Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 02-09-2004, 05:33 PM   #1
rallyshark
Member#: 44813
2008 2.5i 5-Door
Dark Gray Metallic
Unhappy Coil Pack and wires installation?
I recently found out from my local dealer that I need to replace the (#1) ignition coil pack and the (#2) wires that go between it and the spark plugs. The job looks relatively easy. Just a simple swap. Does anyone have any links on how to do this installation or any tips that may be useful? Any help would be very much appreciated. I don't want to get burned with the labor costs when I'm a poor college student anyway
rallyshark is offline   Reply With Quote
Old 02-09-2004, 06:03 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
i would just do the install yourself. its easy. just unplug the old one, and bolt up the new one. if you are replacing the #1 wire, i would just replace them all, if one is bad, the other ones are not far behind.
Shane
PARANOID56 is online now   Reply With Quote
Old 02-09-2004, 06:09 PM   #3
rallyshark
Member#: 44813
2008 2.5i 5-Door
Dark Gray Metallic
Thanks for the help. Has anybody else done this work also? By the way, I wrote my post very poorly...to clarify, (misfire on cylinder 1) it is just the wires and the coil pack that need to be replaced
Old 02-09-2004, 07:29 PM   #4
PARANOID56
Member#: 22035
2003 Brocoma DCab
its very easy. just unbolt the 4 12mm bolts that nold it on, unplug the plug wires, (keep track of which wire gos were) and unplug the plug on the side of the coil. remove it, and install the new one, and plug it back in, now, remove one plug wire at a time, and replace them. that way you have only one wire unpluged at a time, so you can keep track of it.
then sit back and watch porn.
Shane
www.paranoidfabrications.com
Old 02-10-2004, 07:06 PM   #5
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Yes, very easy. Just as Shane describes (though I thought they were 10mm bolts, and I didn't watch porn afterwards; I went for a drive).
Don't be too afraid about accidentally mixing wires up; the coil towers correspond in location to the cylinders in the engine.
Put a little bit of silicone dielectric grease around the edges of the boots at each end of each wire; that'll help keep moisture out.
vrg3 is offline   Reply With Quote
WTB: Ignition Coil Pack and Walbro FP lowell787 Private 'Wanted' Classifieds 3 09-12-2007 10:27 PM
Wtb Wrx Coil Pack / Engine Wiring Subaru Junkie Private 'Wanted' Classifieds 6 11-18-2006 09:56 PM
Coil Packs and hard starting? freemason Service & Maintenance 3 11-26-2005 07:27 AM
Need Coil Pack and Spark Plug Wires! CrazyMike13 South East Region Forum 1 02-05-2005 02:48 AM
need coil pack and spark plug wires redchris_2020 Southern California Impreza Club Forum -- SCIC 2 02-03-2005 03:33 PM
