Old 02-10-2004, 12:18 AM   #1
dwnhillskater
Member#: 42806
2007 Subaru WRX STi
Default Changing gauge cluster color
I want to change all of the lights in the interior of my car, to red. How do I do that?
Aaron
dwnhillskater is offline   Reply With Quote
Old 02-10-2004, 11:35 AM   #2
rallyshark
Member#: 44813
2008 2.5i 5-Door
Dark Gray Metallic
From the '86 supra that i've worked on:
-that as far as the gauge cluster lights, they are just bulbs with colored covers over them, just remove some molding and then the cluster and the bulbs screw in from the back. Just change the color of the rubber sleeves. As far as subies...unless they have updated the tech (don't know myself), it is probably similar
-changing digital readout colors (IE, clocks and such) is virtually impossible as far as I know without changing the gauge itself.
-LCD displays like the radio and CD players will have to stay stock backlit unless they are replaced with aftermarket ones (as far as i know anyway)
Some of my info is probably a bit dated...but i hope it helped at least a little bit.
rallyshark is offline   Reply With Quote
Old 02-10-2004, 12:59 PM   #3
KevinHeist
Member#: 50667
2000 Impreza Coupe
Enginuity Tuned
KevinHeist is offline   Reply With Quote
Old 02-10-2004, 01:32 PM   #4
ursine
Member#: 51771
2000 Impreza GC6 SRP
1980 G2 Celica Rally Taxi
A WRX is a little differant, I know that the gauges just have a condom over the bulb, so just replace the condom with the color of your choice. As far as everything else goes, its alot more complicated, you are going to need to search to get the answer.
-Branden
ursine is offline   Reply With Quote
Old 02-11-2004, 01:23 AM   #5
KevinHeist
Member#: 50667
2000 Impreza Coupe
Enginuity Tuned
Branden,
they're almost identical in what they're made out of.... still have to remove film and change bulb color, etc etc.
gauge cluster color change question imprezaBlue Interior & Exterior Modification 5 02-05-2007 05:57 PM
05 STI gauge cluster color change Kuj_05STI Electrical & Lighting 2 11-13-2006 10:48 PM
diy change ring gauge cluster color slapaho_ca Interior & Exterior Modification 6 11-07-2006 02:41 PM
Change the gauge cluster color? RacerCorrado Interior & Exterior Modification 6 09-21-2005 03:20 PM
changing Sti gauge cluster color Basshead STi Forum Archive 7 09-12-2003 03:08 PM
