#1 |
Member#: 16880
Vehicle:2003 WRX Wagon PSM |
I've been reading about the Koni Inserts and have gotten alot of positive feedback about the Koni/Prodrive spring combo.
My question is what is the deal with cutting stock struts? Is it just the perch that you take off stock and put it on the Koni? If someone could post a DIY Koni install or a link to how detailed the installation is that would be great. Thanks in advance! ~Watts
#2 |
Member#: 5291
Vehicle:'08 Scion xB Nautical Blue Metallic |
http://www.b15sentra.net/forums/show...t=koni+inserts
Should be about the same process, gives you a general idea on what's involved. |
#3 |
Member#: 16880
so basically the stock housing, perch and mount is used and the insert is just bolted into the empty stock housing?
That doesn't seem too hard. Thanks b_tapper Anyone else? |
#4 |
Member#: 5291
Yup that's the basic idea, I'm sure there's going to be some difference between a nissan and a subaru, but a strut is pretty much the same setup on any car.
| Thread Tools | |
| Display Modes | |
| TD05 18G 7cm2 turbo: who has one and how do they work out for you? | GDAryder | Factory 2.0L Turbo Powertrain | 29 | 09-22-2008 12:20 PM |
| Strut tower bars - How do they work? | Alan l. | Brakes, Steering & Suspension | 18 | 11-02-2006 03:02 PM |
| Bellagio garden water acs - how do they work? | Sausage | Off-Topic | 17 | 10-20-2006 01:53 PM |
| Fuses ? how do they work ? | Extraze | Electrical & Lighting | 3 | 04-12-2004 12:50 PM |
| Adjustable sway bars - how do they work? | tomrichardson | Brakes, Steering & Suspension | 5 | 05-03-2001 12:56 AM |
