Old 02-10-2004, 08:20 PM   #1
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Thumbs down Dont buy Noltec Steering Rack bushings
Just wanted to say that I was helping a club member install some Noltec "blue" steering rack bushings on his 02 WRX saturday.
Let me mention before hand that ive done about 10-15 of these installs, all with whiteline bushings. NEVER have I had any difficulty with the actuall bushings until I saw these pieces of junk...
The driver side bushing was about 5mm too wide, which meant that it WOULD NOT fit around the steering rack OR rotate into position. It just got stuck, and folded over.
Not only that, but the material quality was crap. There were bubble defects in the eurathane everywhere on both bushings, and the bushings actually were RIPPING under any stress from trying to install them... Total junk I tell you
Anyway, ive never had any of these problems with the Whiteline bushings, so just stick with those folks. Ive never once seen any visual defects with whiteline bushings (exept for one that somone forgot to cut, but that was easily fixable! ) and the only fitament issue ive had with those was that whiteline seems to insist that the KSR200 model works on some USDM Subarus when in fact it does not. (Just get the KSR202)
Ill see if I can get the pics of the bushings to post here soon too so you guys can see for yourself.
Old 02-10-2004, 10:05 PM   #3
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
wow. glad i got the whitelines...
nhluhr is offline   Reply With Quote
Old 02-10-2004, 10:12 PM   #4
Bolster
Member#: 22290
2002 WRB WRX Wagon
me too
Bolster is offline   Reply With Quote
Old 02-10-2004, 10:22 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
OK....I have a package of the Noltec steering rack bushings, P/N N12247, right here in my hand that I just opened.
I've had these for about 6 months or so.
They seem well made and although they do have a some small surface bubbles along some edges, they are well within what would be considered normal for this type of part. Inspection using a bright light reveals uniform material composition and thickness. Pulling and twisting each bushing reveals no apparent weakness or any defect. They are unremarkable in any other way.
They do seem to be a bit firmer material than the Whiteline bushings I've installed. I have not installed the Noltec bushings.
Kostamojen may have received a defective set of bushings.
I would not hesitate to install the bushings I have.
My 2
Old 02-10-2004, 10:41 PM   #6
oldmansan
Member#: 17877
Midnight Pearl
Default I helped a friend
install his Noltec steering bushings in his STI. No problems. I bought the Whitelines, but I have Noltec front sway bar links and their customer service is outstanding. Send them an email, they won't disappoint.
San
oldmansan is offline   Reply With Quote
Old 02-11-2004, 12:58 AM   #7
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
They werent my bushings, I was doing the install, and just venting about it.
As far as the parts review, whoops! should have posted this there in the first place, completely forgot about it (mostly cause i never go there)
Old 02-11-2004, 01:01 AM   #8
oldmansan
Member#: 17877
Midnight Pearl
Default Sure they where
the right ones? I compared the Noltec to my Whiteline and the Whiteline were a bit stiffer, but that looked to be the only difference.
San
Old 02-11-2004, 01:54 AM   #9
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
You must have gotten a bad set, I installed a set of Noltec bushings without any problems, they fit perfectly on my wagon. Love the steering feel now!
drees is offline   Reply With Quote
Old 02-11-2004, 02:48 AM   #10
oldmansan
Member#: 17877
Midnight Pearl
Default A couple of things,
you've done 10 - 15 installs of steering rack bushings = you're quite knowledgable about how to do this. All of your installs have been with Whiteline, and you know their correct part number. Two of us have installed the Noltec steering bushings with no problems. I've got to think maybe the part wasn't the right one, or a bad set of bushings (I would think latter very unlikely). Either way, I've noticed lately some thread titles that have been pretty strong (accusatory). The one that comes to mind is BEWARE OF CARBOTECH, which was totally groundless. Not saying this one isn't valid, but my experience with Noltec has been nothing but good. Do you know the part number of the bushings you installed?
San
Old 02-11-2004, 03:03 AM   #11
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Im certain as to that they were at least bad bushings. The width of the driver side bushing is NOT different between any model years, so I dont know what the heck could have happened but it happened...
I wouldnt have posted this if say, the Noltecs were cheaper or I thought there was some justification for not posting it, but there isnt. So I posted it.
