Old 03-23-2010, 06:23 PM   #1
swiftwrx06
Member#: 130897
2006 6 speed WRX 18G
330awhp 355ft/lbs
Default Running wire to the rear underside of car
Simple question.. Whats the best way to run a wire from the passenger compartment to the the rear underside of the car, specifically the rear diff? I'm doing a lot of rewiring of mods and I want to wire my STI cluster to my rear diff sensor instead of just grounding it so it actually has a function. I just can't find a way to wire from the trunk area to underneath the car.
swiftwrx06 is offline   Reply With Quote
Old 03-23-2010, 06:28 PM   #2
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
Run the wire inside the vehicle from the cluster, under the passenger's side inside rocker mouldings (what covers the edge of the rug) to under the rear seat.
Under the rear seat are grommets and covered openings so you can effectively run the wire to the rear-end from there without having an exposed wire running the length of the car.
Old 03-23-2010, 10:32 PM   #3
swiftwrx06
Member#: 130897
330awhp 355ft/lbs
Thanks, I ran the wire under the rear seats and there was a rubber seal with some wires running through it behind the fuel lines. I just poked a hole in it with an exacto and ran the wire through to under the car. It hooked right to the rear diff sensor using a spade connector, but I might get the OEM connector from the dealership to avoid corrosion on the leads.
Old 03-26-2010, 10:50 AM   #4
hoffmanEstates
Member#: 122043
04 wagonier
psm
good:
hoffmanEstates is offline   Reply With Quote
Old 03-26-2010, 10:57 AM   #5
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
If you cannot source an OEM connector, use shielded crimp-on connectors and put dielectric grease on each connector to keep water, dirt, and so-on out.
Old 03-26-2010, 11:49 AM   #6
island boyeee
Member#: 171758
2006 WRX Ltd Stg m@!
Blk&Grn / 08 Daytona 675
^ this. i put heat shrink on all my electrical connections as well.
i was also going to point out that there is a big rubber grommet in the spare tire well. this is where i ran my power in for my stereo.
island boyeee is offline   Reply With Quote
How do you run wires to the center console? RaceTM Electrical & Lighting 7 11-07-2009 12:49 AM
6spd housing contacting underside of car IA Performance Transmission (AT/MT) & Driveline 5 11-17-2003 12:57 PM
Creaking noise from underside of car. Tranny/diff? QwikRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-27-2003 01:20 AM
Running wires to the speakers in the door Imprezer Car Audio, Video & Security 11 08-06-2002 11:57 AM
running a power wire to the trunk Bobalouy Car Audio, Video & Security 10 02-02-2000 12:40 AM
