Old 02-08-2004, 09:22 PM   #1
SupraScooby
Member#: 52123
05 WRB STi
04 AW STi GT30R [RIP]
Default Intake Silencer delete elbow
when taking out the intake silencer on an STi..is it worth replacing it with the intake silencer delete elbow since it would still have the ram air scoop doing its function?
id like to hear my turbo/recirc valve more thx
SupraScooby is offline   Reply With Quote
Old 02-08-2004, 09:56 PM   #2
ImportVenom
Member#: 34204
2004 WRX
WR Blue
I'd recommend keeping the elbow so you get the cold air from the front of the car. I just cut off the silencer box and sealed up the elbow myself. However, you won't be able to really hear the factory bypass valve. You will hear better spool, but can barely hear the bypass valve even with the radio off and the windows up.
ImportVenom is offline   Reply With Quote
Old 02-08-2004, 10:05 PM   #3
SupraScooby
Member#: 52123
05 WRB STi
should i replace the panel filter too or just keep it oem? thx
was looking at the blitz since you dont have to oil it
Old 02-08-2004, 10:12 PM   #4
ImportVenom
Member#: 34204
2004 WRX
WR Blue
That's really up to you, but don't expect a huge difference from it. I don't think you'd be able to notice it by driving. Maybe try searching for opinions on that filter.
Old 02-08-2004, 10:26 PM   #5
SupraScooby
Member#: 52123
05 WRB STi
yeah not looking for any performance gains...just wondering if it filters better
Old 02-08-2004, 10:50 PM   #6
Mishmosh
Member#: 45030
2004 WRX wagon
Platinum silver metallic
If anything, aftermarket filters are worse but will extend your change/re-oil interval if you do not wish to keep track of replacing stock filters.
Regarding removing the intake resonator with or without an elbow, just be aware that there is little if any performance gain. Without an elbow will net you some turbo noise, with the delete elbow will sound just like stock.
Mishmosh is offline   Reply With Quote
Old 02-08-2004, 11:25 PM   #7
SupraScooby
Member#: 52123
05 WRB STi
some turbo noise is what i was aiming for...so i guess no elbow for me
how often do you have to replace the stock filter?
Old 02-08-2004, 11:33 PM   #8
SupraScooby
Member#: 52123
05 WRB STi
well...come to think of it...if the delete elbow in place sounds like stock...what was the whole point in replacing the intake SILENCER?
Old 02-08-2004, 11:47 PM   #9
ImportVenom
Member#: 34204
2004 WRX
WR Blue
You DO hear the turbo spool up more. I'm saying you can't really hear the factory bypass valve (barely). You should do it just to improve airflow in your intake system. I'm just saying the change in sound is not drastic, but yes, you can hear the turbo spool more.
Old 02-09-2004, 12:16 AM   #10
asceleon
Member#: 18064
2004 STi
to answer both commens, I hacked my friends snorkel up for him when I took it out. I cut it up, sealed the bottom to essentially make a U (elbow) to connect the ram air input and the airbox. Why did I do it this way? To retain the stock airflow and still keep cooler air coming into the airbox, instead of stagnant engine air.
To answer the question at hand, more spool and turbo whine were audible BUT the sound of the factory bpv didnt really change.
asceleon is offline   Reply With Quote
Old 02-09-2004, 07:06 AM   #11
SupraScooby
Member#: 52123
05 WRB STi
oh ok....i didnt know you were referring to the bov sound being stock...gotcha
Old 02-09-2004, 07:07 AM   #12
SupraScooby
Member#: 52123
05 WRB STi
what did you seal it up with?
Old 02-09-2004, 07:50 AM   #13
Mishmosh
Member#: 45030
2004 WRX wagon
I have the GP Moto silencer delete elbow. Maybe I'm deaf but it sounds just like stock. I'm not hearing any turbo noises. I was hoping for something more...
Old 02-09-2004, 05:07 PM   #14
SupraScooby
Member#: 52123
05 WRB STi
hmm maybe its a lil louder w/o the elbow
Old 02-09-2004, 06:30 PM   #15
skiteton
Member#: 53064
2011 Legacy 2.5i
2012 Acura TSX
I just ordered the Gp Moto delete elbow from Rallitek for more spool up sound. Are telling me you can't tell a difference after you installed it? If that's the case, I'll be fuming when it gets here! I'd like anyone else's comments too, if you have a GP moto elbow.
skiteton is offline   Reply With Quote
Old 02-09-2004, 08:21 PM   #16
RokketRide
Member#: 17984
1967 Barracuda
2000 OBSTi
Hey if anything, the elbow saves you a few ounces of weight of the front end
RokketRide is offline   Reply With Quote
Old 02-09-2004, 08:25 PM   #17
Saladin
Member#: 36844
2004 WRX Sedan
WR Pearl Blue
Um, we sealed it with a thick plastic lid of some sort, just cut the plastic to shape and hot glue guned it until it was sealed right (might want to file down the elbow part so it is flat and you can seal it much easier that way).
The turbo sounds ..well..you can actually haer it lol. The BPV, isnt really supposed to make a sound, so you dont really hear it.
I added an mbc recently and now i can hear the spoolup at much lower rpms and its quite fun to hear. (when you get into higher rpms, the roar sometimes tends to overpower the wooosh)
Saladin is offline   Reply With Quote
Old 02-09-2004, 10:10 PM   #18
ImportVenom
Member#: 34204
2004 WRX
WR Blue
Ya I just used the plastic from the silencer part of the box that I cut out. I cut it to fit, and then used plastic epoxy to seal it up. To the person above expecting much better spool etc, I wouldn't keep my hopes up. The difference is small, but it's a really cheap mod, and you can definitely hear spool up more.
Old 02-10-2004, 12:03 PM   #19
Saladin
Member#: 36844
2004 WRX Sedan
WR Pearl Blue
the quick spoolup was a result of the mbc, not the silencer delete.
Old 08-25-2004, 01:48 PM   #20
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
I just installed one and can't really hear a difference either *bump*. Maybe a liiiitle louder but that's about it.
john
Old 08-25-2004, 02:33 PM   #21
WRXSleeper
Member#: 43853
2004 WRX Sedan Stg 2
Platinum Silver
you can't really here the difference in 1st gear that much w/ the delete elbow you need ne in like 3rd or 4th just cruising and hit the gas. there is a sound difference though slight and i think it made me spool a tiny but quicker.
i would stick with oem filter. i was thinking of K&N, but from all the reasearch i have done here and at clubwrx i think i'll stay oem.
WRXSleeper is offline   Reply With Quote
Intake silencer delete elbow...WHERE? Predator3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-01-2004 12:24 AM
FS: GP Moto intake silencer delete elbow $30 shipped. 03WRXMA Private 'For Sale' Classifieds 11 07-21-2004 07:37 PM
Intake silencer delete elbow hondascooter Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 06-17-2004 05:09 PM
FS: Intake Silencer Delete Elbow SupraScooby Private 'For Sale' Classifieds 9 05-26-2004 02:28 AM
gpmoto Intake Silencer delete elbow Benjamin Tang Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-04-2003 04:10 AM
