Old 02-09-2004, 01:36 PM   #1
elektrikheadx
Member#: 37077
2002 WRX Sedan
WR blue
Exclamation radio wiring - battery terminal
vehicle: 2002 Subaru WRX
Ok.. so here is my issue. I ran a line the other day from the battery through the hole in the firewall and hooked it up to my radio, no problem.
Yesterday.. (after the fact) I bought some cable shrouding plastic (just blue tube..) and slid that onto the wire all teh way from the battery to the inside of the car (just enough to clear the hole on the inside).
Now.. I dont know if I've just become crazy or what, but I hear a weird noise when im going say 60-75 down the interstate. It's reminiscent of a high-speed fan rubbing up against something.. that oscillating RRrrRRrrRRRrrRRrr. It isnt LOUD but I can hear it, and just being able to hear it is driving me nuts. BTW: this is when the radio is Off.
My question is whether it is possible I could have knocked anything loose or strangled a cable or if its possible I could have ran the wire against a fan of some kind. I also think the "whoosh" of the TC sounds odd but that is probably me just being crazy.
Pics:
Before:
After:
Where the blue disappears, is where it tucks down and as far as I can tell, goes directly into the firewall hole to the inside. It is also fairly taut.
Helpful replies welcome!
Thanks!
elektrikheadx is offline   Reply With Quote
Old 02-09-2004, 04:08 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
Well, if this only happened after you put the blue covering on (and moved it to its current location) you might try moving the wire, as it might be getting some interference from some other signal. Is that wire going to the radio? Or an amp?
Shane
www.paranoidfabrications.com
PARANOID56 is online now   Reply With Quote
Old 02-09-2004, 04:10 PM   #3
elektrikheadx
Member#: 37077
2002 WRX Sedan
WR blue
It's going to the radio. It's an Alpine with an internal mosfet amp.
Regardless, I get the sound whether the radio is on or off (even took the fuse out to test).
Right, I'm guessing that the blue covering is rubbing up against something.. but I don't know what exactly, especially since I cant get down inside there to look.
Old 02-09-2004, 05:00 PM   #4
PARANOID56
Member#: 22035
2003 Brocoma DCab
is it posable to pull the wire back out like in the fist pic? and see if its gets better. if it stops, then there is some enterferance somewere in the engine bay. try routing the wires a different way.
Shane
Neg battery terminal ground wire wantinaSTI Electrical & Lighting 2 03-02-2010 02:47 PM
Whats involved with changing the battery terminals on the wires? PaulRex Electrical & Lighting 4 10-08-2007 08:25 PM
Battery Terminal too small Kevin Thomas Normally Aspirated Powertrain 2 05-18-2002 03:26 PM
Battery terminal? Revision Mid West Subaru Owners Club Forum -- MWSOC 11 04-29-2002 01:48 PM
Keep those battery terminals clean dudes! PunksWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-18-2002 12:09 PM
