Old 06-04-2004, 01:39 PM   #26
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
STiMULi: Thanks for the info, I added it above.
Maicca: The links still work for me! Only motor oil is discussed here, you will have to search for the other levels.
STiMULi: Factory fill from Subaru for a new vehicle is regular Valvoline oil with zero additives. I suspect that other manufacturers have "break in oil" otherwise the "break in oil" talk wouldn't be around these forums.
Old 06-04-2004, 07:48 PM   #27
STiMULi
Member#: 59381
2005 Impreza WRX STi
Thanks very much for your great FAQs!
STiMULi is offline   Reply With Quote
Old 06-07-2004, 02:14 PM   #28
akier
Member#: 63582
89 DL Sedan
Great information - thanks.
Now a quick question: in reading all of those oil reviews, they usually recommend an oil flush with a low viscosity oil to purge the system before switching to synthetic. On an older engine, if I was NOT switching to synthetic, would there be any benefit to a purge? That is, would a purge be beneficial in an all mineral oil system?
Offhand, I'm thinking there would be some marginal detergent action to the engine, but whether or not it would be worth the extra time is my question. Thanks!
akier is offline   Reply With Quote
Old 06-09-2004, 12:17 PM   #29
JAGpro
Member#: 52805
2002 Impreza WRX
Unabomber... thanks for the FAQ... however, I also am having trouble bringing up the Impreza Oil Change instructions from Subymods... I even went in there and did a search that came up dry. Can you help?
JAGpro is offline   Reply With Quote
Old 06-10-2004, 01:18 AM   #30
STiMULi
Member#: 59381
Scoobymods is a pay perview site that is currently looking for funding.
Old 06-16-2004, 09:14 PM   #31
krk206s
Member#: 27065
2004 WRX
Is it better to change the oil at 1000 miles after break-in or just wait until 3000 miles the first time?
krk206s is offline   Reply With Quote
Old 06-17-2004, 06:12 PM   #32
LisaPhish
Member#: 38753
'02 Legacy GT Wagon
Silver - 5spd!
Unhappy What happens if you switch from Synthetic, back?
Hey... I need some advice. I just took my car to a new shop and had the oil changed. I asked when I made the appt that they put Synthetic oil in, as that's what I've been running.
When I picked up the car, I was shocked that he only charged me $20.95 for the oil change. I asked him if he remembered to put the synthetic in, and he said he had. He asked why I asked and I said because it was so cheap... and he just replied, he's just less expensive than the dealership...
The last time I had the oil changed at the dealership, it cost me $35, as the Mobil One cost $6.07/qt.
What do you think? Could he have forgotten and put regular oil in my car? If so, what would that do? How would I know? Is there some way to tell? Would it look different on the dipstick?
Thanks in advance,
Lisa
LisaPhish is offline   Reply With Quote
Old 06-24-2004, 09:26 PM   #33
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
krk206s, do what you feel like, it's your car and this post gives you the "best" advice.
LisaPhish, you got duped. There is no such thing as a $21 synthetic oil change. ~$4/qt is the cheapest you will find synthetic @ ~5 qts = ~$20 alone. Not gonna happen in the real world.
Old 07-05-2004, 12:56 PM   #34
Stilish
Member#: 65634
2004 Impreza/WRX/STi
Pearl Blue
Hey, another thing...Can you discuss about Tranny/Rear Diff changes too? I use Redline and it is awesome, have no idea when best to change it though...haven't got that far (8k miles).
Any fluids would be awesome...and maybe mention for regular drive cars and ones that Auto-X/qtr mile a lot.
Also, I talked to a Subaru dealership and I was told that using synthetic too early in life of car can sometimes cause a Cam seal leak (my friend got one on number 4 when switched at 10k). I am not so sure that this is true cuz mine seaps some at the same spot at 8k on regular oil...anyone else have a seapage problem? Not bad, just slight on mine.
Steve
And you are definately right Unabomber, cheapest GOOD synthetic I have found runs 5-6 bux a qt....Also, becareful if you don't go to Subaru for STi oil change....most places that are 15 min oil change places will put the WRONG oil filter on ur car (non-turbo filter)...but if you want to save cash....get filter at Subaru, take to oil change place (if you are lazy too)....I just change mine myself.
Stilish is offline   Reply With Quote
Old 07-06-2004, 01:26 AM   #35
jhuang76
Member#: 1284
2005 Legacy GT
Royal Blue Pearl
Overall, this is a great FAQ. I've got just a few more points to add.
