Old 10-07-2011, 04:10 PM   #1
MyOtherRideIsUrMom
Member#: 159636
2007 WRX WRB-18G EWG
2014 Outback LTD ISM
Default Reason for multiple HVAC motor failures?
My car is an 07 WRX with about 120k on it. It was bought new. Around september 2010, the original blower motor started making clicking and screeching noises. I replaced the blower, and just over 1 year later, it has started doing it again. The first time, as with this time, I will be replacing it with OEM parts. Has anyone had multiple blower failures like this?
MyOtherRideIsUrMom is offline   Reply With Quote
Old 10-07-2011, 08:12 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
If something is restricting the rotation of the motor that can cause damage to the motor.
Cougar4 is offline   Reply With Quote
Old 10-07-2011, 08:35 PM   #3
MyOtherRideIsUrMom
Member#: 159636
I forgot to mention there was nothing noticeable with the first one. I have a cabin filter that I change every spring.
Old 09-30-2013, 05:42 PM   #4
MyOtherRideIsUrMom
Member#: 159636
My blower motor just started dying again. That puts me at 3 replacements in 200k/5years.
Old 09-30-2013, 08:04 PM   #5
Cougar4
Member#: 53443
Winestone
Since you are hearing noises it sounds like the fan is touching something and restricting the motion of the motor.
Old 09-30-2013, 09:05 PM   #6
DentMagnet
Member#: 352689
2004 Impreza
dark green but looks blak
Maybe the impeller is missing a balance weight. This is something you could look for in the ductwork.
Also, if the motor is mounted with rubber isolators, maybe these have hardened over the years.
The HVAC-Talk forum may have several more candidate causes.
I also have HVAC problems and I will soon be searching as to whether there is a class action lawsuit against Subaru about this issue.
IIRC they already had one because the odometer read a few percent high causing the warranty to expire sooner in some cases. Seems like this is sort of related to 'odometer fraud', but I don't want to appear to be anti-business. . .
DentMagnet is offline   Reply With Quote
Old 10-01-2013, 03:20 PM   #7
MyOtherRideIsUrMom
Member#: 159636
With the original one, and the first replacement, I thought there was something touching. I never found anything, and my last one there was nothing either. I have a feeling I will find the same thing this time.
It always starts out griding, then goes to squeeling, then stops. I was hoping there would be a new revision, but no luck yet.
The second time it happened, I checked all of the rubber mounts, they all seemed fine.
Old 10-01-2013, 06:02 PM   #8
Cougar4
Member#: 53443
Winestone
If a grinding noise is heard right after installing a new motor something is touching the fan that shouldn't be.
Old 10-01-2013, 10:25 PM   #9
DentMagnet
Member#: 352689
2004 Impreza
I inferred that the new motors all started out quiet, so then the grinding would be the motor bearing being ruined, followed by squealing, followed by failure.
Impeller imbalance should cause the motor shaft lateral/radial runout or backlash to increase.
04 STI motor failure root located Obsidian Warranty Issues & SOA Problems 205 05-15-2012 07:28 PM
wtb; hvac motors and box sdkenny Private 'Wanted' Classifieds 1 12-26-2008 01:07 AM
Need more info for sti motor swap - hvac, motor and so on. hybrid gti 2 Subaru Conversions 4 09-29-2008 10:41 PM
Main reasons for engine failure cr125r General Community 15 05-13-2006 09:50 AM
motor failure question (building up) DoctorNick Normally Aspirated with bolt-on Forced Induction Powertrain 24 10-28-2002 12:03 PM
