Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 02-12-2004, 11:18 AM   #1
Jeff_DML
Member#: 32018
2008 M3 Sedan
Interlagos Blue
Default install uppipe first or wait for downpipe too?
Quick question, my car is stock. If I eventually plan to replace my downpipe, should I wait until I get it before installing a uppipe? Basically it is easier to install both at the same time or are their installations different? Seems like you can get to the downpipe from under the car while the uppipe requires removing the intercooler and stuff from above.
thanks
Jeff_DML is offline   Reply With Quote
Old 02-12-2004, 11:52 AM   #2
mkultra69
Member#: 34402
2002 WRX AP stg 2+
WRB 4EAT and proud of it!
Youll have to remove the downpipe anyways so I waited. You might wanna get some I/C pipes too, get it all done at once.
mkultra69 is offline   Reply With Quote
Old 02-12-2004, 11:58 AM   #3
Jeff_DML
Member#: 32018
2008 M3 Sedan
Interlagos Blue
thanks
Old 02-12-2004, 12:38 PM   #4
AutoSpeedPerformance
Vendor
Member#: 51592
Defintely wait, you have to take the downpipe out for both jobs so you may as well get it all done at once. The intercooler doesnt have to come out for either install, so that shouldn't have any effect on you decission.
Frank
AutoSpeedPerformance is offline   Reply With Quote
Old 02-12-2004, 07:59 PM   #5
camz911
Member#: 16041
'02 SCRAP METAL
ZERO whp.... :(
Frank
agreed...you can do the IC pipes any time you want...
camz911 is offline   Reply With Quote
Old 02-12-2004, 09:13 PM   #6
batmanalan
Member#: 37583
just do the up
batmanalan is offline   Reply With Quote
Old 02-12-2004, 09:50 PM   #7
Member#: 22294
2003 WRX MBP
COBB STG II
What they all said, wait and to it all at once.
WRB is offline   Reply With Quote
Old 02-12-2004, 10:55 PM   #8
Bankie
Member#: 37785
OT hates your car
The downpipe install is easy. I wouldn't hesitate to install the uppipe while I wait to get the dp. And the intercooler doesn't have to come out but it makes access a whole lot easier if you remove it.
Bankie is offline   Reply With Quote
Old 02-13-2004, 08:52 AM   #9
Rickyh
Member#: 40453
downpipe takes an hour by itself. just do the uppipe since you already have it. when you do get the downpipe it is going to be really easy because the bolts aren't going to be frozen up because you will have loosened em up doing the uppipe.
Rickyh is online now   Reply With Quote
Old 02-13-2004, 11:22 AM   #10
Bankie
Member#: 37785
OT hates your car
It took me about 2 hours the first because of the frozen bolts. The last time it only took me 40 minutes to take the dp off, modify so it didn't touch the frame, and put it back on.
Old 02-13-2004, 11:36 AM   #11
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
How long are you going to wait for the downpipe?
I would say just do the uppipe now since that is the much harder install. Then when you have the money get the downpipe. The DP will go in really easily since like aforementioned the bolts will have been touched and you will also know how to do it.
mbiker97 is offline   Reply With Quote
Old 02-13-2004, 11:40 AM   #12
jfandem
Member#: 37747
2003 WRX
Sedona Red
How does the downpipe take an hour by itself? I removed and installed it 3 or 4 times now and it takes about 10 minutes or less...5 bolts from the turbo to downpipe, and the 2 bolts from the downpipe to midpipe...thats it...just wondering why you think it takes an hour?
jfandem is offline   Reply With Quote
Old 02-13-2004, 02:15 PM   #13
SJwrx
Member#: 14970
1997 GF8
multi
Dowpipes are so easy to install that you might aswell do the uppipe and then do the downpipe at a later time.
Rich
SJwrx is offline   Reply With Quote
Old 02-14-2004, 10:32 AM   #14
epoth
Member#: 49667
2004 WRX 2.5 Hybrid
8cm18G - PPG Helical
I did the uppipe first and then the downpipe a couple of weeks later. Works out well.
epoth is offline   Reply With Quote
Old 02-14-2004, 12:29 PM   #15
camz911
Member#: 16041
'02 SCRAP METAL
ZERO whp.... :(
you guys like doing more work than you have to.....I dont see any sense in taking it off and re-installing it twice, but thats just me
would it be safe to install now or wait for a tune? darkinc Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 11-04-2008 06:39 PM
Install coilovers now or wait for summer? wrbWRX Brakes, Steering & Suspension 11 10-15-2004 11:17 AM
44 miles too much on new sti? or wait for 05 Focus4 General Community 19 05-20-2004 06:32 PM
Evo first or wait for sti? gtr General Community 27 08-20-2002 01:40 PM
What to buy? '01 Brighton Wagon or OBS? or wait for '02? Garvinator General Forum Archive 11 12-15-2000 12:55 AM
