Old 02-12-2004, 01:38 PM   #1
makofoto
Member#: 25243
2006 Legacy Outback
Default AutoX, ABS or No ABS?
Last weekend I drove my first AutoX with the ABS fuse pulled. It was a bumpy course ... and I was told it was better to run without ABS.
It was the first time in MANY years driving without ABS ... and so I'm having to re-learn brake modulation ...
But on a smooth course ... would ABS have some things going for it?
makofoto is offline   Reply With Quote
Old 02-12-2004, 02:56 PM   #2
jmott
Member#: 6713
2007 Prius
brown
Default Re: AutoX, ABS or No ABS?
the best autocross driver I know, Chris Ramey, seems to not really care whether or not its on.
which makes some sense, if you are capable of threshold braking, you want engage the ABS anyway.
other very good (but not as good as chris) autocrossers I know consider ABS to be a huge advantage.
jmott is offline   Reply With Quote
Old 02-12-2004, 03:13 PM   #3
BriDrive
Member#: 21801
2013 Jacked Up T4R
Not to mention in many if not most auto-x courses the very best drivers are good LEFT foot brakers /trail brakers who rarely even use full braking.....
BriDrive is offline   Reply With Quote
Old 02-12-2004, 04:03 PM   #4
leecea
Member#: 37359
2003 WRX
If I make a mistake with braking, I'd rather have ABS kick in than flatspot an expensive R tire.
leecea is offline   Reply With Quote
Old 02-12-2004, 04:34 PM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Ive only had ABS kick on once while autocrossing... It shouldnt really matter much, because you are SUPPOSED to only brake before the corner
Old 02-12-2004, 04:35 PM   #6
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Riiiight. Get your facts right chief Lots of great autox drivers break with their right foot
ABS is an advantage in the WRX. It saves you a lot of tires.
-Tom
trhoppe is offline   Reply With Quote
Old 02-12-2004, 04:40 PM   #7
jmott
Member#: 6713
2007 Prius
brown
-Tom
or break with their left foot but apply full braking force all the time =)
Old 02-12-2004, 04:43 PM   #8
nate49509
Member#: 22452
2016 WRX
On. I rarely feel the ABS kick in while auto-xing and when it does I'm usually glad it did. I've heard someone say before that nobody can modulate the brakes faster than ABS can.
nate49509 is offline   Reply With Quote
Old 02-12-2004, 04:46 PM   #9
Watkinsm3
Member#: 51740
2004 STi A-Stock #24
Same as my Coffee : Black
I was an extreme threshold braker in my Integra as it's ABS was horrible and slow. I could trailbrake, left foot brake ( I am more of a right foot braker overall ) fine in the car as long as I NEVER touched the ABS.
The STi? I have yet to get it to an autox yet (they keep getting canceled on me ), but I can tell you already the ABS feel incredible. Will I rely on it on course? No. Will I be upset if I slip into it by mistake every now and then? no-at-all!
-Matt
Watkinsm3 is offline   Reply With Quote
Old 02-12-2004, 04:47 PM   #10
ITWRX4ME
Member#: 24472
2001 Miata
Is the stopping distance with ABS longer when compared to proper threshold braking?
ITWRX4ME is offline   Reply With Quote
Old 02-12-2004, 04:48 PM   #11
Watkinsm3
Member#: 51740
They never dove my Integra!! Seasons cycle faster than that car's ABS!!!
-Matt
Old 02-12-2004, 04:51 PM   #12
jmott
Member#: 6713
2007 Prius
brown
yes
but how many people can threshold brake that well? I do not know.
Old 02-12-2004, 04:53 PM   #13
Watkinsm3
Member#: 51740
I'm a step behind on these replies!
In theory perfect threshold braking will ALWAYS be better then ABS. With perfect Threshold braking the wheels will NEVER lock. ABS Has to sense the lock and release the wheel. The good systems cycle really quick while maintaining balance. Nobody is perfect and with an average driver versus a good car? No contest... ABS will give better stopping distances.
-Matt
Old 02-12-2004, 04:59 PM   #14
nate49509
Member#: 22452
2016 WRX
-Matt
I agree very well said.
