Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 02-13-2004, 10:46 AM   #1
DirtDevil
Member#: 4041
2015 STI Keyless/NAV
Crystal White Pearl
Default HKS Turbo Timer in an 04 with Security.
Hello alll, need a little help wiring my HKS Type1 TT up to a 04 with the security option. I hooked it all up last night according to swank monkeys layout, and when I turn the car off it stays on for like half a second and then shuts off imediately. The pink wire on the 04 is a mystery to me as the only one I found was on a wiring harness in the middle console attatched to the security box in there. was this the correct wire? also I did not wire the acc up to the black box above the fuse box. Is this a must? I have taken it all out for now until I can get a good document for the 04 specifically, thank for anyones help.
DirtDevil is offline   Reply With Quote
Old 02-13-2004, 10:51 AM   #2
netZ
Member#: 5743
2007 Kia Optima
gold brick
Default Re: HKS Turbo Timer in an 04 with Security.
dark green/black on keyless entry module pin6
grey on security module pin2
ebrake wire is light green off ebrake
netZ
Originally posted by DirtDevil
Hello alll, need a little help wiring my HKS Type1 TT up to a 04 with the security option. I hookd it all up last night according to swank monkeys layout, and when I turn the car off it stays on for like half a second and then shuts off imediately. the pink wire on the 04 is a mystery to me as the only one I found was on a wiring harness in the middle console attatched to the security box in there. was this the correct wire? also I did not wire the acc up to the black box above the fuse box. Is this a must? I have taken it all out for now until I can get a good document for the 04 specifically, thank for anyones help.
netZ is offline   Reply With Quote
Old 02-13-2004, 03:12 PM   #3
DirtDevil
Member#: 4041
Crystal White Pearl
OK Thanks NetZ. Do these wires just need tapped or do they need to be cut and spliced into the HKS harness?
Old 02-13-2004, 04:01 PM   #4
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Please use the
There is a very informative thread on this same page! Same thread as the BLITZ tt
Leonardo is offline   Reply With Quote
Old 02-13-2004, 08:55 PM   #5
netZ
Member#: 5743
2007 Kia Optima
gold brick
the ebrake wire only needs to be tapped. the other 2 needs to be cut and taped away.
netZ
fs: 04 tail light, hks turbo timer, hks intake, hks bov, greddy fmic fdrx7 SCIC Private Classifieds 36 12-03-2008 03:00 PM
FS: HKS Turbo timer in factory clock pod mogrl840 Interior/Dressup/Audio & Security 3 12-01-2008 04:08 PM
Will the HKS wire harness work with the Apexi turbo timer for the 04 Wagon? othon Electrical & Lighting 6 02-12-2004 01:32 AM
Anyone is using an Apexi turbo timer in their STi? Does it work with the stock alarm? JDM addict Electrical & Lighting 6 09-17-2003 02:48 PM
HKS turbo timer vs. Viper security system syndicate rex Car Audio, Video & Security 1 06-24-2002 03:42 PM
