Old 02-11-2004, 10:58 PM   #1
mouserWRX
Member#: 48960
2006 TL
Anthracite
Default Odd turn signal behavior -- ??
Well just the other day I noticed that my right turn signal flashes at twice the speed my left one. If I use my hazard lights, they both go off and on at the same normal speed. When I use the right turn signal however, it's twice as fast as normal.
I checked the turn signal fuse under the hood and the fuse is still good. Any other suggestions as to what's going on?
I just recently got a Cobb stage 2 reflash, but I don't know if that would affect anything or not.
I tried searching for the answer but didn't find anything.
mouserWRX is offline   Reply With Quote
Old 02-11-2004, 11:28 PM   #2
GT2RS
Member#: 1077
Usually that happens when one of your bulb is busted...have you checked both the front and rear bulbs yet?
GT2RS is offline   Reply With Quote
Old 02-11-2004, 11:33 PM   #3
mouserWRX
Member#: 48960
2006 TL
Anthracite
No I will check that next, thanks for the help!
Old 02-11-2004, 11:57 PM   #4
GT2RS
Member#: 1077
Yeah that could be it...
Old 02-12-2004, 10:24 AM   #5
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
more than likely the case.
ATX25RS is offline   Reply With Quote
Old 02-12-2004, 10:26 AM   #6
mouserWRX
Member#: 48960
2006 TL
Anthracite
Andres, do you know what bulbs are used for the turn signals, and if I can get them in amber?
Odd closed loop behavior (AFR target)? Kha0S Engine Management & Tuning 17 06-28-2010 09:00 AM
Front turn signal, brake light, and running light won't turn off Floor it Electrical & Lighting 0 06-27-2009 10:34 PM
Driver Side Turn Signals - Odd Flashing Pattern daisyGT Electrical & Lighting 0 08-30-2008 03:04 PM
Turning the side marker light into a turn signal romanom Interior & Exterior Modification 3 03-20-2002 08:48 AM
