Old 02-09-2004, 09:41 PM   #1
SubieStyle
Member#: 48936
I Do Installs On The
Side;) PM me for details!
Question Best source to power gauges from
I want to put three guages in my 04 WRX, I will be using a dash pod.I will be installing Autometer; manual boost gauge, electric oil temp gauge, & EGT gauge. What is the best source to power these gauges with? I was thinking of using the wires left from the clock to power them (after I remove it). Will these wires give a sufficient source of power for three gauges?(both for power & lighting). If I use these does anyone recomend running a relays for the power & lighting? I want to make sure they are as bright as possible, & and work correctly! Any help & input word be great. Thanks in advance.
P.S. I searched and found a few ways to do this, but I wanted to know which works the best.
Will.
SubieStyle is offline   Reply With Quote
Old 02-09-2004, 11:17 PM   #2
brunetmj
Member#: 8023
2004 2.5 RS
I generally just use the clock wire for power. I run three different things off the clock wire (2 gauges and a radar detector) without problems. Gauges to not really require much power. The head unit acc. power wire (red) could also be used in addition to the hazard switch if you want to split up the load.
brunetmj is offline   Reply With Quote
Old 02-09-2004, 11:44 PM   #3
SubieStyle
Member#: 48936
Okay cool, thanks for you input "brunetmj". I aslo have a radar detector I would like to hook up direct too, I just want to wait until the gauges are in so i'll no where it'll end up (but thats a whole other story). So will the power for "illumination" also have enough juice to make the gauges as bright as they can be?
Old 02-10-2004, 10:46 AM   #4
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
I also used the clock since all the needed wires are there. You won't have a problem getting enough power from those wires.
mbiker97 is offline   Reply With Quote
Old 02-10-2004, 12:27 PM   #5
awdman
Member#: 27962
2003 WRX Sedan
Blue, with more dings!
Default Same setup except...
I have oil pressure. I used the clock for switched power and the extra wires off the radio for illumination/ground. I had to remove the factory Boost gauge so I was already working in that area though. Plenty bright, and works with the dimmer...
awdman is offline   Reply With Quote
Old 02-10-2004, 01:58 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
The spare plug on the radio harness is your best source of 'dimming' power for the lights on the gauges.
The plug for the mirror/compas is great for the radar detector 'cuz it is swithched and fused already, and it you don't have the mirror/compass it is unused......and the best theing about both of these is that you don't have to cut anything...just get some spade connectors from radiosuck and plug 'em in.
Old 02-10-2004, 03:01 PM   #7
SubieStyle
Member#: 48936
So there is an unused plug behind the radio? Do I have to remove the radio to get to it, or can I do it w/o having to remove it? Thanks every one for you input.
Will.
Old 02-10-2004, 03:08 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
Will.
Sorry, but the radio has to come out to get at it. It is a PITA, but if you are smart and make a nice harness and put it where it is easy to get at for future use(like I did)....it is a job done once.
I can not understand why people make such an issue of where to get power from on this car...it is SO SIMPLE to do right and you DON"T have to cut/splice or vampire anything if you take a little time and use what god(and Subaru) gave you and do it right.
This car, other than the switched grounds, is a piece of cake to wire stuff into. The relay pannel has all sorts of possibilities, and the unused plugs are there for the plucking....
Old 02-10-2004, 03:40 PM   #9
SubieStyle
Member#: 48936
Okay cool, thanks for you help!
Will.
Best way to ship wheels from the US to Canada!?!?! kyotoegg Canada Region Forum 18 04-25-2007 06:41 PM
Best Way to Xfer Audio from PC to Mac? scoobydrew06 Off-Topic 9 03-04-2007 07:21 PM
Best way to return oil from turbo to block? BrysImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 8 12-02-2004 01:40 AM
Best Amp to power single w6v2? dman918 Car Audio, Video & Security 26 09-24-2004 08:27 AM
Oem Rotors-Pads etc. for daily driver. whats the best source to buy ? ptsmalls Brakes, Steering & Suspension 1 08-23-2004 11:51 AM
