Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 02-18-2004, 04:51 PM   #26
PolTec Inc
Vendor
Vendor Sales Rating: (2)
Member#: 41768
great parts that came from Mcmaster
Actually, if we bought the parts there we would hardly make any money (buying larger quantities helps a little), especially after you add up all the hardware and custom spacers required (the picture does not the full assembly). Not to mention the time one would need to spend researching.
Now, getting back to business.
For those that placed the orders yesterday, thank you, the parts will ship today.
Dariusz
PolTec Inc is offline
Old 02-18-2004, 07:37 PM   #27
Nivek-CA
Member#: 41415
Poltec, how do your rear end links differ from the aftermarket STI links that come with the six piece rear kit?
What kind of handling difference is there?
If I do not compete, is this a wise investment in handling?
Nivek-CA is offline
Old 02-18-2004, 07:47 PM   #28
supermarkus
Member Sales Rating: (13)
Member#: 6971
2008 WRX STi
SSM
When I looked up the parts on McMaster's site (page 1048), the high capacity SS metric ones ran about 34 bucks per piece, so for two complete links it worked out to over $120 I haven't found a high quality alternative to these yet. After about 3 hours of research, this seems like a decent deal for the links.
supermarkus is offline
Old 02-18-2004, 08:11 PM   #29
PolTec Inc
Vendor
Member#: 41768
Are you referring to the pink STi control arm kit? If so, our links for the USDM STi will not be suitable for this application since the links for the pink set are much longer. However, we just did a prototype replacement for one of the members of this board and if everything works out we may start offering those as well.
With that said, the stock links are quite good but our links offer about twice the load carrying capacity and you can adjust their length to eliminate away bar preload.
Dariusz
PolTec Inc
Old 02-19-2004, 01:49 AM   #30
Nivek-CA
Member#: 41415
This is the setup on my car currently any thoughts?
Nivek-CA is offline
Old 02-19-2004, 06:28 AM   #31
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
Is that a stabi bar from an 04? The angle is screwed up... look at that and ask yourself how that can possibly offer any roll control. Either that or the stock suspension has a lot of droop in it... Maybe I'm just used to seeing mine that takes about one pump to get the tires in the air.
ellisnc is offline
Old 02-19-2004, 08:49 AM   #32
PolTec Inc
Vendor
Member#: 41768
Nivek-CA
This is the set up that I mentioned, OvRclockR should receive the first prototype today, and if everything works out, we will start selling it in March. I do have one more prototype ready; send me an email if you want it.
Regarding the box, we also plan on selling it starting in March, it would be made from billet aluminum.
Dariusz
Old 02-19-2004, 10:55 AM   #33
Nivek-CA
Member#: 41415
Ok I am a bit confused, but this picture was taken while the car was in the air. Does that change anything?
Poltect PM'd you.
Nivek-CA is offline
Old 02-19-2004, 12:27 PM   #34
OvRclockR
Member#: 20671
2002 Wrx sedan
I'll post pictures with the prototype installed this weekend.
Nivek-CA, Your rear sway bar has a wierd downward angle. Especially for 22mm setting. I believe the ends of the sway bar are suppose to be parrallel to the floor. Anybody have something to say about this?
OvRclockR is offline
Old 02-19-2004, 12:36 PM   #35
Nivek-CA
Member#: 41415
Yes, anybody???
I will also try to get a pic of it while on the ground to see how much the angle has changed.
Nivek-CA is offline
Old 02-19-2004, 12:38 PM   #36
Bolster
Member Sales Rating: (26)
Member#: 22290
2002 WRB WRX Wagon
If it's off the ground, then it should appear as it does in that picture.
Bolster is offline
Old 02-19-2004, 01:09 PM   #37
OvRclockR
Member#: 20671
2002 Wrx sedan
I thought the official way io install sway bars is to install it with the car on the ground on a flat surface.
With the car on the ground. You have to get dirty and lay on the ground.
-Albert
Old 02-21-2004, 04:16 PM   #38
PolTec Inc
Vendor
Member#: 41768
TTT
Old 02-21-2004, 04:30 PM   #39
Nivek-CA
Member#: 41415
Dariusz
PolTec Inc
Any word about the prototype...fitting
Nivek-CA is offline
Old 02-22-2004, 06:24 AM   #40
red04
Member#: 42919
2004 wrx
san remo red
how much for fronts and non-adjustable rears together? thanks
-Adam
red04 is offline
Old 02-23-2004, 06:35 PM   #41
PolTec Inc
Vendor
Member#: 41768
Adam,
I sent you an email.
Albert has reported some clunking from bottom side of the link (apparently something is loose). I just shipped him a new prototype that should adress the issue (it uses different bushings). It looks like it will be another couple of days before we find out.
Dariusz
Old 02-24-2004, 05:06 PM   #42
PolTec Inc
Vendor
Member#: 41768
bump
Old 02-25-2004, 04:27 PM   #43
PolTec Inc
Vendor
Member#: 41768
I have an update for those that want end links for the STi V8 controll arm set (see picture below).
OvRclockR has reported that the second set of prototypes does not have any clunking so far and is working as intended. He has also made a few sugestions about the links that we will incorporate in our final design. For those that would be interested in purchasing those links, they will be available by the end of the next week and we will have a promotion for the firs 5 customers. Contact us for pictures or if you would like to pre-order them.
Just to clarify, this will not include the pink "box" that the links mount to, the box should be available by March 15-th.
Old 02-25-2004, 08:21 PM   #44
ellisnc
Member#: 4229
2003 S2000
Poltec,
Could you PM me... I'd like a set of the front links and rear links for the STi 6 piece set. I'd be willing to test fit some for you and give feed back as I'll be corner weighting my car in a couple weeks myself and be at the track the first weekend in April.
Nivtek, it looks like you're using a mismatch of parts or something. Like the pink links you're using are from a 03 and the stabi bar is from a 04.
Take a picture of the car on the ground under compression and that'll be the only way to know since I'm used to the reduced droop of my suspension. The stabi end-parts don't have to be parallel to the ground but the closer they are to being parallel with the endlinks the more the system will bind up when it moves around.
ellisnc is offline
Old 02-26-2004, 04:06 PM   #45
PolTec Inc
Vendor
Member#: 41768
ellisnc
I have sent you an email, let me know if you got it.
Old 02-27-2004, 03:04 PM   #46
PolTec Inc
Vendor
Member#: 41768
ttt
Old 02-27-2004, 03:23 PM   #47
nhluhr
John Wayne Toilet Paper
Member Sales Rating: (22)
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
how about the pics of the prototype "box" adapter for the 6-piece STi Sport Lateral Link Kit owners.
nhluhr is offline
Old 02-28-2004, 12:01 PM   #48
spankaveli
Member Sales Rating: (4)
Member#: 42826
1999 Toyota Corolla
Tan
spankaveli is offline
Old 02-28-2004, 01:45 PM   #49
PolTec Inc
Vendor
Member#: 41768
All of our products include hardware with extras in case you happen to lose something.
Old 02-28-2004, 01:50 PM   #50
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
awesome, ill be ordering tuesday
Closed Thread
stock end links with new sways?? Speedster329 Newbies & FAQs 7 11-07-2009 03:44 AM
Replacing busings with Spherical Bearing? advanracing62 Brakes, Steering & Suspension 4 12-20-2005 03:27 PM
NEW! Whiteline Alloy Rear End Link Kits - ONLY 2 Sets in stock! AllSubaru.com Vendor 'For Sale' Classifieds 11 09-02-2003 02:29 PM
