Welcome to the North American Subaru Impreza Owners Club Wednesday July 1, 2015
Old 02-13-2004, 12:20 AM   #1
e23k13l420
Member#: 30482
Default 04 JDM STi (HID) headlights on WRX
Hey, I was wondering what i needed in order to get them to work, maybe a harness, and something to up the voltage? Please help, Thanks.
e23k13l420 is offline   Reply With Quote
Old 04-10-2005, 10:52 AM   #2
SupraToWRX
Member#: 43942
'05 White/Gold STi
Bump...I just picked myself up a set of the '04 jdm sti hid headlights. What would I need to do to fit these on my '04 wrx?
SupraToWRX is offline   Reply With Quote
Old 04-10-2005, 01:13 PM   #3
SloSubie
Member#: 63411
2004 Impreza WRX
its the same housing, just pull the housing. Replace you bulbs, cut your low beam wires and splice them into the ballast power supply. Dont forget to remove the daytime runninglight module.
SloSubie is offline   Reply With Quote
Old 04-10-2005, 02:07 PM   #4
SupraToWRX
Member#: 43942
'05 White/Gold STi
Well I've got the whole headlight assembly coming (housing, ballasts, bulbs) and my drl's have been disabled from behind the glove box. So all I would need to do is cut the single power supply wire for the lowbeams and splice it into the ballast power supply? I don't need another ground or anything? Anyone have any pics?
Old 04-10-2005, 02:29 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You do need a different ground. The HIDs should NOT be connected to the existing low beam ground, but to a direct chassis ground. You can use the existing common power.
Old 04-10-2005, 04:18 PM   #6
SupraToWRX
Member#: 43942
'05 White/Gold STi
Sounds good. What guage wire should be used for the ground and can you recommend any good grounding locations?
Old 04-10-2005, 04:22 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You don't need to use very heavy wire, 12 gauge is fine as long as you keep the run as short as possible and make the connections solid. On the drivers side you can either go to the negative battery terminal or the existing chassis ground on the fender, passenger side the fender is best since it's right there.
Old 04-11-2005, 07:15 PM   #8
SupraToWRX
Member#: 43942
'05 White/Gold STi
Cool...does anyone have any pics or any experiences with this?
WTB: JDM STi Bugeye headlight (HID or not HID) LIQUIDSK8S Private 'Wanted' Classifieds 0 05-04-2010 12:53 PM
04 JDM STI key use on 06 STI ? MoMoZzz Vancouver Impreza Club Forum -- VIC 12 06-04-2009 01:08 PM
04 JDM STI key use on 06 STI ? MoMoZzz Electrical & Lighting 0 06-03-2009 08:43 PM
FS: JDM STi Projector Headlights (for WRX 02-03) gloom Canada Region Forum 0 02-08-2004 04:39 PM
Standard Headlight to JDM (Non-HID) Headlight wrx2sti Interior & Exterior Modification 5 11-27-2002 01:38 PM
