Old 02-11-2004, 03:34 PM   #1
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Question why not use fuel system components for WI?
particularly, how about a walbro 255lph hp pump, which is capable of over 100psi of pressure? they're cheap too--100 bucks! get a fuel tank, mount the pump in it. get an autometer fuel level gauge and mount it in the cockpit for your low water indicator.
combine that with an FPR, plumbed into the intake manifold, and you have a nice rising rate FPR to keep the injection pressure differential steady. if you use the oem FPR, you get the 43psi of water injection pressure, or you could go aftermarket. of course, you would have to plumb in a return line.
complaints about reliability are clearly sidestepped with this approach... if the components are good enough for fuel, why wouldn't they be with water (or alcohol, or some mix)?
thoughts?
ken
Old 02-11-2004, 03:48 PM   #2
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
Better yet, why not skip the cost and time of installing two seperate systems, and put the water right in with your gas in the gas tank, and turn up your IDC's accordingly! j/k
Sounds like a good idea to me.
Zackbo is offline   Reply With Quote
Old 02-11-2004, 04:04 PM   #3
wgknestrick
Member#: 32576
04 STI
Ask ChargedPerformance (Ed) what he thinks. We just installed WI last night and the WI pump is WAY different from a fuel pump.
wgknestrick is offline   Reply With Quote
Old 02-11-2004, 04:07 PM   #4
Jon [in CT]
Member#: 2992
02 WRX Sedan
If I went through the trouble and expense of adding what is essentially a second fuel system, I wouldn't fill it with water — I'd use xylene or toluene.
Jon [in CT] is offline   Reply With Quote
Old 02-12-2004, 12:20 AM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Another issue with using fuel components is that they are not necessarily approved for water. Many fuel components will actually rust internally when used with water (fuel injectors especially).
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 02-12-2004, 11:22 AM   #6
Charged Performance
Vendor
Member#: 40645
Provided the components were compatible with your selected mixture there is no reason that you couldn't do this. But would the complications of installing a second fuel system (tank, pump, pressure regulator, return line, injector controller) aftermarket be worth the added benefits?
In my view an optimal supplemental mixture injection system would be a rising rate pressure regulated port injected system controlled by a map whose base flow characteristics was tuned to the knock tendencies of the motor and its torque profile. There would be an overlay +/- modifier to the flow amount for cylinder by cylinder EGTs. Add to it a small jet at the turbo outlet that was controlled by the temperature of the induction charge seen at the throttlebody.
I disagree that solely xylene or toulene would be the inherently better option when doing this. With a full blown second fuel system - you could alter the ultimate fuel mix to a knock suppressed optimal mixture without water injection - that I won't deny. But how much would the gasoline fueling have to be decreased and how much *lene would you have to inject to reach this point? Water still has an infinite effective octane requiring much less to be injected then its alternatives for the same effect.
Dispite John Banks' experiences I still have found that until fuel is reduced to optimal AFR water is a better injectable for the knock suppression being sought - though I remain open to learn otherwise. From there I would use methanol due to its solubility with the water and to ensure all oxygen actually was being utilized in combustion.
Ed.
Charged Performance is offline   Reply With Quote
Uhm Why Not use an AC Condenser for Intercooling? PseudoKirby Water/Methanol Injection, Nitrous & Intercooler Cooling 8 04-19-2009 11:01 PM
Any problems with using fog light switch for WI? fragment Electrical & Lighting 0 07-28-2004 03:36 PM
Why not use O2 instead of N2O? TheMadScientist Water/Methanol Injection, Nitrous & Intercooler Cooling 3 01-07-2004 12:57 PM
why not use the factory up pipe minus the pre cat? 2003 sedan Texas Impreza Club Forum -- TXIC 12 12-15-2002 04:08 PM
Fuel System Upgrade for WRX GoodFinder Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 03-13-2002 11:58 PM
