Old 02-11-2004, 06:54 PM   #1
AK'S REX
Member#: 12163
Default Factory oil temp gauge broken........
Anybody ever have the oil temp gauge on the factory gauge pack stop working? I imagine it's the sending unit but I'm not certain. Just stopped working today, worked fine yesterday though. Where can I get a sender?
Thanks,
-AK
AK'S REX is offline   Reply With Quote
Old 02-11-2004, 07:34 PM   #2
edubb11
Member#: 23918
2002 WRX (SOLD) :(
Sex? Yes, please.
Would it be covered under the bumper to bumper warranty? That is if you are still under 36,000 miles. Otherwise, maybe you can use a sending unit from Autometer or something, but I'm not certain.
edubb11 is offline   Reply With Quote
Old 02-11-2004, 10:41 PM   #3
wrx102
Member#: 49956
'02 WRX R.I.P.
'03 protege
My oil temp gauge broke about a month ago. The dealer said the sensor was broken. But they fixed it for me for free because it was still under warranty. If your car is over 36K miles, they won't do it for free.
wrx102 is offline   Reply With Quote
Old 02-13-2006, 04:40 PM   #4
Worxman02
Member#: 66563
2002 Impreza WRX
WR Blue Pearl
Question
I know that this is an old thread, but Im having an issue with my oil temp gauge and I decided to bump this old thread instead of starting a new one to prevent any responses that consist of "search". On my 02 WRX I have the whole gauge pack installed and the oil temp gauge has recently been acting strange. It reads at 180 C (max temp) when I start the car and when I rev the engine, the needle goes to 50 C (lowest temp) and then when in driving it will sometimes wander back and forth between temps. Eventually it settles down and seems to be reading the correct temp. Im assuming its either the sending unit going bad or the wiring is shorting out/loose or it could be a bad ground. What do you guys think?
Worxman02 is offline   Reply With Quote
Old 02-14-2006, 11:21 AM   #5
Worxman02
Member#: 66563
2002 Impreza WRX
WR Blue Pearl
bump.
Old 02-17-2006, 12:59 AM   #6
Worxman02
Member#: 66563
2002 Impreza WRX
WR Blue Pearl
bump. Somebody please help?
Old 02-19-2006, 09:23 PM   #7
Worxman02
Member#: 66563
2002 Impreza WRX
WR Blue Pearl
bump.
Old 02-20-2006, 04:24 PM   #8
Worxman02
Member#: 66563
2002 Impreza WRX
WR Blue Pearl
You guys suck
Old 02-20-2006, 05:58 PM   #9
mhbrown
Member#: 12537
'02 WRX Sportwagon
WR Blue Pearl
Where is your temperature probe installed. If it is an oil pan install, I am betting that you have a cracked, broken or shorted wire just outside the probe.
mhbrown is offline   Reply With Quote
Old 02-20-2006, 07:55 PM   #10
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
The oil temperature sensor for the factory gauge is known to be troublesome. I battled with my dealer over erratic oil temp readings for quite a while. They finally installed a new gauge only and the problem came back almost immediately. I installed a new temperature sensor and that solved the problem.
jac04 is offline   Reply With Quote
Old 02-21-2006, 09:16 AM   #11
Worxman02
Member#: 66563
2002 Impreza WRX
WR Blue Pearl
Finally! Thank you guys for some answers. the temp probe is the factory one located in the oil pan. I assumed it was a short, thanks for confirming it. Any suggestions on how to prevent it from happening again once I get a new sensor? I'll probably try to wrap it in electrical tape or heat shrink tubing if possible.
factory oil temp gauge sensor KitchenerWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-29-2010 04:13 PM
FS: DEFI Amber 60mm boost, water temp, oil press, oil temp gauge w STi genome unit renda85 Exterior/Styling 11 08-03-2009 09:13 AM
LA WTB: Oil Temp Sensor for lamco oil temp gauge Yulri Private 'Wanted' Classifieds 0 03-09-2008 09:14 PM
Can a defi oil temp gauge be used for water temp duty? hella_sti Interior & Exterior Modification 2 05-05-2007 04:56 PM
Broken factory oil temperature gauge? WRX Bamboo Steamer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-20-2001 01:28 PM
