Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 02-11-2004, 04:03 AM   #1
STI808
Member#: 39060
2004 STI
Java Black
Default pros and cons for electric exhaust cutout?
anyone have experience us electric exhaust cutout? any problem? any idea where should I install it downpipe or mid pipe?
STI808 is offline   Reply With Quote
Old 02-11-2004, 04:37 AM   #2
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Here ya go...search is your friend....
http://forums.nasioc.com/forums/show...hreadid=493213
mr2guru is offline   Reply With Quote
Old 02-11-2004, 06:39 AM   #3
Big Turkey
Member#: 32118
Pros: It's the ultimate sleeper. It sounds badass when you're opening it or closing it. It's super loud then all of a sudden it's quiet. Let you have a stock sound when you're cruising with a hot chick in the passenger's seat.
Cons: It leaks when it's closed so it sounds like you have a good sized exhaust leak.
Big Turkey is offline   Reply With Quote
Old 02-11-2004, 10:01 AM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
also, if the rest of your exhaust is stock (ie. moderately restrictive) then switching back and forth often may "confuse" the ecu. for example, the first time i took off my oem muffler, the car didn't really start responding to the lower backpressure until i did about a day's worth of driving... then it definitely came alive.
it's not like it will do any damage, but you probably won't be able to open the cutout and immediately reap ALL the benefits (at least not without an ecu reset and a shiv iam trick).
jm2c
ken
Old 02-11-2004, 11:55 AM   #5
Billy_H
Member#: 34047
02 WRX
The only real down sides I could see would be if you place it before your rear o2 sensor and don't run a resistor. You'd run the risk of throwing a check engine light when the cutout was open. Also, if the cutout were to start leaking then that would suck as well. The cutout I bought and compared to others on the market looks to be much better manufactured and doesn't leak as of yet. I've also talked with a few guys running the same cut out for close to 3+ years and they have had no problems with operation or leaking.
Billy_H is offline   Reply With Quote
Old 02-11-2004, 12:40 PM   #6
mixup52
Member#: 39691
2002 WRX Wagon
D-I-Z-Z-L-E, has a short clip of his car with his cut out. It's pretty cool. PM him and I am sure he will send it your way!
mixup52 is offline   Reply With Quote
Old 02-11-2004, 01:15 PM   #7
2002 Red VF22
Member#: 53694
WRX - VF22, 3" TB
MBC, Catless, I/C Hoses
Cool
With my vf22 and MBC, It surprised me to see it jump 2 psi in boost when I unhooked the catback for a test run.
With the stock ECU, it hit the fuel cut and gave me a CEL.
So if you were to use a cutout, you would have to have an EBC.
2002 Red VF22 is offline   Reply With Quote
Old 02-11-2004, 01:53 PM   #8
jsmonet
Member#: 14190
2005 STi
white
a chronic problem i saw on other boards was that the servos didn't really hold up to the normal abuse of daily driving. kind of an expensive part for it to not last very long.
although you don't hear about the "mine's lasted me 100k miles in perfect shape" cases nearly as often, now do you?
jsmonet is offline   Reply With Quote
Old 02-11-2004, 04:07 PM   #9
Big Turkey
Member#: 32118
Which company did you purchase yours from?
Old 02-11-2004, 04:15 PM   #10
WRX Jim
Member#: 22321
Mine lasted a about 8 months before it met a raised manhole cover ..
then it ran open full time for another 5 months...
my ears hurt so i got a RFL and nwo i love it.
WRX Jim is offline   Reply With Quote
Old 02-11-2004, 09:43 PM   #11
500hpwrxsti
Member#: 22459
2002 WRX GT40R
700AWHP but whos counting
Electric cutouts are the ****!!!! I have one on my car and love it. One of my biggest sponsors, Quick Time Performance, is the provider of my cutout as well as the cutouts on several of the cars we put together at our shop! Go to the website, www.quicktimeperformance.com , or call and talk to Barry! You cant go wrong, this is an A+ product and it will scare the **** out of people when you open it at a stop light and rev on someone who just reved up on you!! Again, go to the website and see the sound clips that are available and check out Barrys' WRX!!!!