Old 02-12-2004, 05:06 PM   #15
BriDrive
Member#: 21801
2013 Jacked Up T4R
Errr....trhoppe.....I....uhhh.....don't want to jinx you....I'll wait to see the results out of Atlanta.....but......I'm bettin MK is gonna left foot beat you
Joking aside, I of course realize right footers are capable of as much speed....
Old 02-12-2004, 05:11 PM   #16
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Good Try there I won't be in atlanta because the tranny blew, but it will be interesting to see if mikey can be on pace
-Tom
Old 02-12-2004, 05:18 PM   #17
PKer
Member#: 27647
06 MX-5-STR 03WRX
(ret), 08 Titan-Tow
I think the WRX ABS is particularly sensitive and goes into ABS much too early.
I always disable ABS.
PKer is offline   Reply With Quote
Old 02-12-2004, 05:19 PM   #18
BriDrive
Member#: 21801
2013 Jacked Up T4R
Oops, sorry about that...I did not know.......
Old 02-12-2004, 05:40 PM   #19
akuhner
Member#: 462
2000 Impreza 2.5 RS
SCCA Rally Cross Car
Auto-X: ABS On
Rally-X: ABS Off (goes for any slippery surface)
akuhner is offline   Reply With Quote
Old 02-12-2004, 07:19 PM   #20
leecea
Member#: 37359
2003 WRX
My experience is that it only does that when you hit a bump under braking. I have certainly experienced that, but I've never had ABS kick in too early on flat tarmac.
I think the original poster talked about an autox course with bumpy corner approaches - that could be an interesting challenge!
Old 02-12-2004, 07:33 PM   #21
PKer
Member#: 27647
06 MX-5-STR 03WRX
(ret), 08 Titan-Tow
Good point.
As a matter of fact I drove the same course as Makofoto and there was a crest of sorts right bfore a dip and then a pretty hard left. It wasn't easy to wait for the car to settle after the dip and then brake. I locked em' up for a sec in that spot.
Old 02-12-2004, 07:33 PM   #22
Uber Wagon
Member#: 39600
2008 STi
Dark Grey Metallic
So you mean to tell me all that trouble I went through to make an ABS cutoff switch was for nothing!?
Uber Wagon is offline   Reply With Quote
Old 02-12-2004, 07:40 PM   #23
WRXIN
Member#: 15405
2004 STI
Silver/Gold - Team Blew
I've driven the course that Mako (original poster) is referring to. I usually run auto-x with the abs enabled but the surface he recently ran is rough and bumpy, has some small holes, and actually runs through some small "valleys", kind of like a big gentle gutter in the street. There's a tendency on this course to easily endup with a wheel in the air for a sec and that's where abs starts to be a problem. (Mako, maybe you can repost that pic you have with your wheel in the air in this thread, it'll give folks an idea of the the surface I'm trying to describe)
Anyhow, on this particular course, my abs kicks in way too much and ruins my left-foot braking efforts. I've read that on rough surfaces, abs can actually degrade braking distances, so that's why I suggested he pull the fuse.
Its all driver preference in the end. I left foot brake and trail brake and I have more success that way then using just my right foot for both gas and brake.
Lots of good points made in this thread. Thanks.
-Mark
WRXIN is offline   Reply With Quote
Old 02-12-2004, 07:49 PM   #24
makofoto
Member#: 25243
2006 Legacy Outback
This bump was at the exit of a corner ... but ... you get the idea ...
Old 02-12-2004, 08:06 PM   #25
makofoto
Member#: 25243
2006 Legacy Outback
A better example from the same course ... very stiffely sprung VW ... pitching up after rebounding going through the "ditch." Of course I don't believe that VW had any ABS to worry about ....
See how low that car in the background is ... the "ditch" flows to that low point.
Brembo+ABS Delete+ Auto. Issues or no? Seraphinwolf Subaru Conversions 2 02-09-2009 01:27 PM
I pulled the ABS fuse, but when I put it back, no ABS? BoSachok Brakes, Steering & Suspension 2 02-19-2007 01:27 PM
ABS vs No ABS in snow...my experience express_wagon New England Impreza Club Forum -- NESIC 42 12-10-2005 01:21 PM
ABS or no ABS in autocross w/non-stock brakes? RebelINS Motorsports 11 10-21-2004 01:02 AM
Gravel roads - ABS or no ABS? 8Complex General Forum Archive 7 06-20-2000 09:35 PM
