Old 06-02-2006, 01:16 PM   #51
CrooklineWRX
Member#: 114305
2006 WRX Limited
Steel Gray
Default Subaru dealer saying NO synthetic?
More fuel for the oil fire... just dropped my 06 WRX at Cityside Subaru in Belmont, MA for a suspension issue and the first question the check-in guy asked me was if I had changed my oil yet? (Presumably trying to sell me an oil change.) My car has 3,500 miles on it and I told him, yes, I changed the oil at 1,000 miles. He asked what kind of oil and I told him it was Valvoline Synthetic 5W-30. He said unequivocally "you cannot use synethic oil in a WRX... it is too thin."
I am confused... from everything I have read here and on linked pages, synthetic of the correct viscosity actually withstands pressure and viscosity breakdown better than dino oil? Am I missing a new service guidance from Subaru or something? Anyone else have this experience?
CrooklineWRX is offline   Reply With Quote
Old 06-02-2006, 01:52 PM   #52
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
You are experiencing what's known as "the people who work at my dealership are dumasses". Synthetic is discussed in your owners manual and it's 100% fine. As to being too thin....5W30 is 5W30 is 5W30 as they are all tested by the API to be the proper weight. While some may thin out later, to blanket say that one is too thin without oil analysis to back this up is pure lunacy. Maybe you are lucky enough to have a real tribologist working at your dealership though.
Old 06-02-2006, 06:51 PM   #53
CrooklineWRX
Member#: 114305
2006 WRX Limited
Steel Gray
Well that explains the lab coat
Yeah... I'm going to stick with synth since the overwhelming body of evidence supports it. Thanks for all the research.
Old 06-03-2006, 02:49 AM   #54
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
On the other hand there is some pretty good experience that changing to synthetic oil before 5-10K miles may be too soon to properly get the engine fully broken in for best performance and gas mileage. I intend to switch to synthetic at around 7K miles, 1K seems way too soon.
Alan is offline   Reply With Quote
Old 11-02-2006, 04:43 AM   #55
gtx510
Member#: 66118
fwiw, LE ISN'T synthetic. if it was their HDEO 40wt would be a 10W40 or 5W40, not a 15W40.
They also make no mention of synthetic on their site. good dino oil though...it's red and red's fast
For a turbo car look for ACEA A3/B3, A4/B4, A3/B3/B4 oils. Or HDEO's meant for diesels; Delvac, Delo, Rotella, etc. In freezing cold winters a 30wt might work ok, but I wouldn't use anything thinner than GC 0W30.
N/A will be happy with ACEA A1/B1, A5/B5, A1/B1/B5 oils.
gtx510 is offline   Reply With Quote
Old 11-02-2006, 08:57 PM   #56
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
You like to split hairs don't you? It's technically a blend, but since it's about 9000% better than most 100% synthetics, I took the "liberty" of calling it a synthetic.
Old 11-07-2006, 06:09 AM   #57
gtx510
Member#: 66118
afaik, LE is a DINO OIL. I guessing probably Group II+.
They also make no mention of being a "blend".
No way is it a synthetic, that "arguement" applies to Group III oils...
no, I just prefer CORRECT information over falsehoods and speculation.
Ask LE, I've always heard that they say it AIN'T synthetic. (And the shop I used to work at sold LE)
Old 11-07-2006, 11:32 AM   #58
gtx510
Member#: 66118
well, i stand corrected
LE is a blend since their Monolec additive is synthetic. Shows what my old boss knew...
So it's an expensive blend... but that's better than the expensive dino oil that I thought it was.
It's good oil with lotsa additives, but I wouldn't pay $7-8/qt for it. What's this stuff cost these days? It used to be about $5/qt but the price went up and I can't find prices on the net.
"better" is difficult to quanitify.
less engine wear? more power? smoother running? longer lasting?
then compare to Amsoil, Motul, Redline, Schaeffer, etc..
Old 03-26-2007, 02:58 PM   #59
USCTrojan4JC
Member#: 51876
2004 Impreza WRX Sdn
WR Blue Pearl
Default Oil change intervals
The Editor-In-Chief where I work (Edmunds.com) just posted this today:
http://blogs.edmunds.com/karl/465
I've been changing oil at 3,750-mile intervals with Mobil 1 5w-30. I believe commuting on the Santa Monica freeway every weekday and some "spirited driving" would fall under "severe driving conditions." I also go to open track days about twice a year.
Am I being wasteful?
Thanks in advance!
God bless,
Loren
USCTrojan4JC is offline   Reply With Quote
Old 03-26-2007, 03:27 PM   #60
bluesubie
Member#: 767
04 FXT
The only way to really know is to do a used oil analysis. . With M1 5W30 in your conditions and location, you're probably not going to want to go past 3,750 unless you have a good analysis.
Oh, and don't run 5W30 (or 10W30) in the summer at the track unless you want a "qualifying oil".
-Dennis
Old 03-26-2007, 06:33 PM   #61
wrx222
Member#: 55768
2002 PSM WRX Wagon
'03 Forester, '01 Outback
Anyone know the Oil Capacity for a 1995 Impreza L Wagon (EJ18)?