500hpwrxsti is offline   Reply With Quote
Old 02-11-2004, 10:01 PM   #12
dudical26
Member#: 37934
I have one and i love it. I think it works very well. The unit i have is from Quick Time Performance, it is their QTEC. It is a great product, well manufactured, and worth the price. Check out the link below
http://www.quicktimeperformance.com/downpipe.htm
http://208.254.222.235/QTEC/WRXVideo.wmv ---- video
dudical26 is offline   Reply With Quote
Old 02-12-2004, 09:38 AM   #13
Billy_H
Member#: 34047
02 WRX
DMH Performance
I hate saying bad things about companies online...but the QTech was the main other cutout I compared mine against. The DMH unit is MUCH better quality. Hell, my friends that have them on their F-Bodies are getting ready to pull their QTecks off and get the DMHs.
Old 02-12-2004, 10:39 AM   #14
Tex-WReX
Member#: 7107
2014 Mustang GT
DMH Performance
That almost looks too good to be under the car!
Tex-WReX is offline   Reply With Quote
Old 02-12-2004, 07:12 PM   #15
500hpwrxsti
Member#: 22459
2002 WRX GT40R
The dmh is more money and alot more bulky! Just my opinion
Old 02-12-2004, 08:55 PM   #16
camz911
Member#: 16041
'02 SCRAP METAL
ZERO whp.... :(
the one CON that I see is that when the cut-out is closed, there is just that open pocket. By that I mean there is a pipe section with no exit. That small section creats turbulence in the exhaust stream...so unless you're running this thing open all the time, I've gotta assume that you're losing a little bit of power...not alot, but a little bit...
BTW...it sounded AWESOME!!!!
camz911 is offline   Reply With Quote
Old 02-12-2004, 09:07 PM   #17
jefersun
Member#: 37716
2002 ej257 Black WRX
DO NOT BUY A CUT OUT
I bought a QuickTime Performance cutout, and the leak that it gave when closed was so annoying... it sounded horrible. Sounded like a constant hub hub hub, the sound of a beat up car. The best thing i suggest to you is, keep the stock muffler, and have the rest redone. Do it yourself, i did mine, and it's very quiet. I mean is it worth it, loudnoise all the time, or even a little hum all the time (subaru sound isnt all great unless you're opendownpipe, that sounds freaking mean as hell)? 5 hp at the best, o.k. to be on the conservative, actually ridiculous, 10 hp lesss? So what, exhaust isn't everything. 10 hp correlates to what, .1 off your quarter?
jefersun is offline   Reply With Quote
Old 02-12-2004, 09:22 PM   #18
replacement killer
Member#: 19368
2003 WRX
Anyone have any experience with the McCord power plate?
http://www.mccordcg.com/mpp/mpp.htm
replacement killer is offline   Reply With Quote
Old 02-12-2004, 10:12 PM   #19
batmanalan
Member#: 37583
tuning would be a chore
batmanalan is offline   Reply With Quote
Old 02-12-2004, 10:35 PM   #20
HighWayDrifter
Member#: 8908
2012 Ford Raptor
*yack* to cheap marketing posts
HighWayDrifter is offline   Reply With Quote
Old 02-13-2004, 01:30 AM   #21
ESTCOASTSUPORTER
Member#: 34254
2003 WRX
WHITE
QTP all the way to the track baby
ESTCOASTSUPORTER is offline   Reply With Quote
Old 02-13-2004, 04:30 AM   #22
Big Turkey
Member#: 32118
I have a few friends with the QTP and theirs have already broken on them. I run the McCord, which I bought used, and it's been going good for about 6 months. Yes, it does leak and it is very very annoying, but I hate the droning sound of an exhaust on the freeway. The only thing is that the cutout has seen many speed bumps.. so I believe it's on it's way out. It takes 8 seconds to open up now instead of the usual 4.. and it hesitates when I'm trying to open it.
Pros and cons for tmic or fmic Evo Killer Water/Methanol Injection, Nitrous & Intercooler Cooling 30 11-16-2009 02:55 PM
pros and cons for diff. trannys redrex2002 Transmission (AT/MT) & Driveline 13 05-01-2007 06:25 PM
pros and cons for electric exhaust cutout? STI808 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-11-2004 11:21 AM
Turbo back vs. cat back exhaust pros and cons xfactor834 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 08-07-2002 02:00 AM
Pros and Cons of 3" Exhaust Vs. 2.5" stimpy Normally Aspirated Powertrain 14 01-30-2001 10:50 PM
