#1 |
RIP 1/19/64 - 7/23/11
Scooby Guru Member#: 24654
NESIC
Vehicle:1957 Taggart Comet atlasshruggedpart1.com |
The following was posted in the oil filter sticky thread:
"A subaru mechanic told me the new filter has a check valve inside that keeps the oil from draining from the turbo cooling lines and engine internals after the car is shut off." Despite repeated requests for confirmation of this, none have been forthcoming. Anybody?
#2 |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
The AA060 and the AA080 both have check valves in them. The only difference in the AA080 is that it is smaller to keep it away from the crossover pipe's heat. Either filter will work. Neither will keep oil in the turbo, oil lines, and engine internals- it will drain back into the pan, like it's supposed to, for the most part. That's not what the check valve is there for.
Brian |
#3 |
NESIC
So what does the check valve do? Do aftermarket filters like PurOne have it?
#4 |
Miss You Mom
NESIC
#5 |
Member#: 37135
Vehicle:1999 Crown Vic White |
Hmmm, I always thought that check valves were there to permit oil to bypass the filter in the event that the filter becomes clogged. Without that bypass feature, a clogged filter would stop oil from flowing through the engine...
Or, so I thought... Mike 02 WRX Wagon |
#6 | |
Member#: 993
#7 |
Member#: 51978
Vehicle:1996 Legacy Outback Red |
Question....does that check valve even matter if the filter is positioned vertically, like in many of the Subies?
#8 |
NESIC
I don't see how the orientation of the filter would matter.
#9 | |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
Since someone has brought up Subaru oil filters again, I noticed a little blurb on p. 3 of this SOA article:
#10 | |
Member#: 51978
Oh well.... |
#11 | |
Member#: 52
Vehicle:2005 Legacy GT 98 BMW 540i LS2/T56 |
Because the H6 has a higher volume oil pump so the filter with more survafe area may cause a drop in the oil pressure, or cause the pressure overide valve to open (it could act as if the filter was blocked) and cause the oil to bypass the filter completely. It is much more of a theoretical than a practical concern. If the filter is changed according to the specs, it unlikekly to cause any problem, jsut as it is iunlikely to make any difference what type of filter is used if it is changed when it should be. |
| Thread Tools | |
| Display Modes | |
| FS(socal) 2 OEM oil filters+ 2 washer rings and 1 Fram oil filter | fusionchicken | Engine/Power/Exhaust | 0 | 08-21-2009 05:26 PM |
| 3 new OEM oil filters for sale in Charlotte, NC | dakwrx | South East Region Private Classifieds | 1 | 07-19-2008 12:19 PM |
| FS: New OEM Oil Filter/Gasket for 00/01 Impreza - $8 | Matt_Chan | VIC Private Classifieds | 1 | 12-11-2007 10:49 PM |
| OEM Oil Filters, OEM Turbo oil filters, fuel filters, spark plugs, air filters | LangstonSubaru | Vendor 'For Sale' Classifieds | 125 | 03-29-2004 08:25 AM |
| Is it okay to use non-OEM oil filters? | Benchow | Newbies & FAQs | 4 | 08-09-2003 12:05 PM |
