Old 02-11-2004, 04:46 PM   #1
Phantom Rex
Member#: 53537
2004 Imprezza WRX
Default Running lights won't turn off.
Need some help. Regardless of the position of the headlight switch, my running lights stay on even when the car is turned off.
I'm completey baffled. In addition, the only time the stereo light work is when the car is on, but the headlight switch is off. Oh, it gets better. The dash lights work when they're supposed to, but don't light up completely.
I'm starting to think that my car might be possesed.
I know this might be a shot in the dark, but does anyone have a clue what it could be?
Thanks.
Phantom Rex is offline   Reply With Quote
Old 02-11-2004, 04:49 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
as for the running lights, try turning off the switch on top of the steering column.
Shane
PARANOID56 is offline   Reply With Quote
Old 02-11-2004, 05:35 PM   #3
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
On the end of the headlight lever, there is a knob to adjust the brightness of the dash lights. The stereo also dims when the headlights are turned on, so it might just be that you can't see the light during the daytime when the lights are on.
You really need to read your owners manual before you break something.
lotusTT is offline   Reply With Quote
Old 02-11-2004, 07:02 PM   #4
Phantom Rex
Member#: 53537
2004 Imprezza WRX
Yep, I'm an a$$. You guys are right on both accounts.
My car thanks you.
Old 02-14-2004, 02:26 AM   #5
RevNHardSti
Member#: 44697
04 Sti 04'
Pearl Blue
My car thanks you too!
I had the same issue with my running lights!
RevNHardSti is offline   Reply With Quote
Front turn signal, brake light, and running light won't turn off Floor it Electrical & Lighting 0 06-27-2009 10:34 PM
My lights won't turn off after I turn the car off. need HELP sillyme Newbies & FAQs 8 12-18-2008 08:41 PM
WTF: MY brake lights and front signal lights won't turn off 05ImprezaRS General Community 7 04-10-2007 06:59 AM
Tail lights and front running lights won't turn off. pcpolo Electrical & Lighting 7 06-21-2005 03:13 PM
daytime running lights won't turn off! selector37 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 02-12-2002 12:00 PM
