Old 02-11-2004, 02:43 PM   #1
MITCHELL
Member#: 42924
04 STI
SILVER
Default STi turbo removal
Can anyone point me in the direction of a thread on removal instructions for the turbo and wastegate on a 04' STi. I want to send the turbo and wastegate to deadbolt for porting.
Thanks.
Mitch
MITCHELL is offline   Reply With Quote
Old 02-11-2004, 02:50 PM   #2
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
http://techinfo.subaru.com/html/index.jsp
$20.00 get as much detailed info as desired for taking the car apart and putting it back together.
(with ugly poorly drawn pictures to close to tell the location of half of them )
turboICE is offline   Reply With Quote
Old 02-12-2004, 12:37 PM   #3
MITCHELL
Member#: 42924
04 STI
SILVER
anyone who has done it and has suggestions?
Old 02-12-2004, 12:43 PM   #4
STFUTuning
Member#: 40729
2004 STi, EVO
AEM Factory Trained Tuner
Dude, just call me. I was goingto talk to you today anyways.
STFUTuning is offline   Reply With Quote
Old 02-12-2004, 12:58 PM   #5
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
Check scoobymods, it is not that bad I do them in about 2 hours ot my old man pace.
bikerboy is offline   Reply With Quote
Old 02-12-2004, 01:01 PM   #6
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
I have done it and that was my suggestion. I am continually amazed that people won't spend $20 for the factory service books on their $30k car that they want to wrench on themselves.
Old 02-12-2004, 01:30 PM   #7
carguy19
Member#: 48550
2004 ^^^whp ^^^wtq
remove IC and hoses from turbo....
remove heatshields
drop DP
remove bolts to up pipe
remove coolant lines
remove oil lines
remove vac hoses
remove turbo
it should only take about 1 1/2 hrs
If you are sending out the turbo to deadbolt all you have to send them is the exhaust side, its easier and less time consuming to remove.....
remove Heatshields
Drop DP
take out up pipe bolts
remove WG actuator arm from ex housing and remove vac hose.
remove band clamp that holds the turbo together
wiggle ex housing off
this will save you 45 min and is all that deadbolt does work to. So it doesnt pay to send the whole thing out.
carguy19 is offline   Reply With Quote
Old 02-12-2004, 03:15 PM   #8
pierceman
Member#: 44903
2002 NSXsupercharged
silverstone/black/black
it is actually very easy, PLUG THE COOLANT LINES WITH SPARK PLUGS. you will need 2 ,one on the pass side of the turbo and one for the top from the resevoir. It took me about 4 hours the first time, second time about 2 from start to finish. get new crush washers for the banjo bolt and new up/dp gaskets.
MAtt
pierceman is offline   Reply With Quote
Old 02-12-2004, 08:17 PM   #9
MITCHELL
Member#: 42924
04 STI
SILVER
Thanks!
Old 02-12-2004, 08:20 PM   #10
MITCHELL
Member#: 42924
04 STI
SILVER
thanks for the help.
Mitch
Old 06-23-2014, 11:43 AM   #11
shes_a_rally_girl
Member#: 146711
2004 STi
So from what I'm reading, 1.5-4 hours for just removal? I have a manual, but I came across this thread and was wondering what y'all's perceived difficulty is at changing out the turbo. I have nearly 110,000 miles on my STi, and it sounds like this puppy is ready to go. My Forrester XT is currently in the dealership for the same repair (under warranty, thank goodness), and they say the total cost without the warranty would be about $2,500! I'm looking online, and can find an OEM replacement for about $800, so if it is something folks think is really simple, I'll try that route. Just like the OCVs...dealer wanted to charge $600 parts and labor, but we just got the parts for about $240 and changed them ourselves...wasn't as difficult as some folks made it sound, as long as you take a minute to look at what you are working with, and plan what you need to remove ahead of time.
shes_a_rally_girl is offline   Reply With Quote
Old 06-23-2014, 11:46 AM   #12
mbhammerbro
Member#: 344521
2013 STi
Way to revive a 10 year old thread.
mbhammerbro is offline   Reply With Quote
Old 06-23-2014, 11:28 PM   #13
stevejones19
Member#: 275250
2006 WRX
Could've Made a new one and been destroyed by the next 10 people to comment on it... Its NASIOC, either way you'll get an earful from someone on here. (eye-full?)
These really isn't anything thats too difficult with this procedure though. As long as you have the proper tools, It is pretty straightforward. The bottom bolts on the turbo might be your toughest area. That or getting the oil return line hooked back up. But they aren't that hard, just take your time.
stevejones19 is offline   Reply With Quote
Old 06-24-2014, 12:01 AM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
post up in your local area forum for somebody local to you for help
id bet that you will have guys juming outta the woodwork to help you
beer and pizza and done in an afternoon....you WILL learn something....i promise
what exactly that will be....to be determined
this is the best answer you will get
Old 06-24-2014, 01:35 AM   #15
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
It's easy. Do it yourself.
Avoid the Subaru boy community. They'll try toget you to wear visors, hang stuffed animals from the bumper and paint your wheels pink blue yellow and gay. Assuming you haven't already.
And pointless mudflaps and goddamn red horns. Wtfbbq
ProfessWRX is offline   Reply With Quote
Old 06-24-2014, 01:29 PM   #16
roadtrip1098
Member#: 185688
2006 STi
WR Blue
The only hiccup I ever hit pulling a turbo is the occasional stuck bolt going to the DP. My 06 came apart easy, my 08 same story, a friends 09 - 2 had to be cut. Even doing that it still doesn't take too long once the heat shields are off. If you're changing the turbo, you may want to look at other options as well I know there's a couple shops that do VF39's with billet wheels on them for pretty cheap.
roadtrip1098 is offline   Reply With Quote
Old 06-24-2014, 06:51 PM   #17
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
Yeah. It really isnt bad. I did it myself a while ago
BeastianSTI is offline   Reply With Quote
Old 06-24-2014, 06:55 PM   #18
wobbletop
Member#: 11652
'11 STI 5dr Red
'70 Porsche 914/6
Half the heat shield bolts will probably snap in half. But it's not that difficult if you've worked on your car before. Make sure everything is torqued properly and use new gaskets.
wobbletop is offline   Reply With Quote
Old 06-24-2014, 08:44 PM   #19
Uncle Scotty
Member#: 16200
OK buy Nates beans
I predict disaster if the OP attempts this without onsite assistance from somebody who has done this before.
Removing an STI turbo shoodoggy Newbies & FAQs 15 05-14-2007 09:07 PM
06 STi seat removal vs 05 WRX seat removal razy Interior & Exterior Modification 1 04-12-2006 02:35 AM
TurboXS Uppipe and Stock Turbo Removal DTECH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-28-2003 12:11 AM
Need help having trouble with turbo removal tifosi77 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-30-2002 11:17 PM
turbo removal party? [email protected] Texas Impreza Club Forum -- TXIC 10 10-26-2001 11:37 PM
