Old 02-08-2004, 05:52 PM   #1
Kager
Member#: 54576
1993 Legacy L Wagon
Pearl White
Default HID installation
I don't know if someone posted this thread before, but I couldn't find it, so I'll just post it again.
ok...
I just bought a 9007 8000k HID kit from Ebay, and doesn't feel like to spend anymore money to hire someone to install it, so Does anyone know how to install a HID kit on a 02' WRX? please provide some instructions!! I really need some help on this one! thanks!!
by the way, i am a new guy, just joined today! nice to meet you all!
Kager is offline   Reply With Quote
Old 02-08-2004, 06:47 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Not to beat up on you, but 8000K is not optimum for light output. Anything above 5000K will be more blue/purple, have more glare and produce less usable light. It's also not the best idea to retrofit HIDs into the stock reflector housings, but since you've already bought them-
First, check the bulbs to be sure they are the proper type for reflector housings. They should be D2R type which have an anti-glare mask on the bulb glass. If they don't have that mask they are D2S type which is for use in projectors. Try to exchange them if they're D2S.
You'd normally want to disable your daytime running lights when installing HID's, although that may be a problem in Canada since they are required by law and I believe you will fail inspection if they don't work. If you don't care and want to disable them anyway, unplug the main DRL control module next to the glovebox. There are threads here you can search for that detail its exact location and how to unplug it. If you decide to keep your DRLs, make sure you do NOT connect the negative wires from the HID ballasts to the factory headlight plugs. You must wire them as follows-
The HID ballast will have a positive and negative input. Connect the negative wire from each ballast directly to a chassis ground or the negative battery terminal. Connect the positives to the center pin of the factory headlight connector on each side, this is the common headlight power. If your kit doesn't include any type of plug-in connectors for your car you'll have to cut and splice the connections. Make the connection to the factory harness by either soldering and heat-shrinking or butt-splicing and taping. The connection must be electrically sound and well-insulated.
Some HID kits will blow the 15A headlight fuses when first turned on, due to the high current the ballasts draw at startup. If this happens, the headlight fuses can be replaced with 20A ones. Do not go any higher. If they still blow there is a problem, the ballasts will not draw that much.
It's also possible to use relays to power the HIDs directly from the battery, but if your kit doesn't include relays and instructions you'd need help to do this.
Finally, be aware if you aren't already that when you install the HIDs in your stock lights you will lose your high beams. And one more thing, aim them very carefully to minimize the chance of blinding other drivers.
Old 02-09-2004, 12:14 AM   #3
Kager
Member#: 54576
1993 Legacy L Wagon
Pearl White
Thanks for the information!
it's very informative!!
Old 02-13-2004, 11:54 AM   #4
1984
Member#: 16461
WRB w/paintchip flake
Question
Why?
1984 is offline   Reply With Quote
Old 02-13-2004, 07:05 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
They are designed for the light output and pattern of halogen bulbs. When HIDs are retrofitted in this type of housing they will be very bright so you may think they are great, but they will produce an excessive amount of glare to other drivers. This is why the NHTSA recently enforced its rule banning sales of such retrofits.
Old 02-14-2004, 02:41 AM   #6
Subie2.5RS2003
Member#: 41941
2003 Impreza 2.5RS
Ridge Blue Pearl
www.hidplace.com
click on information and it has a step by step way to install them
Subie2.5RS2003 is offline   Reply With Quote
Old 02-14-2004, 02:55 AM   #7
1984
Member#: 16461
I see...hmmm. So no matter how I aim the headlights, the way in which the HID light is being reflected is going to cause excessive glare no matter what. That's crappy.
HID install questions Bear Interior & Exterior Modification 0 12-13-2001 07:11 PM
HID install in 02WRX Morette lights Woodywayne Interior & Exterior Modification 1 11-07-2001 10:56 AM
GC8 Morettes HID install problem! Need Help sti2_5rs Interior & Exterior Modification 7 11-02-2001 04:49 PM
Help! HID install sti2_5rs Interior & Exterior Modification 12 03-14-2001 10:37 AM
HID install ? dead-eye Technical Forum Archive 8 10-10-2000 08:57 AM
