Old 02-13-2004, 01:50 AM   #1
jharl
Member#: 29379
99 Outback Wagon
Red
Default wiring help with piaa 510's
I have a set of piaa 510 driving lights and need help figuring out how to wire them. I'd like to have the lights wired similar to how the fogs are, so that they turn on and off with the headlights high beams and also have a switch to turn them off even when highbeams are activated.
I have an extra factory fog light switch that I want to use instead of the supplied piaa switch if possible. I have a wiring diagram of the foglight switch to help, but can't really understand how I'd hook up those 5 wires of the factory switch to the piaa harness. Also how will I get a switched positive from the high beams to the light switch, since subaru uses switched grounds? Am I going to have to just cut up the piaa harness and get a different relay to even make this possible? I hope someone can make sense of my questions. Thanks. This is going in a '99 outback.
Jason
jharl is offline   Reply With Quote
Old 02-13-2004, 10:35 AM   #2
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
i could see how to do it with the piaa switch the stock one may be a bit off....if you use the piaa one all you do is splice in the piaa switch wire into the high beam wire. if the switch is active, whenever you arm the high beams, the lights will come one. yet you can still use the switch to shut the 510's off...
ATX25RS is offline   Reply With Quote
Old 02-13-2004, 08:41 PM   #3
jharl
Member#: 29379
99 Outback Wagon
Red
I thought the way the headlights were wired was one constant positive, and then 2 wires that were each a switched ground for high beam and low beam, or am I wrong? Maybe I'll just tap into that wire and just do a test run and see if it works.
Old 02-14-2004, 10:45 PM   #4
jharl
Member#: 29379
99 Outback Wagon
Red
Never mind, I figured out how to wire it up using a factory switch, if anyone needs help doing the same thing let me know.
Jason
A/C wiring help, WRX harness with Legacy A/C compressor wiring help mutiger93gt Legacy Forum 3 03-01-2010 05:34 PM
Need wiring help with '05 Outback/Legacy smosh Car Audio, Video & Security 0 04-23-2005 09:34 AM
Help with Amp Wiring HELP FAST Black_Rain Tri-State Area Forum 4 09-28-2003 08:30 PM
A little help? - Make PIAAs come on with high beams? darmom Bay Area Impreza Club Forum -- BAIC 1 01-08-2003 05:20 AM
Need some wiring help with STi headlights Obscure411 Interior & Exterior Modification 15 03-14-2002 10:55 AM
