Closed Thread
Old 02-09-2004, 09:29 AM   #1
wrxxed
Member#: 20567
04 STi
Sil/Sil
Default Radar detector hookup
Best(most convienient) place to use a vampire crimp to get power? Anyone used the compass mirror?? or dome light?Thanks.
wrxxed is offline
Old 02-09-2004, 09:34 AM   #2
4pOwnag3
Member#: 53200
2004 S60R
Gray
hey, STIRS and i we routed our V1's throught the dome light! its easier to see more of the road. the V1 is placed close to the top of the windshield so the wire is almost non existant!!! easily connected too!!
4pOwnag3 is offline
Old 02-09-2004, 12:21 PM   #3
wrxxed
Member#: 20567
04 STi
Sil/Sil
Thumbs up V1 Hookup
Thanks,which wire(s) did you tap in to and how do you like the V1, I've been getting alot of false laser alarms? I think its the onstar in other cars setting it off?
Thats actually where I initally wanted to tap the power from but wasnt sure I'd blow a fuse with the increase power(be it minute)draw!
wrxxed is offline
Old 02-09-2004, 02:11 PM   #4
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
You don't need to vampire anything if you use the mirror/compass plug. I did mine a long time ago and it works like a champ.
False alarm in laser are usually from red LED taillights like those on the new Trailblazers...my '95 vintage Passoprt falses on those if I'm behind a Trailblazer at a light.
Uncle Scotty is offline
Old 02-09-2004, 04:02 PM   #5
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
you can always use the cigarette lighter wire behind the dash (not like subaru gave us the lighter anyway) and run the wire up behind the molding and then underneath the roof molding to the radar. Its easier to hide the fuse behind the dash (just above the fuse terminal block is a nice wide open space). Only a little piece of the wire with the phone jack adapter is seen through the window, but mines blocked from view via the e-z pass.
coyote73176 is offline
Old 02-09-2004, 05:00 PM   #6
wrxxed
Member#: 20567
04 STi
Sil/Sil
Lightbulb wiring advice
The only problem tapping into the map light id its a constant power so I'll have to manually shut the radar off everytime I turn the car off,I'd rather not trust myself in doing so. I'd rather it be an ignition powered/switched supply. My friend wired it from the cig lighter but it seems like such a far way to go and I was trying to avoid removing the a pillar cover..etc..
Thanks for the input,and I wasnt aware the LED taillights would send a false alarm to my $400 V1?? Its pretty annoying ,especially when your over the speed limit!
wrxxed is offline
Old 02-09-2004, 06:21 PM   #7
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
The mirror/compass plug is switched
Old 02-09-2004, 08:29 PM   #8
JokeZero
Member#: 19501
2002 WRX WR Blue
SQC 072
JokeZero is offline
Old 02-10-2004, 11:22 AM   #9
wrxxed
Member#: 20567
04 STi
Sil/Sil
Exclamation V1 help
Thanks,thats exactly what I was looking for!! You da man!
AWESOME LINK!!!
wrxxed is offline
Old 02-11-2004, 07:44 PM   #10
STIRS
Member#: 16731
2002 Impreza WRX
WR Blue
If you want you can tap into the black wire in the harness with the ground from the V1, since its the ground wire for the optional mirror.
STIRS is offline
Old 03-02-2004, 01:33 PM   #11
4pOwnag3
Member#: 53200
2004 S60R
Gray
thats probly b/c its a passport. . . but the false lasers do occur on mine aswell, not very often though! i tried my laser pointer it didn't set it off!
4pOwnag3 is offline
Old 03-02-2004, 02:10 PM   #12
wwwwc
Member#: 14003
2002 WRX Wagon
Dirt-colored
I don't have a compass mirror. Which wire should I tap?
Thanks!
wwwwc is offline
Old 03-02-2004, 02:33 PM   #13
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Thanks!
The plug is there for the compass/mirror is there even if you don't have the compass/mirror...A simple circuit tester will tell you which wire is hot.
Old 03-02-2004, 03:46 PM   #14
bleuquila
Member#: 31922
03 wrx wagon
fastAr than sound
Default Re: wiring advice
hehe, well hopefully if you're going that fast, you aren't all that close to brake lights! The only times my V1 has done a laser alert while I'm driving, not parking at a traffic light, there has been a cop waiting for me. Good thing I wasn't going too fast at the time
bleuquila is offline
Old 07-16-2010, 03:08 PM   #15
skep18
Member#: 214971
2005 WRX
Can anyone provide a working link for this roof install?
skep18 is offline
Old 09-21-2010, 09:25 PM   #16
rando666
Member#: 258433
any links?
rando666 is offline
Old 09-21-2010, 10:32 PM   #17
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
This thread is over six years old.
Mulder is offline
Closed Thread
Will a car's radar system set off a radar detector? AVANTI R5 Non-Subaru News & Rumors 10 01-28-2009 02:17 PM
Do cops have new radar gun that doesn't set off radar detector? JDM addict Off-Topic 48 09-09-2008 08:56 PM
Escort 8500 x50 Radar Detector -CHEAP #1 Radar/Laser Detector stevestarr NWIC Private Classifieds 1 12-01-2007 07:16 AM
Escort 8500 x50 Radar Detector -CHEAP #1 Radar/Laser Detector stevestarr Non-Subaru Stuff 0 12-01-2007 06:12 AM
Testing Water - Beltronics RX 65 Radar Detector and extras! Rated #1 by Radar Roy Rick Dizzle Interior/Dressup/Audio & Security 10 12-30-2006 02:58 PM
Message Board Statistics All times are GMT -4. The time now is 02:41 AM.
