Old 02-10-2004, 10:18 PM   #1
RIP_2my_GC8
Member#: 52287
2002 WRX Wagon
World Rally Blue
Default Weird Cel Code!!!
ok heres the situation, my up pipe/downpipe were stock prior to this particular CEL, then i installed the PDE catless up pipe and PDE catless down pipe and i get a CEL. i scan it with my OBDII scanner and i get 2 codes of the exact same DTC: P1311 Manufacturer. Fuel/Air Metering (2 codes of this, identical) so i erase it, i put the resister back in the EGT probe(which i took out when i was doing the up pipe) and i start my car up again and back it comes. i have absolutely no idea what this is and its annoying as hell. please help me before i go insane!!
RIP_2my_GC8 is offline   Reply With Quote
Old 02-10-2004, 10:33 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
It's not your EGT sensor, it's your air/fuel sensor causing the code.
Brian
Old 02-10-2004, 10:34 PM   #3
RIP_2my_GC8
Member#: 52287
2002 WRX Wagon
World Rally Blue
i.e. mass airflow sensor?
Old 02-10-2004, 10:43 PM   #4
RIP_2my_GC8
Member#: 52287
2002 WRX Wagon
World Rally Blue
why would it throw this code right after i install my up/down pipes since i havent changed the intake? and what do i do about this code?
Old 02-10-2004, 10:44 PM   #5
vile
Member#: 32371
'02 t-rex wagon
platinum
hmmm, i can't find that code for the '02 wrx in the service manuel
vile is offline   Reply With Quote
Old 02-10-2004, 10:48 PM   #6
RIP_2my_GC8
Member#: 52287
2002 WRX Wagon
World Rally Blue
it shows up on my OBDII scanner, i couldnt find it either thats why it seems so odd.
Old 02-11-2004, 12:53 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
You may have borked a wire somewhere....
Old 02-11-2004, 04:05 AM   #8
RIP_2my_GC8
Member#: 52287
2002 WRX Wagon
World Rally Blue
ok guys, im now convinced that im dyslexic. i just ran the code again and i again read it as 1311 but my dad goes "heh no that says 1131" damn i feel dumb :-( ok so now that i know its 1131 "manufacturer control, fuel air metering) can someone explain that to me?
Old 02-11-2004, 04:15 AM   #9
supermarkus
Member#: 6971
2008 WRX STi
SSM
how did you install your up-pipe? Did you remove the turbo and pull it out through the top? Also, check your front O2 sensor for broken wires.
P1131 Front oxygen sensor circuit malfunction (short circuit)
I believe the DTCs in the 1000 range are manufacturer specific, so a generic obd2 scanner may not give the right diagnosis with the number.
supermarkus is offline   Reply With Quote
Old 02-11-2004, 04:17 AM   #10
RIP_2my_GC8
Member#: 52287
2002 WRX Wagon
World Rally Blue
i removed the passenger side exhaust manifold, then i jacked up the motor slightly and pulled the old up-pipe out the bottom then installed the aftermarket up pipe the same way. i havent had time to check it yet since ive been busy with school and work, im going to try to check it tomorrow night, is it ok to drive it for now? would that also explain why my car smells godawful even though its not running cats i dont think its supposed to be this bad, it smells like a diesel dump truck.
Old 02-11-2004, 04:23 AM   #11
supermarkus
Member#: 6971
2008 WRX STi
SSM
Um. If you have no cats, your exhaust will stink, there's no avoiding that. What do you think the cats are there for?
It sounds like you hosed your front O2 sensor during the installation. $135 bucks for a new one or something like that.
Old 02-11-2004, 05:07 AM   #12
RIP_2my_GC8
Member#: 52287
2002 WRX Wagon
World Rally Blue
135 bucks?!?! ah fuk, can i use the o2 sensor from an impreza 2.5RS? ive got 2 of them lying around :-D
Old 02-11-2004, 05:21 AM   #13
supermarkus
Member#: 6971
2008 WRX STi
SSM
Go to subaruparts.com and look up the part numbers.
Old 02-11-2004, 10:18 AM   #14
vile
Member#: 32371
'02 t-rex wagon
platinum
p/n - 22641AA042
152 on subaruparts.com.....since you took off the passenger side manifold, chances are, you either unplugged the o2 or removed it from the manifold....double check you're connection before buying a new one......das where the front o2 is located, tapped in on the pass. mani.
Old 02-11-2004, 10:24 AM   #15
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
No, air fuel sensor. It's either the one in your collector or the O2 sensor in your cat. My bet is the one in the collector though.
Brian
Old 02-11-2004, 06:32 PM   #16
RIP_2my_GC8
Member#: 52287
2002 WRX Wagon
World Rally Blue
cant be the one in the cat cause lol i dont have any cats, plus according to the thread on here about CELs 1131 is front o2 sensor short circuit so hopefully if its not fried all the way i can repair it and use some high-temp sheathing over it if not i guess its a new o2 sensor unless someones parting out a car :-P
STG2: Flashing CEL but no CEL code mvitic AccessPort 1 08-10-2006 09:43 PM
Weird result pulling CEL code from AccessPort? STiMUL8 Engine Management & Tuning 6 04-14-2006 01:29 PM
HELP: where can I borrow a CEL code reader or get the code pulled for free? anonymous_wolf Vancouver Impreza Club Forum -- VIC 5 08-11-2005 01:40 AM
Road tuned: CEL codes and weird engine noise Mr. Bungle Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-06-2005 04:15 PM
really weird trouble code! baldcherub Normally Aspirated Powertrain 1 06-25-2002 12:29 PM
