Old 02-11-2004, 02:44 AM   #1
njpreppy
Member#: 47451
Default 278 / 292tq without broken gears!
Suspension:
Tanabe Pro Sustec-SS Coilovers
Tanabe Rear Pillow Ball Strut Mounts
STI Front Upper Strut Mounts
Cusco Rear Sway Bar
Rota 17" Gold SDR
225/45/17 ContiSport Contact
Performance:
EcuTek
Perrin Pulley
Forge Dump Valve
Turboxs Stealth-Back (Downpipe, Midpipe, Hi-Flow Cat)
Prodrive Axel Back Exhaust
Helix Flex Uppipe
Gruppe-S Manifold
Perrin Short Ram Intake
One Step Colder NGK Platinum Spark Plugs
Walbro Fuel Pump
STI Injectors 550cc
VF22
Perrin Fuel Rails
Perrin Front Mount Intercooler
Goodridge Stainless Lines
Bobcat Front and Rear Pads
Monkey Fart version 8.3 j/k
Other
STI Fog Covers
Apexi Turbo Timer w/ Blitz Harness
Corbeau 5 point harnesses
Newly installed PA system / noisemaker
Ecutec'd by Rallispec at 278whp 292tq at 17psi
I will never drag this car for fear of losing the gears (I do not have the money to replace them). But, I'd imagine it would run somewhere around a 12.7-8 Hang out at Rallispec enough and you'll learn how many people actually need/get new gears.
Painted my front IC bars only but not plates. As you can see the rocks love to chip away at it.
I couldn't figure out how to make pictures available here so here's a link: http://home.gwu.edu/~fed/scoob/
njpreppy is offline   Reply With Quote
Old 02-11-2004, 03:01 AM   #2
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
Thumbs up
Nice results. Good luck with it.
Your smart on the gearbox comments (I'm on set #2 at near stock power)
~v6
V6TurboTA is offline   Reply With Quote
Old 02-11-2004, 03:13 AM   #3
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
Looks like a good setup. Nice numbers. If you donít abuse your transmission, I donít see it failing prematurely. I haven't heard of someone who broke theirs without driver error/abuse. I used to go to the drag strip every week. Never a problem, 70000 miles strong.
-Mike
MJU1983 is offline   Reply With Quote
Old 02-11-2004, 05:08 AM   #4
Big Turkey
Member#: 32118
-Mike
Wrd.
I made 346hp/360trq on my VF30, on the stock tranny. It's still holding up. I've gone to the drag strip maybe 4-5 times since, and made 20+ passes. I go out twice a week to go street race with those domestics. I usually go from a roll, 20mph, 50mph whichever. It's still a damn champ. If you don't abuse it, and as long as you're on the stock clutch or a clutch that allows a good amount of slippage, I think it's enough to save your tranny.
Big Turkey is offline   Reply With Quote
Old 02-11-2004, 08:14 AM   #5
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
That's nuts! It's not often you see a Suby makin more torque than it is whp on the dyno! Congrats on the setup.
Looks like your FMIC has seen better days though
jigga is offline   Reply With Quote
Old 02-11-2004, 09:39 AM   #6
wRxbeater11
Member#: 12682
Got any dyno sheet to post? I wanna see how it looks.
wRxbeater11 is offline   Reply With Quote
Old 02-11-2004, 11:53 AM   #7
M32WRXin3seconds
Member#: 36797
exactly why my gear box will last a long time....not dumped or abused
M32WRXin3seconds is offline   Reply With Quote
Old 02-11-2004, 11:56 AM   #8
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Good numbers.
I have. Plenty of people.
TypeC is offline   Reply With Quote
Old 02-11-2004, 12:28 PM   #9
njpreppy
Member#: 47451
Default dyno
Hey thanks for all the comments everyone. Someone asked for my dyno plot. Those figures are actually from the Ecutek road dyno, which from my understanding is incredibly accurate. I did not receive a dyno plot from it. I'm not even sure that there is one but I might be misunderstood.
A couple of cool figures I got from the print out are:
Terminal velocity due to power: 178.9mph
In Gear Acceleration:
40-60 2.7s
50-70 2.3s
60-80 2.5s
279.2 bhp @ 5692 RPM
293.2 tq @ 4661 RPM
Power to weight ratio: 180.1 BHP per ton
Dave at Rallispec calculated this with:
total vehicle mass: 1550 kg
Drag Co-efficient: .37
Tire setup at the time: 205/55/16 (stock)
Engine Rev Limit: 7100
Test Gear: 3
Max Speed of Gear 99mph
Air intake temp: 75 F
Atmosph. Pressure: 1.02 bar
Not quite sure where he came up with some of those figures. Someone asked about my FMIC not seeing better days: it's actually only a month old Road salt in NY...
