Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 02-09-2004, 12:21 PM   #1
live311
Member#: 10801
2008 Outback
Question Computer Help: Video card not getting enough power
While surfing the web in IE I get a warning saying that my video card is not getting enough power, so it's been de-tuned to allow it to run properly. I'll check the video setup myself after getting the error and everything seems to be fine. Then I'll get it a couple more times and the computer will re-boot.
Here's my system:
Abit IS7 mobo
Intel P4 2.6C
1 GB Corsair TwinX PC3200
Gainward Geforce FX5900 128MB
Seagate 120GB SATA HD
Maxtor 13GB ATA HD
Sony CDRW/DVD-ROM combo drive
floppy drive
420W Raidmax PS
3 case fans (1 with LEDs)
Windows XP Home
There's no way the wattage is too low for this system, unless the power supply is a piece of crap (it came with the case). I've got the video card plugged into its own molex connector, so it's not daisy-chained with anything else. So what the hell is the problem? It's really starting to piss me off
live311 is offline   Reply With Quote
Old 02-09-2004, 12:43 PM   #2
Kaiser
\_(ツ)
Member#: 7170
Aut Kaiser,
aut nullus.
Did you plug the power cable from the video card directly into one coming from your power supply? The 40 watt the AGP slot provides isn't enough for the the 5900's, which is why they come with their own power cable.
EDIT: ok, so I read your post more carefully but still, make sure it's connected securely. That's the only thing it could be, or test the power cable you're using is actually getting power from the supply.
Kaiser is offline   Reply With Quote
Old 02-09-2004, 12:44 PM   #3
Kaiser
\_(ツ)
Member#: 7170
Aut Kaiser,
aut nullus.
Look at the top right part of the card. See the power cable?
Old 02-09-2004, 12:58 PM   #4
Star*Child
Member#: 5659
There's two types of voltages for AGP slots. 1.5v and 3.3v Are you MoBo and vid card compatible with each other?
Star*Child is offline   Reply With Quote
Old 02-09-2004, 01:03 PM   #5
Turbosnow
Member#: 9029
'02 WRX, 84 VW Conv
Check the solder joints on the power connector on the card, if you have a test light for your car check the power at the connector as well.
Turbosnow is offline   Reply With Quote
Old 02-09-2004, 02:28 PM   #6
live311
Member#: 10801
2008 Outback
Yes, I do have it plugged in at the molex connector. I've had it plugged in at a couple different connectors. I do have to use a splitter simply because I need it to reach, but I have nothing plugged into the other end of the splitter. I'll try unplugging the case fans tonight and see if the problem persists. If not, it's obviously the PS. I'm pretty sure that's it. Otherwise I think I'll have to RMA the card
Old 02-09-2004, 02:34 PM   #7
Turbosnow
Member#: 9029
'02 WRX, 84 VW Conv
I doubt it;s the ps unless it's voltage regulation is really crappy, it could easily be a bad solder joint on the card at the power connector.
Old 02-09-2004, 02:37 PM   #8
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
check voltage, not wattage.
DISCOPOPE is offline   Reply With Quote
Old 02-09-2004, 03:35 PM   #9
live311
Member#: 10801
2008 Outback
The AGP voltage is maxed out at 1.65V in the BIOS. Someone on another message board recommended I increase it from the 1.55V it was set at to see if it would solve the problem. It didn't. Would decreasing the voltage to 1.5V help?
Old 02-09-2004, 03:46 PM   #10
Star*Child
Member#: 5659
that may be the problem? I'm not an expert on this, but my new mobo (soyo plat drag 2) only supports the 3.3v cards. Maybe the issues it that you AGP port isn't supplying enough voltage to your card?
I'm using a 9800xt at home and the AGP slot has a little light in case the card you try and plug an older 1.5v card into the slot.
Check your vid card documentation and see what it is and check your mobo documentation to see what you can support.
Old 02-09-2004, 04:04 PM   #11
J!M
Member#: 31595
04 STi
Just knowing that you have a 420W power supply isn't enough. Somewhere in the specs for the power supply it should split up how much power can be maxed on each of the voltage lines.
It's possible that your power supply can't handle the power demands for the voltage rating the video card is on. Check out the ratings for the +3.3 +5 and +12 on your power supply, and make sure you're not going over those limits with all of your devices.
J!M is offline   Reply With Quote
Old 02-09-2004, 04:15 PM   #12
m750
Member#: 2278
8Sti | 07 allez
White | Comp
just because the ps says it's rated for 420, doesn't mean it actually puts that out. It could be the mazda of power supplys. If one of your friend has a qualiy / name brand one, I'd try that.
AO
m750 is offline   Reply With Quote
Old 02-26-2004, 02:51 PM   #13
dicksosa
Member#: 13742
2002 Impreza WRX
WR Blue
The RaidMax PS are OK.. they are really not all that great. What J!M and m750 say basically applies.
Try Antec, Enermax, Thermaltake, Zalman -- those are some good Power Supplies. And probably nothing less than the 420 you had before..
For the rest of the components in your system try the Antec TrueBlue 480. -- As the rest of your stuff is pretty good quality why not have the PS be too.
Just a note ALL these power supplies are not cheap ($80-110). But it's one area that you really shouldn't skimp out on. Also having a better PS can actually allow you to overclock your computer a bit more.. usually.
dicksosa is offline   Reply With Quote
Stance Gr+ Pro coilovers, not getting enough rear camber with camber plates caffeinefr3e Brakes, Steering & Suspension 24 03-06-2009 07:43 PM
Computer Gurus: Video Card Help ricified Off-Topic 5 06-03-2006 08:58 AM
Not getting enough sex from my GF....HELP. wrxman555 Off-Topic 180 01-05-2005 02:45 AM
My uncle fell through some ice today, drunk and not getting enough sex on his date. Protege Menace Off-Topic 4 12-25-2004 01:17 AM
