Old 02-11-2004, 06:39 PM   #1
pistoffjstr
Member#: 29283
2003 Subaru Forester
Red
Default Headlight mod help
For those of you who have done the relay mod
from this site
did you buy the kit or did you get relays on your own?
IF you bought relays on your own were did you get them and what kind/ratings
pistoffjstr is offline   Reply With Quote
Old 02-12-2004, 03:38 PM   #2
dropmech
Member#: 41477
2006 Tahoe that
will pull your bumper off
I'mnot reading all of that. Can we have the cliff notes?
dropmech is offline   Reply With Quote
Old 02-12-2004, 04:19 PM   #3
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
i bought the relays on my own, but you will also need new headlight plugs, and a new male headlight plug (hard to find)
so, i would just buy the kit, and shorten the wires so it fits the subaru better.
Shane
www.paranoidfabrications.com
PARANOID56 is offline   Reply With Quote
Old 02-12-2004, 05:04 PM   #4
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I got the kit from Daniel stern. It does not come with wire, heatshrink, or protective loom - only the relays, the relay "brackets" all the connectors, and the fuses.
I bought 12ga wire, spiral loom, and lots of heatshrink tubing from parts express.
After an initial screw up with the wiring, I went with a simpler wiring layout and it works GREAT now.
If you don't get the kit from Daniel Stern, you'll be faced with finding the connectors (i needed H1 and 9005 in addition to the 9007 to plug into the factory harness). You'll also need to get the proper relays and such. The hella 40amp dual-87 terminal is probably the best way to go. You can get them from www.rallylights.com
I used 10 ga wire to go from the battery+12V to the relay's #30 terminal and a single 12ga for 87 terminal.
nhluhr is offline   Reply With Quote
Old 02-12-2004, 07:26 PM   #5
pistoffjstr
Member#: 29283
Red
cool thanks for the feed back guys
headlight mod help SedonaScooby Interior & Exterior Modification 3 11-15-2007 08:59 PM
Headlight Mod Help? CtGT Electrical & Lighting 4 04-09-2003 02:43 PM
Headlight mod help fuzzycuffs Interior & Exterior Modification 4 03-30-2003 04:28 AM
Headlight Mod Help? rlarose New England Impreza Club Forum -- NESIC 0 06-19-2002 10:12 AM
The headlight mod... Help quikly please DubbleURX Interior & Exterior Modification 3 10-11-2001 09:48 PM
