Old 02-12-2004, 01:49 PM   #1
Tobey
Member#: 21400
2015 WRX Limited
ISM
Default question about bad egt sensor, the egt fix etc
so my egt sensor went bad and i left it in there, did the resistor trick and my cel is gone.
now i got to thinking, the ecu is now seeing the same reading from that egt sensor all the time now right? which means my car is convinced that it only needs to give me X amount of fuel?
before i could never get my car above 1500f on my egt gauge (pass side manifold) but now i wonder if it would be easier to melt stuff? this is my assumption only, can anyone verify this?
anyone know the approximate price of a new egt sensor? i think it might be worthwhile to replace it!!
Tobey is offline   Reply With Quote
Old 02-12-2004, 02:00 PM   #2
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
EGT sensor != fueling control. It's just to tell the engine if that uppipe cat is melting/burning. You were probably thinking of the front 02 sensor.
mexicanpizza is offline   Reply With Quote
Old 02-12-2004, 03:40 PM   #3
Tobey
Member#: 21400
2015 WRX Limited
ISM
wouldn't the egt have to control some aspect of fueling? think about it, if your egt's are high the ecu has to see that, so it compensates...
this is my theory only, just not sure if i am anywhere close? i started throwing it around in my head and got to wondering...
Old 02-12-2004, 03:43 PM   #4
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
Welp, read up more around here...it's pretty well documented that the EGT sensor is ONLY there for determining the combustion status of the uppipe cat.
I would say about 1/2-2/3'rd's of the people with WRX's and catless uppipes run the resistor mod.
Uppipe EGT sensor removal. CEL fix? Gro Harlem Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-21-2009 02:53 PM
Questions about toe and camber, need to fix bigtime problem in my front end. muckchiller Brakes, Steering & Suspension 5 12-30-2007 08:15 PM
Question about rear O2 sensor Speedy02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-29-2003 07:01 AM
Questions about stock shock sensor on 2000 2.5 RS slim speedy Car Audio, Video & Security 1 03-05-2003 12:28 PM
Question about air/fuel sensors Stranger Normally Aspirated Powertrain 1 12-03-2002 10:33 PM