Just bought one the other night, no manual.
Thanks
Dave
wrx222 is offline   Reply With Quote
Old 03-26-2007, 11:28 PM   #62
bluesubie
Member#: 767
04 FXT
Thanks
Dave
Subaru.com and mysubaru.com
Old 03-27-2007, 11:34 PM   #63
wrx222
Member#: 55768
2002 PSM WRX Wagon
Originally Posted by bluesubie View Post
Thanks for the links, Subaru.com tells me how often I should change my oil and how to protect the vehicle's finish, mysubaru.com I can't log into cause I didn't buy the car from a dealer.
I appreciate the effort, but does anyone know the oil capacity for the ej18?
I'm thinking somewhere around 4qts, just want to be sure.
Thanks Again,
Dave
Old 03-28-2007, 02:15 PM   #64
bluesubie
Member#: 767
04 FXT
Not even with the VIN? I did a google and found this. Looks like 4.2 qts.
Old 03-29-2007, 09:39 AM   #65
wrx222
Member#: 55768
2002 PSM WRX Wagon
Thanks
That's funny I googled a bunch of different things and couldn't find it, oh well, I appreciate the info.
The guy who owned the car before me apparently thought it took about 7qts
I had to run for a second oil pan before my 6qt one overflowed
Dave
Old 03-29-2007, 11:11 PM   #66
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Wait, what? There were 7 qts. in the engine? That's not good; that much extra oil could have damaged something (can't remember exactly what ... )
Mike Wevrick is offline   Reply With Quote
Old 05-30-2007, 07:54 PM   #67
hardwareguy
Member#: 103384
2000 Protege
Green
Awesome FAQ, thank you!
hardwareguy is offline   Reply With Quote
Old 06-26-2007, 10:56 PM   #68
junkman
Member#: 152155
2007 Sti Ltd
UGM
This is my first ever post to a forum - kinda intimidating! Lots of info on oil!! Just wondering - what weight/grade of oil do the Subaru rally pros use?
junkman is offline   Reply With Quote
Old 06-26-2007, 11:28 PM   #69
bluesubie
Member#: 767
04 FXT
Well, the Subaru World Rally Team uses Motul 300V 5W40. Whether or not it's in an actual rally car, I don't know.
-Dennis
Old 06-27-2007, 12:09 AM   #70
junkman
Member#: 152155
2007 Sti Ltd
UGM
Thanks for the reply, Dennis Unless I'm mistaken, Subaru recommends 5W-30 oil for all Imprezas, turbo and non-turbo. Any reason why I couldn't use a 10W-30 or even 10W-40 in my Sti?
Old 06-27-2007, 11:13 AM   #71
bluesubie
Member#: 767
04 FXT
Looky at the owner's manual and don't go only by what's on the oil cap. Otherwise, your driving privileges may be suspended by nasioc. Anyway, here's a start; 5W30 is preferred for full economy.
-Dennis
Old 06-29-2007, 12:24 AM   #72
gopsu
Member#: 96448
02 WRX VF34
Dennis, how about use of 10W50 M1 on stage 4 WRX?
gopsu is offline   Reply With Quote
Old 12-10-2007, 01:24 PM   #73
Drake13
Member#: 153927
2004 STI
WRB TBE, TiaL 44mm EWG
Excellent FAQ!
Drake13 is offline   Reply With Quote
Old 12-10-2007, 02:48 PM   #74
jacky599r
Member#: 137631
2006 WRX
Red
i drive a 2006 rex and lives in singapore. Here, we see avg temp of 30 deg C or higher. Then, what kinda oil do u guys think its suitable considering the tropical climate? In addition, im in for a 20k service, wanted to do a engine flush(not "treatment" kind but sort of a machine that recirculates a solution throughout the engine) just before i change turbo but was told it does more harm then good to the engine. Lastly, back to the oil... 300v seems to be a popular choice and im running 10w40 with 5k intervals
jacky599r is offline   Reply With Quote
Old 12-26-2007, 03:38 PM   #75
sleepless
Member#: 135321
2004 Impreza 2.5 RS
Blurple
Random fact for those changing their own oil:
Baby powder is your friend when you get oil splatter on your clothes. Add a pile of the stuff on any spots and let it sit overnight. In the morning, remove excess and wash as usual. Repeat as needed. Oil gone!
sleepless is offline   Reply With Quote
Cooling System FAQ: Read if you want coolant information! Unabomber Service & Maintenance 629 10-24-2016 03:16 PM
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 712 10-17-2016 06:27 PM
Injector, Fuel Pump, and Fuel Rail FAQ: Read if you are thinking of upgrading! Unabomber Newbies & FAQs 180 09-13-2016 03:41 PM
Tool FAQ: Read if you want information on Subaru specific tools and sundries Unabomber Service & Maintenance 41 08-16-2014 05:59 PM
Car Storage FAQ: Read if you are storing your car for more than 30 days Unabomber Newbies & FAQs 104 10-10-2013 02:07 PM
