Notices
Old 02-13-2004, 09:26 AM   #1
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
Default Aps Dr-55 409 Whp!
Didn't see that it was posted yet so check it out!
http://www.mzmperformance.com/cars/austinsubaru.phtml
bikerboy is offline   Reply With Quote
Old 02-13-2004, 10:57 AM   #2
robvas
Member#: 17466
Any pump #'s?
That extra .5 liters makes some good numbers!
robvas is offline   Reply With Quote
Old 02-13-2004, 11:34 AM   #3
zimm
Member#: 44427
Some quick math shows over $8,000 plus tuning fees...ouch! A $4k turbo? Out of my price range.
zimm is offline   Reply With Quote
Old 02-13-2004, 12:03 PM   #4
wrex03
Member#: 29963
04 sti
That's some pretty good spool up as well.
wrex03 is offline   Reply With Quote
Old 02-13-2004, 12:03 PM   #5
asianboy101
Visiting NASIOC Timeout
Member#: 46373
2004 subaru sti
blue
with all that mods. are you going to be hitting the gas station alot more now? also does tuning stop the boost creep if we keep the original turbo? also is it possible to tune an sti and leave the fuel the way it is and tune everything else?
asianboy101 is offline   Reply With Quote
Old 02-13-2004, 12:11 PM   #6
davidm_sh
Member#: 5994
2004 Impreza WRX STi
Java Black
The only thing that concerns me is that the dyno plot of the DR55 on APS website doesn't see full torque 4700rpm about 700rpm later than this latest dyno result. Plus the torque plots just don't line up AT ALL under 4000rpms comparing APS to MZM. I mean APS is MUCH lower reading at lower rpms and they are converting to flywheel hp even (assuming) compared to MZMs higher whp readings in the lower rpms.
I assume maybe APS is dynoing in 4th gear versus MZM using 5th or possibly aps in 3rd vs MZM 4th?
Just makes me wonder what lag is really like is all.
EDIT: Dyno charts -
davidm_sh is offline   Reply With Quote
Old 02-13-2004, 12:21 PM   #7
Adam P
Member#: 49436
Also, notice the race gas aspect. I can imagine that without the race gas the car would put out about 50 hp less to the wheels or so. What would you guys estimate the race gas angle is worth in terms of hp?
Adam
Adam P is offline   Reply With Quote
Old 02-13-2004, 12:40 PM   #8
wgknestrick
Member#: 32576
04 STI
10-12% of total HP with race gas of around 100oct.
wgknestrick is offline   Reply With Quote
Old 02-13-2004, 12:51 PM   #9
metoo
Member#: 4764
2004 STi sold :(
forizzle
Adam
I was just going to say that.
I've seen huge jumps in early-on torque from using race gas. On top of that is different tuning philosophies. MZM uses E-manage fuel computer and EBC. APS uses a Unichip looking thing (they say it's different than a Unichip) and boost module.
metoo is offline   Reply With Quote
Old 02-13-2004, 01:27 PM   #10
AustinTexas
Member#: 15971
2000 Scooby
STi
race gas allows an increase in timing, which in turbo decreases spool up time.
AustinTexas is offline   Reply With Quote
Old 02-13-2004, 01:36 PM   #11
Subie2
Member#: 14750
2007 Element SC
Root Beer Metallic
whats with the tumbler deletes tho? I thought the STi didnt have any to begin with.
Subie2 is offline   Reply With Quote
Old 02-13-2004, 01:43 PM   #12
AustinTexas
Member#: 15971
2000 Scooby
STi
Yes the USDM 2.5 liter STi motor has tumblers, but the JDM 2.0 STi does not.
Old 02-13-2004, 04:07 PM   #13
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
hehe do i smell an rt55 in the works for matt?
DISCOPOPE is offline   Reply With Quote
Old 02-13-2004, 04:26 PM   #14
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Just to confirmt he APS chart looks like Shootout mode HP and is crank HP(in the corner it says S_HP) Dyno dynamics bolts the engine in an engine dyno, Dyno tests it, and tests that same engine in the car. They did this for the Subaru so they would have Shootout mode. Its a popular car... Not many cars are listed but the main AWD turbo cars are.
Clark
AZScoobie is offline   Reply With Quote
Old 02-13-2004, 04:52 PM   #15
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
Would the STi really weigh 3400lbs? If it isnt would that lower the power rating?
~v6
V6TurboTA is offline   Reply With Quote
Old 02-14-2004, 02:18 AM   #16
broadfield
Member#: 13847
1992 240sx White
Old: 2004 Sti White
I weighed myself in my STi with a 1/8 tank of gas in it was 3205 lbs.
broadfield is offline   Reply With Quote
Old 02-14-2004, 09:43 AM   #17
davidm_sh
Member#: 5994
Java Black
Just for a data point on weight when I ran my [email protected] @6000ft above sea level in stock form the car with half tank of gas, full interior (spare, jack, etc + stereo) + me (190lbs) = 3510lbs on the scale.
Old 02-14-2004, 11:20 AM   #18
particleeffect
Member#: 41524
04 sti - no radio
plat silver
"Yes the USDM 2.5 liter STi motor has tumblers, but the JDM 2.0 STi does not."
What's a tumbler?
particleeffect is offline   Reply With Quote
Old 02-14-2004, 07:59 PM   #19
wistful
Member#: 745
2004 STi
Java Black Pearl
TGV tumblers. for emissions.
Don
wistful is offline   Reply With Quote
Old 02-14-2004, 09:33 PM   #20
pegdrgr
Member#: 25693
2008 18x9" goodness
E85-380ftlbs @ 3100
What's a tumbler?
A device to generate turbulence in the intake to help atomization of fuel when the manafold is cold. Unfortunately once the car is warm they are no longer needed, but they still to inhibit flow under high CFM flow.
pegdrgr is offline   Reply With Quote
Old 02-15-2004, 06:33 PM   #21
zacek
Member#: 19467
04 WRX STi
WR Blue - original owner
I suspect APS ran the DR55 with 93 octane gas. not race gas hence the dramatic difference.
zacek is offline   Reply With Quote
Old 02-15-2004, 09:31 PM   #22
cdraayer
Member#: 41843
04 STi - 390whp
There was no change in timimg, the race gas was just insurance against a lean condition.
cdraayer is offline   Reply With Quote
Old 02-18-2004, 08:00 PM   #23
Leo
Member#: 52226
99 Honda Civic SI
Milano Red
oy yeah keep those horsies comming. Great Job
Leo is offline   Reply With Quote
fs/ft: aps dr 725 fmic, APS 3" turbo back exhaust fdrx7 SCIC Private Classifieds 46 01-20-2010 04:54 PM
APS DR series 3.5" tbe, APS cai w/ K&N filter!!! blu_scooby Engine/Power/Exhaust 2 05-23-2009 04:48 PM
WTB: APS DR 525 or DR 725 FMIC leonbmx Private 'Wanted' Classifieds 6 09-02-2007 12:40 PM
need info on APS Dr series 3.5'' pip exhaust omega Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-13-2003 02:51 AM
APS DR 500 FMIC Pics fatcatwrx Member's Car Gallery 13 03-15-2003 03:53 AM
