Old 02-10-2004, 02:16 PM   #1
DwithBoost
Member#: 34712
2003 WRX
World Rally Blue
Default Where to find wideband O2
I can't stand not knowing what my A/F ratio is exactly. I need a wideband O2 sensor for my WRX so I can finally tune my UTEC knowing what my A/F ratio really is. Does anyone know where I can get one? Do I need one or two? Any input is appreciated.
DwithBoost is offline   Reply With Quote
Old 02-10-2004, 02:28 PM   #2
zaxrex
Member#: 9898
Water Injected Blue
http://forums.nasioc.com/forums/show...hreadid=449910
or try searching...
You might want to get some engine management for thet -22 you are running and some injectors so you don't blow your engine. Sounds like you want to run the stock injectors static up to the point that your AFRs change on a wideband. That seems like a very expensive tuning strat. to me.
zaxrex is offline   Reply With Quote
Old 02-10-2004, 08:30 PM   #3
02R6
Member#: 22157
'02 WRX '04 350Z
Cause We Are The Aquateen
02R6 is offline   Reply With Quote
Old 02-10-2004, 09:12 PM   #4
nmyeti
Member#: 4980
nmyeti is offline   Reply With Quote
Old 02-11-2004, 08:52 AM   #5
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Originally posted by nmyeti
http://www.turboxs.com/txstuner.htm
http://www.deltadashintegration.com/
jblaine is offline   Reply With Quote
any way to install wideband o2 on stock TBE? schiarelli Newbies & FAQs 22 11-23-2009 02:42 PM
Hard to find parts - where to find? eclip5e Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-09-2007 01:25 PM
A/F gauge: Ok to install wideband o2 sensor in this location? Force Electrical & Lighting 19 01-19-2007 02:23 AM
Where to find O2 bung? xcntrk75 Mid Atlantic Impreza Club -- MAIC 8 01-06-2006 02:42 PM
Where to Install Wideband O2 Sensor? Vector92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-08-2004 11:51 AM