1) There is a lot of information on the basestock used (Group I-V / mineral based/synthetic based), but one must not forget the importance of the additive package! Even a well synthesized PAO will oxidize over time, although a cheap Group I will oxidize more severly and rapidly. Plus, blowby that gets in the crankcase will deposit all sorts of nasty chemicals into the oil. Therefore, you will need antioxidants to neutralize all the free radicals and peroxides (formed from the oxidized baseoil, from the fuel, partially burnt hydrocarbons ... etc). You will need detergents to neutralize any acids (nice sulfuric acid from the combustion chamber, carboxylic acid from oxidized oil/fuel, ... etc), and prevent formation of varnish/lacquer and sludge. Dispersants help keep whatever oil insoluable chemicals that exists in the oil from agglomerating (such as sludge and soot). Anti-wear additives help coat the metal surfaces to provide protection and reduced friction in metal-metal contact areas (also known as mixed and boundary lubrication where bulk lubricants are not sufficient to provide complete separation). You've got anti-rust/anti-corrosion additives to protect yellow metals (copper based) and lead (though most new bearings no longer contain lead). You also need anti-foaming agents. Also, since the base oil's viscosity changes too much w/ temperature (even for Group IV and V), many times you have to add viscosity modifiers to increase the oils viscosity, especially at higher temperatures.
This is all I can think of right now. Things will get very complex when you consider how all the additives interact. To sum it up, formulating an oil is a job of "optimized compromise" rather than making an "absolute best".
Basically, what this means is that a great oil is not just selecting a great basestock, but also adding in the right mixture of additives to balance protection, fuel economy (reduced frictional losses), and drain interval. There are compromises that will occur.
Also, I will add that there are a lot of high mileage oils out there in the market place today. I don't know what each of them have that makes them "high mileage", but there is at least one company that has done their own testing and development to develop an additive that specifcally helps to "swell" fluoroelastomers (eg. modern seals). Seals will eventually with time "dry up" as its material leaches out into the oil (esters/diesters are notorious for promoting this), so additives in the oil that will help replenish the seal will help the seal last longer. Therefore, oils that have such additives are good for older cars.
jhuang76 is offline   Reply With Quote
Old 07-11-2004, 12:39 AM   #36
Max Umbarger
Member#: 1112
2006 FXT
RBP
nice!
Max Umbarger is offline   Reply With Quote
Old 11-07-2004, 01:46 PM   #37
WilmoWRX
Member#: 73981
2002 Impreza WRX
platinum silver metallic
hi, i want to know what oil type to use for my scooby, regarding viscosity and so. Im planning on buying Motul synthetic, since they use tha one on the wrc impreza. And also where can i buy oil and oil filters for less money.
WilmoWRX is offline   Reply With Quote
Old 11-07-2004, 02:49 PM   #38
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Buying Motul because they use it in WRC is dumb. Their car is 5000% different than yours. Aside from that, they sponser the WRC car, so they use their oil because it's free. 5W30 is what the manual recommends, use it. I can't tell you what the cheapest place for oil and filter is without knowing what you are using of either. Aside from that, www.froogle.com is your friend.
Old 11-07-2004, 05:04 PM   #39
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Motul is good stuff. If you arent going to extend your drains I recommend the 300v (if youre not scared of non API-certified oils, which you shouldnt be), it offers the most protection. Other than that make sure you get one of their ester based oils. Since you are in PR I would use 10w30 or 5w40.
santofontana is offline   Reply With Quote
Old 12-07-2004, 03:04 AM   #40
Max Umbarger
Member#: 1112
2006 FXT
RBP
I use oem purolater filters, and Mobil 1 5-W30 dino oil on all 3 of my Impreza's and my oldest impreza has 235,000 miles on it (ej18). I am still researching before I use synthetic on my WRX, also holidays=low cash flow.
I tried synthetic in my oldest impreza, and lead to leaks (about 3 oil changes).
Funny!
Same weight, I went back to dino oil and leaks went a way, though it was slowly.
I've researched quite a bit. Look at my join date. I have Impreza L, OBS, and WRX. I can somewhat understand synthetic. But since I just got the WRX, I havn't studied the turbo forums until I got. Though I did touch base with it, I never thought I would be interested in synthetic, but maybe. That is for the WRX, not the OBS or L.
...max
Old 12-07-2004, 03:19 AM   #41
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
Ron,
Have you done any research on Torco oil?? www.torcousa.com
Bishop is offline   Reply With Quote
Old 12-16-2004, 05:56 PM   #42
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
No. I used to be into oil research hot and heavy when I got my car. I researched, questioned, PM'd, emailed, and generally drove everyone on bobistheoilguy.com's forums nuts plus many manufacturers. I started using Mobil 1 Delvac as I thought it was the "best". Since then, my opinion has mellowed a bunch. I use Mobil1 5W30 and change every 5000 miles. Mobil1 because it's cheap, universally accepted as a "good" synthetic, and you can get it everywhere. I chose a synthetic because it's "better" and 5k change interval not because I like to change it sooner than the SOA recommended 7.5k, but because it's easier to remember to swap out at 30, 35, 40, etc. If you are using this oil, from what little I did read, it's probably fine. For the best advice, research it on the bobistheoilguy forums as those guys have probably have more info about it.
