Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
Old 10-27-2003, 10:49 AM   #1
SubaruStu
Member#: 8972
2003 WRX Wagon
Question Backup light switch on 00 RS?
It seems that I have no more backup lights. It's always been a
little flaky since I put in the shortshifter. I assume that it's the switch
at the shifter end that is giving me grief.
Before I go tearing things apart, can someone point in the right direction
to locate the switch.
Thanks...Stu
SubaruStu is offline   Reply With Quote
Old 10-27-2003, 10:53 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The switch isn't part of the shifter, it is on the transmission case. The shifter shouldn't effect whether the reverse lights work or not, unless there is something restricting its movement when you shift into reverse and it doesn't actually go all the way in.
Old 10-27-2003, 10:57 AM   #3
SubaruStu
Member#: 8972
2003 WRX Wagon
That's what I was guessing. I figured somewhere along the line, the
shifter assembly must contact a switch, when put into reverse, to turn
on the reverse lights. I was hoping it was up top. Looks like I get to
spend some quality time on my back on a cold concrete floor.
Thanks (and quick too!)
Old 10-28-2003, 06:53 PM   #4
quietgiroth
Member#: 19375
If you get a chance please take pic's. I have the same problem, but I dont' have a garage to spend time under the car in.
quietgiroth is offline   Reply With Quote
Old 10-28-2003, 07:51 PM   #5
Murray
Member#: 11312
2009 Gray
Legacy 2.5i
i have the same problem too in my 97L... when i shift into reverse, it take about 2 seconds then the reverse light pops on(yes, only 1).
i htought it may be the short shifter too for some reason, then i realized the switch is on the case..and the linakge still moves as normal in that area..
maybe its just sticking or something.
Murray
Murray is offline   Reply With Quote
Old 10-29-2003, 09:00 AM   #6
SubaruStu
Member#: 8972
2003 WRX Wagon
I might try to get underneath this weekend, but it is looking busy
already. I can't wait too long or it'll get too cold!
I'll grab the cam if there are pics to be had.
Stu
Old 10-29-2003, 10:37 AM   #7
quietgiroth
Member#: 19375
that would be great if you get a chance. Good luck!
Old 11-12-2003, 03:46 PM   #8
Stroke
Member#: 12208
1998 Pick'm up truck
Bump.
Any pics? I have the same problem.
Stroke is offline   Reply With Quote
Old 11-12-2003, 06:51 PM   #9
SubaruStu
Member#: 8972
2003 WRX Wagon
Originally posted by strokefactor
Bump.
Sorry, I haven't gotten to it yet. Life keeps getting in the way
Old 11-12-2003, 07:51 PM   #10
Stroke
Member#: 12208
Stupid life!
Old 11-12-2003, 08:59 PM   #11
SubaruStu
Member#: 8972
2003 WRX Wagon
Stupid life!
Yeah, if I could just get rid of responsbilities, like working, I'd
have tons of time to do other stuff.....
Old 11-20-2003, 11:50 AM   #12
Stroke
Member#: 12208
dOOD! Would you quit your job and take a picture of your tranny already!?
Old 12-03-2003, 06:01 PM   #13
Stroke
Member#: 12208
bump
Old 01-06-2004, 02:40 PM   #14
hawksoob
Member#: 51978
1996 Legacy Outback
Red
My backup lights were not working for quite awhile. Replaced the bulbs - nothing. Assumed the switch. Mechanic checked it while he was underneath anyway replacing my front axle, he said it was bad and needed to be replaced. I was all prepared to order the new switch and jack the thing up and bust a knuckle or two and finally fix it.
Then ...
I was driving a moving truck, following my girlfriend who was driving my car, and noticed that the upper/outer bulb in my passenger side brake light was out. I replaced that bulb. Later that evening, as I was in the 'ru backing up, I noticed that, miraculously, my reverse lights were lighting. Possible that the dead brake light was closing a circuit to the reverse lights, and replacing it allowed current to the reverse light? Doe no. But it works now.
hawksoob is offline   Reply With Quote
Old 01-06-2004, 02:50 PM   #15
Stroke
Member#: 12208
Well, my brake lights work fine. I guess I'll just have to have a mechanic look at it.
Old 01-25-2004, 10:57 PM   #16
quietgiroth
Member#: 19375
Could someone describe where this switch on the transmission housing is. I had a look today and I couldn't see it (then again it was very cold and the most of the underside was covered in ice and snow).
My reverse lights arn't working. Check all bulbs, fuses ect.
They use to turn on if I shifted in and out of reverse a couple of times...
Old 02-04-2004, 10:29 PM   #17
quietgiroth
Member#: 19375
The part number is: 32005AA051
Part name is: SW ASSY-BACK LAMP
Total Cost: $34.67 CDN
The switch on the tranny
Plug under airbox
I also did a bit of a write up on the TSC
TSC - Quietgiroth's take on changing reverse switch
Old 02-09-2004, 11:57 AM   #18
Stroke
Member#: 12208
Sweet jesus! Thanks!!!
Old 02-10-2004, 10:49 PM   #19
quietgiroth
Member#: 19375
Yeah, sounds like I made somebody's day! If you have any questions pm me.
WTB: 05 WRX nuetral position and backup light switch speedymaker Private 'Wanted' Classifieds 13 11-28-2009 03:05 PM
97 OB sport (impreza) 5sp > where's the backup light switch? eakins Transmission (AT/MT) & Driveline 0 12-07-2004 11:55 PM
WRX Front Sway Bar on 00 RS Fast Reggie Mid Atlantic Impreza Club -- MAIC 1 01-20-2002 09:27 PM
Black spots on 00 RS wheels - cleaning tips? yakker Interior & Exterior Modification 1 04-19-2001 11:59 AM
Parking light switch on steering column...? ImprezaL General Forum Archive 13 07-12-2000 10:13 AM
