Old 02-12-2004, 01:01 AM   #1
burt_poppenga
Member#: 16442
2004 STi
Default Stoptech Brake Lines for STI?
Hello,
Anyone out there have the SS Stoptech brake lines for the STI?
Looks like the mounting bracket on the front line is made out of plastic ... is this an issue?
(As I recall, the bracket on my old WRXs Goodridge lines was all metal.)
Thanks,
Burt
burt_poppenga is offline   Reply With Quote
Old 02-12-2004, 06:14 AM   #2
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
If you actually see the bracket it looks like it has a high fiber content so IMO it looks up to the task.
ellisnc is offline   Reply With Quote
Old 02-14-2004, 10:48 AM   #3
burt_poppenga
Member#: 16442
2004 STi
I ended up calling the folks from Stoptech and they haven't had any issues with the plastic bracket failing. They did mention that there are small pieces of shink tube on either side of the front brackets that are intended to keep the hose from freely slipping through the bracket: I was advised to back these up with zip ties if the shrink tube moved too freely (after things were installed and set up). No such issues with the rear lines (must be the additional turning motion that the front has).
BTW: the only difference between the WRX and STI Stoptech lines is the front STI lines have a slight bend (30 degrees or so) just before the banjo fitting (the front WRX lines are a straight shot).
WTB Single SS braided + coated brake line for STI aus_taz NESIC Private Classifieds 0 08-20-2007 01:49 PM
VA: Goodridge stainless brake lines for STi- cheap! Adrift Suspension/Brakes/Handling 3 01-18-2007 10:16 PM
FS CA: Brake parts, pads, lines for STi, Stoptech, WRX wylie Private 'For Sale' Classifieds 9 03-24-2006 11:28 PM
D.O.T. STAINLESS STEEL BRAKE LINES for STI hauvis Brakes, Steering & Suspension 5 12-07-2004 03:08 AM
SS brake lines for STi RafalW Brakes, Steering & Suspension 0 06-17-2003 07:05 PM