Old 02-11-2004, 03:43 AM   #12
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Did you talk to noltec about it? I know the endlinks I have from them are absolutely top notch.
mr2guru is offline   Reply With Quote
Old 02-11-2004, 03:45 AM   #13
oldmansan
Member#: 17877
Midnight Pearl
Default I have to bow
to your experience in this area (at least) as one set of steering rack bushings is all I've had the displeasure to install. Just trying to cover all the bases. You posted what you experienced, rightly so. I just wanted to make sure there wasn't a difference in the parts you installed, and the ones I and drees did.
San (rookie steering bushing installer)
Old 02-11-2004, 07:26 AM   #14
Safir
Member#: 3873
. Paradise is
like Disney with hookers
My question is, did you, at any time, contact noltec or the retailer the bushings were purchased from about this, or did you just come on the baord here and say "noltec steering bushings are crap"
it is very possible that you got the wrong bushings. a bushing for a mustang or something probably fell in teh bin of "WRX" bushings.
Safir is offline   Reply With Quote
Old 02-11-2004, 09:50 AM   #15
Egan
Member#: 12670
01 M Coupe,
05 Legacy GT, 05 Titan
First off, Kosta didn't buy them so it's not his place to call Noltec. I think he was trying to put out a warning for anyone else that buys these that there is a potential problem and they should double check before tearing their car apart. The passenger side was fine, only the driver's side was the issue.
These weren't mine either as I have the Whitelines, but we were doing the install at my house. As you can see there is an obvious width problem. The picture compares, from left to right, Whiteline to stock to Noltec. Do what you will with the information, I am merely providing pictures of the issue we had. It may be a one off error:
Egan is offline   Reply With Quote
Old 02-11-2004, 09:54 AM   #16
Egan
Member#: 12670
01 M Coupe,
Originally posted by Egan
...I think he was trying to put out a warning for anyone else that buys these that there is a potential problem and they should double check before tearing their car apart. ...
Okay, reading the title again I may be wrong.
Old 02-11-2004, 12:08 PM   #17
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
my noltecs went in without an extraordinary amount of fuss.
i mean, the job itself is a pita, but it wasn't made any worse by the noltecs!
jm2c
ken
Old 02-11-2004, 12:39 PM   #18
drees
Member#: 25905
2003 Silver Wagon
Yeah, something's definitely screwy there.
Old 02-11-2004, 03:54 PM   #19
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
jm2c
ken
Naw, the job is easy after the 2nd or 3rd time Im sure this was probably a bad batch of bushings, or at least someone putting the wrong bushing in the wrong bag...
Old 02-11-2004, 04:13 PM   #20
Uncle Scotty
Member#: 16200
OK buy Nates beans
Might have been an after 3 beer lunch for the bag stuffer....
Old 02-11-2004, 04:24 PM   #21
Egan
Member#: 12670
01 M Coupe,
Kind of like those Subies built on Fridays!
Old 02-11-2004, 07:38 PM   #22
WheelsCSM
Member#: 20765
2008 Forester XT
6mt/18g-xt
I just put some Noltec bushings on, and it did seem like the driver's side was a little too wide. I was still able to get it on, and it seems to be working fine. They did have a few small bubbles in the Urethane, but nothing I'm worried about.
WheelsCSM is offline   Reply With Quote
Old 02-11-2004, 07:41 PM   #23
Uncle Scotty
Member#: 16200
OK buy Nates beans
Only those built in Indiana
Old 02-11-2004, 07:49 PM   #24
BIGSKYWRX
Member#: 7958
09 GH B+
Noltecs on, may have been a smidge wide but I don't remember (too long ago)- didn't notice bubbles.
The pic (w/ the whitelines, oem, noltec) above should be sent to Noltec, they may be oblivious to the fact that their's may be too wide.
Big Sky
Old 02-12-2004, 01:31 AM   #25
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Oh and ya, Carbotechs do suck
FS: Noltec steering rack bushings Panic Suspension/Brakes/Handling 0 09-15-2009 09:59 PM
Noltec Steering Rack Bushings drees Car Part Reviews 2 10-23-2008 05:19 PM
FS: Noltec steering rack bushings - $20 shipped Hank3 Private 'For Sale' Classifieds 19 11-20-2004 11:43 AM
Noltec steering rack bushings Hank3 Transmission (AT/MT) & Driveline 0 11-02-2004 11:29 AM
comfort ALK and noltec steering rack bushings installed slater Brakes, Steering & Suspension 16 04-23-2003 12:19 AM
