Old 02-09-2004, 10:06 PM   #1
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
Question Cusco front lower arm bar version 1 vs version 2
Hello all...
I was wondering which cusco lower arm bar is better to run, version 1 or version 2. From a pic that I see on http://www.gruppe-s.com on this page: http://www.gruppe-s.com/Subaru/subsus.htm it appears that they are both installed on the underbelly of that WRX.
1. So could you install both?
2. Will the factory plastic splash guard piece still fit?
3. What will the main advantages be? More oversteer? more understeer?
thanks
-Jason
jay25RS is offline   Reply With Quote
Old 02-09-2004, 10:46 PM   #2
igalwrx
Member#: 13643
'02 WRX Sdn WRB
'05 Leg GT Ltd Wgn Black
I have the v.2
To answer your questions:
1.No, on the wrx you can't have both.
2.yes
3.For the v.2, Structure is much more stiff. Car "feels" much better. Initial turn-in is slightly better. Suspension works better because of it. I believe the v.1 has the same initial turn-in improvement as the v.2 but since it's only a 2-point versus the v.2's 4-point, the stucture is not stiffened. The v.1 does not affect understeer or oversteer, but the v.2 adds significant understeer which could be easily neutralized if you have a rear swaybar set to a stiffer position.
Of note, the v.2 is a nice solid piece. It will be the lowest point of the car (it sticks out maybe by an inch from the next lowest point on car). It weighs probably less than 3 pounds. Installing it is easy as long as you have the means to break the 2 bolts attached to the control arm which are torqued to about 160 lb-ft.
igalwrx is offline   Reply With Quote
Old 02-25-2004, 07:12 PM   #3
kuks
Member#: 39753
07 OBP WRX
03 Sonic Yellow WRX
Would a front sway bar offer the same results/feel?
kuks is offline   Reply With Quote
Old 03-14-2004, 10:03 PM   #4
pigeonfarmboy
Member#: 15146
93 RSTi
" to kuks question
pigeonfarmboy is offline   Reply With Quote
Old 03-14-2004, 10:37 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
The short answer is NO....
I have the v2 and it makes the front of the car 'point' better. It helps get rid of some of that 'disconnected' feeling between the front end of the car and the steering wheel.
Old 03-14-2004, 11:16 PM   #6
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
yea i hope i can figure out how to put it back on, when I take off that front u-shaped bar....
ScreaminFast is offline   Reply With Quote
Old 03-15-2004, 02:14 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
Ya just need some spacers for the front bolts...
Old 03-15-2004, 11:22 AM   #8
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
home depot special?
Old 03-15-2004, 11:47 AM   #9
Genya
Member#: 49899
2004 STi Blue/Silver
[email protected]
Is this also an Effective mod. for the STi?
TIA,
n00b
Genya is offline   Reply With Quote
Old 03-15-2004, 11:48 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
I used the spacers from my ALK...works great.
If you have no ALK spacers, then you will need about 1 1/4" worth of a spacer/side.
Old 03-15-2004, 03:39 PM   #11
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
yea i bought the motorsports ALK, so it didn't come with spacers.... I wonder if I can buy spacers from whiteline....?? hehe
Old 03-15-2004, 03:40 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
I'm sure that if you email Whiteline, you will get a rapid, competent response.
Have you installed the ALK yet?
If not, you may want to prepare yourself for a shock when you do and the 'sport' or 'comfort' one may be on your short 'to get' list....
Ask me how I know
Old 03-15-2004, 04:10 PM   #13
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
hehe i haven't installed it yet
I'm putting the motorsports alk in with the STi aluminum control arms, Eibach ERS 10.8K (600lb) springs for my JIC's, STi lateral links and trailing arms, and whiteline rear diff bushings...
Old 03-15-2004, 05:27 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
So this isn't a street car, then. OK.
Yeah...on the track, you should be fine...
Old 03-15-2004, 06:54 PM   #15
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
its more or less my race car, but I'll take it out for a spirited drive every once and a while... hehe
Cusco front lower arm bar version 1 sti* fan Suspension/Brakes/Handling 1 06-09-2009 04:59 PM
F/S: TX Cusco Front Lower Arm Bar forced4 Private 'For Sale' Classifieds 5 03-26-2005 12:13 PM
CA: FS Cusco Front Lower Arm Bar and Greddy Intake STEALTH-WRX Private 'For Sale' Classifieds 8 09-07-2003 01:57 AM
Cusco front lower arm bar for GC8 Keiho Brakes, Steering & Suspension 1 04-03-2002 04:37 PM
Cusco Front Lower Arm Bar Mk750 Legacy Forum 4 02-07-2002 10:00 PM
