Old 02-11-2004, 04:29 PM   #1
Extraze
Member#: 16980
Default STi dash cluster: Low Tire Pressure Indicator light ? (Pics)
i dont know if any other clusters (WRX, Legacy, Forester or whatever) have this ... but im wondering if any other Domestic Markets have a Tire pressure indicator in the dash cluster like this one ?
is the car equiped with the electronics needed to monitor the tire pressure ? or can it be equiped to do so ??
anyone knows ?
thanks
Extraze is offline   Reply With Quote
Old 02-11-2004, 08:29 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
damn, these STI gauges have everything on them i want one for my 03 rs
Shane
PARANOID56 is offline   Reply With Quote
Old 02-11-2004, 09:40 PM   #3
jlee27
Member#: 10244
2002 2002 Bugeye
Lightbulb
One of our Toyota Seanna (sp?) company car/van is equipt with that sensor also....
-jlee
jlee27 is offline   Reply With Quote
Old 02-13-2004, 05:09 AM   #4
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
It probably measures wheel speed via the abs sensors and if one is faster than the others over time it lights up. When the system is installed on the car of course.
mr2guru is offline   Reply With Quote
Old 02-15-2004, 12:39 PM   #5
o2sys
Member#: 43842
200? WRX STI
i've seen that sign on the forester and i thing i turn on when the Diff. temp gets to hot....so its like a differential temp warining thingy...
o2sys is offline   Reply With Quote
Old 02-15-2004, 12:56 PM   #6
granteeton
Member#: 53529
it's there b/c in 05 they are adding tire pressure sensors in the valve stems, just like in the corvette. it monitors the air pressure of the tire and lets you know when it gets low. bottom line: a $200 mistake if you don't take it apart correctly when you break down a tire.
granteeton is offline   Reply With Quote
Old 02-15-2004, 01:16 PM   #7
o2sys
Member#: 43842
200? WRX STI
that sucks....like if it isnt a pain in the a** just to fix a flat, a sensor has to be there to make it worse.....
Old 02-15-2004, 04:32 PM   #8
Extraze
Member#: 16980
and where did you read this ?
Old 02-15-2004, 04:42 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
New DAMN law to keep let idiots know that they are driving on flat tires so they can do nothing about it....
Manditory air pressure BS on all new cars....
Edited for stupidity!
Old 02-15-2004, 07:05 PM   #10
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
the sensor is usually attached to the inside of the rim, via a really large hose clamp.
And yes you need to break the tire down in a proper sequence to avoid damaging the sensor.
Jay
Old 02-15-2004, 09:45 PM   #11
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
C'mon scotty, don't make me slap some warning points on ya!
Leonardo is offline   Reply With Quote
Old 02-15-2004, 10:01 PM   #12
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
My sisters 99 Grand Am GT has one of those systems on it. Good thing it does or she might try to drive on a flat tire.
EvasionOfTruth is offline   Reply With Quote
Old 02-15-2004, 10:27 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
BAH....more idiot laws for more idiots.....
Support birth control and planned parenthood.
Old 02-16-2004, 12:06 AM   #14
Caliber
Member#: 40199
2003 WRX
Platinum
Actually GM uses the ABS system to measure the rolling circumference of each wheel. So if one is less then the others its tells the driver. But if all 4 are loosing pressure at the same rate it will not notice a difference.
POS tire monitors should be illegal, they only make people less responsable for their own actions!
Please excuse this little rant but I deal with it all day being a mechanic.
Caliber is offline   Reply With Quote
low tire pressure light JustinV Newbies & FAQs 8 03-26-2010 12:43 AM
Getting tires up to temp - low tire pressures? Back Road Runner Autocross 9 10-04-2009 04:45 PM
How will rims effect the low tire pressure indicator.. spree768 Newbies & FAQs 2 06-25-2008 12:42 AM
low tire pressure light wont go off Shootist Tribeca Forum 4 09-10-2006 06:12 PM
Low Tire Pressure Buckeye Kid Tire & Wheel 3 01-14-2004 10:18 AM
