, or a reflash.. I believe some companies can reflash your stock ecu and you can gain a good amount of hp with no aftermarket parts (a reflash will cost you at least a few hundred dollars, usually more)
Old 02-08-2004, 04:15 PM   #6
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
a reflash cost about the same as the higher end ebc's, incase your going the ebc route
el~sharko is offline   Reply With Quote
Increasing the stock boost anabolicbrotha Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-12-2010 09:33 AM
ABC that came with TXS unichip - why do I need to increase the boost every so often? WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-13-2003 05:18 PM
new method to increase factory boost response AustinTX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 245 04-03-2003 11:42 AM
Do I need an uppipe for increase of boost? skoobywrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-06-2003 06:38 PM
Increase in Boost following the same curve as stock boost? KwanDDS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-29-2002 07:07 AM
