Old 02-12-2004, 12:47 AM   #1
bigdwrx
Member#: 28697
WR blue pearl
Default Boost gauge necessary?
If i plan on running a cobb stage 2 and never touching it again, do i still really need to put down the money for a boost gauge?
Thanks,
Danny
bigdwrx is offline   Reply With Quote
Old 02-12-2004, 01:26 AM   #2
jlevy
Member#: 15696
2007 Mini Cooper S
Dark Silver and White
Default monitor MAP values instead
You can also use an OBD-2 tool like pocket logger to view or log MAP values. I don't have a boost gauge and currently have the Cobb stg 2. It's probably safer to just log the values during a pull than watch a gauge anyway.
-my 0.02
jlevy is offline   Reply With Quote
Old 02-12-2004, 01:52 AM   #3
hippy
Member#: 36528
2002 Impreza Wrx
it's probably safer to know if your overboosting when it happens.....
Old 02-12-2004, 09:38 AM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
c'mon, they're cheap enough, and they give you a VERY critical piece of information.
jm2c
ken
Restrictor pill in mechanical boost gauge necessary? PS_REX Electrical & Lighting 2 04-30-2012 05:53 PM
Is a boost controller necessary for my setup? g0tb00st Factory 2.5L Turbo Powertrain 17 12-16-2004 07:17 PM
boost gauge necessary? theSTIguy27 Newbies & FAQs 10 11-17-2004 11:06 PM
Is an EGT gauge necessary?.... TastyTurbo Factory 2.0L Turbo Powertrain 9 11-18-2003 08:27 PM
Message Board Statistics All times are GMT -4. The time now is 09:18 PM.
