Old 02-12-2004, 10:18 PM   #1
UM-WRXer
Member#: 44623
Lightbulb Throttle postion vs boost on stock ecu map
Hey i was wondering about the stock map on my 2002 wrx. Is the throttle postion a function of boost or is rpm a function boost? When im pushing the throttle about 1/3 way down i hit about 6.3 psi no matter what rpm im at or what gear (except 1st). Should my boost not increase as the rpm increases?? I can only hit full boost when im at wot. Is this normal? I dont have any cel's or any tell tale signs that something is wrong. Im getting bad gas milage but it think that is from the bad winter gas up here in maine. Other than that everything is the norm. Im coming off from a vishnu unichip b/c winter is too cold for start-ups. When hooked up with that and emi adapter my car rips, but now that im back to stock i feel my car is slow or something...
Can anyone give me some advise??
THanks
UM-WRXer is offline   Reply With Quote
Old 02-12-2004, 10:20 PM   #2
vile
Member#: 32371
'02 t-rex wagon
platinum
yes, boost is tps dependant
vile is offline   Reply With Quote
Weird idea--3bar/4bar map sensor on stock ECU? HamFist Engine Management & Tuning 5 12-28-2009 12:46 AM
boost on NA ecu SubeSTIle Normally Aspirated Powertrain 12 03-27-2009 10:50 PM
Not hitting target boost on stage 1 map Mr.Krinkle Commercial ECU Reflashes 18 06-16-2007 06:04 PM
reverting back to stock ecu map via accessport?? Go_Rex_Go Newbies & FAQs 3 05-12-2007 01:09 AM
What psi/boost with stock ecu = CEL? SGOSWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-17-2002 08:39 PM
