Old 02-12-2004, 09:12 AM   #1
scooby
Member#: 13085
Default Blown turbo and motor, need some build up suggestions..
Heres the deal, I blew my block and the turbo along with it this weekend and I'm trying to get some advice as to what to put in its place. I was looking at the axis power stage 3 and 4 blocks and doing the stage 2 cobb heads. As for a turbo, I would like something good for atleast 400whp on pump, especially if I'm going to have a built motor with more displacement.
Any thought and suggestions for engine or turbo would be greatly appreciated.
Thanks,
Doug
scooby is offline   Reply With Quote
Old 02-12-2004, 09:32 AM   #2
nickgomez
Member#: 16820
88 535i
alpinweiss
why not just stick an sti 2.5 block in it?
nickgomez is offline   Reply With Quote
Old 02-12-2004, 12:15 PM   #3
Dakken
Member#: 24570
wrx [email protected] 1/4
1.72 best 60ft
If you have the money, Axis is the place to go.
If you're not set on money, i'd say go 2.5 sti block with maybe some better pistons, and the stage 2 heads.
Thats my suggestion
Scott
Dakken is offline   Reply With Quote
Old 02-12-2004, 12:17 PM   #4
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Don't forget a tranny that is up to the job also.
Andy
DonkeyPunch is offline   Reply With Quote
Old 02-12-2004, 05:00 PM   #5
mixup52
Member#: 39691
2002 WRX Wagon
Not sure what the Garrett GT30 makes, but I like that one personally. Also a 6 speed you will need.
mixup52 is offline   Reply With Quote
Old 02-12-2004, 07:06 PM   #6
scooby
Member#: 13085
thanks for the fast replys, money may or may not be an issue depending on how quick I want it fixed.
I seen that greddy has a t67 turbo kit with uppipe and down pipe for the 2004 sti, I wonder if i could use that kit with the 2.5 sti block.
Oh one more thing will my heads fit right on the 2.5 block?
Yes I'm looking into trannys, I have learnt the hard way enough.
Old 02-12-2004, 07:11 PM   #7
scooby
Member#: 13085
I just relooked at the stage 2 from axis and it seems to be pretty affordable at $2400.oo pre assembled with forged pistons. Do you guys think the stock rods are strong enough?
Probably blown motor - Need Some Help :( MattK Mid Atlantic Impreza Club -- MAIC 45 01-06-2009 06:44 PM
Blown motor, need some help... Jpizzzle Built Motor Discussion 5 11-07-2006 07:28 PM
Blown Gasket New Motor needed? scoobiegt Legacy Forum 6 11-23-2004 11:47 PM
Need opinion on if a turbo is right for my build up. DoctorNick Normally Aspirated with bolt-on Forced Induction Powertrain 3 08-09-2002 11:38 PM
need lightweight non RS moter Impreza for build-up - suggestions?? HYDCSX400 General Forum Archive 9 02-21-2001 12:04 AM
