Old 02-10-2004, 11:47 PM   #1
brunetmj
Member#: 8023
2004 2.5 RS
Default High Beam Low Beam Project
I am working on a project that involves the use of the High and Low Beam wires inside the car using a relay. Is the following wired correctly in that Light2 A would Light with the Low beams switched on and then go off as light1 B goes on with the High beam switched on?
brunetmj is offline   Reply With Quote
Old 02-11-2004, 12:25 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes, as long as the 12V to terminal 30 is the headlight switched power, so that the connected lights don't come on unless the headlights are on. Also if this is for the STi I'm not sure what the low beam switching situation is because of the HIDs, but I know you have the wiring diagram.
Old 02-11-2004, 05:18 AM   #3
brunetmj
Member#: 8023
2004 2.5 RS
Mulder, thanks as always. I am a little confused though. If I had any 12 volt source at pin 30 and turning on the switch it would still light the light won’t it? It would just mean the little bulb would light before the headlamps were on because there are other positions on the switch before it? Yes I will be sure to test the voltage on any wires I use. I think I will be ok as long as I catch the wires before the relays and voltage changes.
morettes: when i turn off high beams low beams flicker Impreza2003 Electrical & Lighting 3 08-06-2005 08:47 PM
projector headlights high beam low beam ptsmalls Electrical & Lighting 3 03-14-2004 11:22 PM
High Beam/Low Beam Jfloyd Electrical & Lighting 0 09-12-2003 11:51 PM
High beams, low beams, & fogs at the same time il96 Electrical & Lighting 0 03-10-2003 10:08 AM
JDM headlight high beam/low beam BlueWRXagon Interior & Exterior Modification 20 11-05-2002 10:37 AM
