Old 02-08-2004, 03:22 AM   #1
crazy_sherm
Member#: 30954
2003 WRX Wagon
Sonic Yellow
Default oil filter leak
I just changed my oil today and think I must have overtightened the oil filter. instead of stopping at like 3/4 turn after it got tight, i just tightened it as much as i could by hand. I'm now getting a couple drops of oil coming off the filter every hour or so.
Is there anything I can do to correct this other than taking the filter completely off? Is the gasket shot now because i overtighted it?
crazy_sherm is offline   Reply With Quote
Old 02-08-2004, 03:40 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Did the old gasket come off with the old filter?
If the old gasket is still there, then it will leak.
It is kind of unusual that one will leak if overtightened, unless it is tightened to the point of deforming the filter....Is the filter can bent or twisted?
Take it apart and figure it out...there should be NO leaks.
Old 02-08-2004, 08:01 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Scotty's right, make sure you didn't accidentally double-gasket the filter. Unless you're Ahnold, it's not likely you overtightened it by hand to the point where it would leak.
oil filter leaking, subaru changed my oil WRXout Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 10-18-2006 07:51 PM
New Oil Filter leaks? Ringboy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 11-11-2005 10:58 AM
Oil filter leak? sti_rx7 Service & Maintenance 12 03-26-2005 11:37 PM
Ever had your oil filter leak? DANACoOp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-26-2004 02:42 PM
Oil filter leak or just spillage? element533 Service & Maintenance 2 07-13-2003 01:31 AM