A friend of mine put my numbers into a program called Car Test and got these figures:
Shift Points for maximum accel:
1st 6850 rpm @ 38mph
2nd 6290 @ 62mph
3rd 6310 @ 89
4th 6080 @ 122
Start rpm: 3000 with clutch drop
I raced my brother's 350z, he only has pop-charger intake... I dropped from 3,000 off the line and the rev's went straight down to 1,000 then started. Either my clutch was heated up or it flat out slipped. I take him every time from a roll though, but not by much. We'll see who is in whose rear view mirror at VIR in 20 days
Old 02-11-2004, 12:50 PM   #10
S-1
Member#: 10842
07 2.5i Wagon
so your car was dyno'd in 3rd gear?
S-1 is offline   Reply With Quote
Old 02-11-2004, 01:28 PM   #11
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
do you have any info on the car test program. i'd like to see something that would plot optimal shift points.
rjrutzky is offline   Reply With Quote
Old 02-11-2004, 01:53 PM   #12
njpreppy
Member#: 47451
Default car test program
http://www.cartestsoftware.com/cartest4.5/index.html -- you have to dial in all of your car's specifications
Old 02-11-2004, 04:27 PM   #13
SleeperWRX
Member#: 8179
i hope your tranny doesn't blow...but that's enough power to toast it by just hitting the gas while in a gear. I've seen it happen to 2 friends with vf22's. One in 3rd gear and one in 4th. Start saving just in case.
SleeperWRX is offline   Reply With Quote
Old 02-11-2004, 10:16 PM   #14
bhkim126
Member#: 27142
I just made 283 whp and 244 ft/lbs last Saturday on a stg. 4 with VF-22. I also have the same fear of breaking my tranny. But its holding up. I also noticed you're making more torque than I am
EDIT: heres a scan of my graph.
bhkim126 is offline   Reply With Quote
Old 02-11-2004, 11:05 PM   #15
njpreppy
Member#: 47451
That tq number is really low. Who did your tuning and what kind of ecu? What mods do you have?
Old 02-11-2004, 11:44 PM   #16
bhkim126
Member#: 27142
Tuning was all done on a UTEC by very reputable tuners, PDXTuning. Mods are:
(catless)
VF22
Blitz FMIC w/ HKS SSQV
Blitz boost controller
Blitz catback exhaust
Perrin uppipe
3" downpipe
STi injectors
Walbro fuel pump
AEM short intake
Perrin crank pulley
Old 02-11-2004, 11:48 PM   #17
njpreppy
Member#: 47451
Headers might help that torque out...
Old 02-12-2004, 07:34 AM   #18
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
not really.
from dynos ive seen w/ headers u lose (peak) torque.
hey bhkim, on what psi was this for ur VF 22?
stickman is offline   Reply With Quote
Old 02-12-2004, 07:50 AM   #19
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
here is my dyno on 93 pump @16psi
VF34
JDM STi IC
STi inj
FP
TXS stealthback
STi axle back
unichip
up pipe
stock intake, stock air box, stock exhaust mani
Old 02-12-2004, 01:46 PM   #20
bhkim126
Member#: 27142
21 psi
Old 02-12-2004, 02:03 PM   #21
njpreppy
Member#: 47451
21 PSI!!!!!!!! That's nuts! I'm only at 17psi with my vf22...something doesn't seem right...what do I have that is so different than you?
Old 02-12-2004, 02:19 PM   #22
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
hey njpreppy,
can u post ur dyno graph pls?
thanks.
Old 02-12-2004, 03:35 PM   #23
CMJ
Member#: 39235
You guys keep asking what dyno and for a dyno plot...He got those figures from the ECUtek road dyno feature not a real dyno.
CMJ is offline   Reply With Quote
Old 02-12-2004, 05:04 PM   #24
njpreppy
Member#: 47451
exactly
Old 02-12-2004, 07:32 PM   #25
quickscooby
Member#: 39415
STI [email protected]
479/492 @ 30psi GT30R .82
Originally posted by Big Turkey
Wrd.
Exactly........i was gonna say if you're still on the stock clutch that's why they haven't broken.
That's good tq...i put down 293lbs but with 306hp. Wonder why your tq is high but your hp is lower?
quickscooby is offline   Reply With Quote
2002 WRX. 2 broken gears in a month and a half? peeledback7777 Transmission (AT/MT) & Driveline 14 10-19-2006 11:14 AM
help with a broken gear matt6669 Transmission (AT/MT) & Driveline 6 05-27-2005 09:30 PM
Figured out a way to make life better without first gear syncrhos! Roy Lin Transmission (AT/MT) & Driveline 3 07-31-2004 07:26 AM
Ok Broken Gears Now What TexasFIAWRC Transmission (AT/MT) & Driveline 32 07-01-2003 02:03 PM
Broken gear (picture) WRXGuyInUSA Transmission (AT/MT) & Driveline 16 01-19-2003 11:36 PM