Old 12-16-2004, 10:04 PM   #43
Bishop
Member#: 59993
Ass, grass or cash
thank you sir.
Old 04-05-2005, 07:12 PM   #44
bmwm750
Member#: 84359
2005 WRX STi
I remember sitting on a plane once next to a recently retired oil chemist, and as a mechanically inclined racer type, popped the ubiquitous "oil question."
Apparently the long haul diesel oils are almost the same formulation as the motorcycle industry's high end oils. They have no frictioin modifiers (unwanted in a bike motor because of the wet clutch) and they have high zinc content (which apparently provides "squish out" protection- i.e. between gears, etc). As such, I have been running Delvac 1 in my roadrace and my motocross bike ever since with great results, and save quite a bit over the $7-$8 a quart motorcycle oils (considering how often those machines get it changed).
Now, as cool as the STi is, I'm not sure I lump its motor into the "high end, exotic" classification. E46 BMW M3s, any Porsche, Ferrari, etc. have extremely costly motors and internal parts. To the best of my knowledge (and please correct me if I"m wrong), the STi has a standard 2.5 liter flat four motor with lower compression and a turbo on it. So far on mine, I have been using plain old Mobil 1 5w30 and I change it every 4k or so. In my opinion, until you take apart your block, spending alot of money in the process, and build it "the right way (forged internals, etc.) I wouldnt use anything more exotic than a commonly available synthetic (i.e. Mobil 1). That said, I would definitly use a synthetic as even with a water cooled turbo, any motor, turbocharged or not, that is making 300hp from 2.5 liters is working fairly hard.
Just my $.02.
bmwm750 is offline   Reply With Quote
Old 07-13-2005, 03:20 PM   #45
Impreza911
Member#: 73829
98 Impreza Wagon
Glacier White
Any thoughts on the "higher milage" oils? Is it worth the extra money? Is it preferable over good quality dinos or synthetics?
Impreza911 is offline   Reply With Quote
Old 07-13-2005, 06:13 PM   #46
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
They typically will be a little thicker for their weight range, and have more additives, so they do offer some advantages IMO. They arent always api certified, which is why they are able to boost the adds, which is a good thing, again IMO.
Old 07-14-2005, 10:21 AM   #47
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
Valvoline MaxLife Synthetic is highly regarded by most folks over on the Bob is the Oil Guy (BITOG) forums.
AndyH is offline   Reply With Quote
Old 08-08-2005, 11:51 PM   #48
RankFrank
Member#: 60682
2006 WRX
I didn't see this anywhere else, so here goes: I just found some 2 year old oil in a box. It's Castrol 10w40, so I can't use it in my car, but I was wondering if it was still usable.
Does oil have an expiration date?
RankFrank is offline   Reply With Quote
Old 08-09-2005, 08:36 AM   #49
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
According to the guys over on BITOG forum, if the oil is stored in say your insulated garage, basement, closet, etc. it should be fine for between 3-10 years. With that said, if in doubt don't use it in any car you care about...give it to a buddy to use in his beater.
Some message threads from BITOG on this topic:
http://theoildrop.server101.com/ubb/...c;f=1;t=011436
http://theoildrop.server101.com/cgi/...c;f=1;t=011098
http://theoildrop.server101.com/cgi/...c;f=1;t=010717
http://theoildrop.server101.com/cgi/...c;f=1;t=010092
http://theoildrop.server101.com/cgi/...c;f=1;t=009448
Old 10-09-2005, 12:29 PM   #50
gc822
Member#: 81217
Originally Posted by armand1
ub: a while back I did a cutup study of the Subaru OEM vs PureOne filters. It's in this thread, which also got some good comment by others on the filtering efficiency of different filter materials, etc: http://forums.nasioc.com/forums/show...hreadid=310181
cool study, somewhat confirms my suspicions...
gc822 is offline   Reply With Quote
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 708 06-22-2016 10:58 AM
Injector, Fuel Pump, and Fuel Rail FAQ: Read if you are thinking of upgrading! Unabomber Newbies & FAQs 168 06-20-2016 07:25 PM
Cooling System FAQ: Read if you want coolant information! Unabomber Service & Maintenance 613 06-06-2016 10:14 PM
Tool FAQ: Read if you want information on Subaru specific tools and sundries Unabomber Service & Maintenance 41 08-16-2014 04:59 PM
Car Storage FAQ: Read if you are storing your car for more than 30 days Unabomber Newbies & FAQs 104 10-10-2013 01:07 PM
