Old 02-13-2004, 01:26 PM   #1
1DOWNCLOWN
Member#: 50287
02 WRX
Default 02 Sensor Help Please!!
I installed a A/F guage today and i had to add a little wire to the 02sensor.. my question is... will it effect anything if i used a piece of wire that is about 2 inchs long and thincker then the factory wire.. its a small add on but i need to know if that wire will be ok or do i need to change it to a factory size wire... thanks
1DOWNCLOWN is offline   Reply With Quote
Old 02-13-2004, 01:47 PM   #2
pistoffjstr
Member#: 29283
2003 Subaru Forester
Red
did the same thing with mine you should be fine
pistoffjstr is offline   Reply With Quote
Old 02-13-2004, 01:53 PM   #3
1DOWNCLOWN
Member#: 50287
02 WRX
its about 2 times the size of the factory wire.. are you sure it will be ok.... thanks for the info
Old 02-13-2004, 02:37 PM   #4
1DOWNCLOWN
Member#: 50287
02 WRX
anyone else????? please
Old 02-13-2004, 02:48 PM   #5
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
same here
...wait you ran a wire straight to the 02 sensor? why didnt you run it to the ECU?
ATX25RS is offline   Reply With Quote
Old 02-13-2004, 02:55 PM   #6
1DOWNCLOWN
Member#: 50287
02 WRX
Its to the wire that conects to the ECU.. just outside of the ECU.. i just want to make sure that i wont have any problems do to the larger wire i had to splice in the wiring...
Old 02-13-2004, 02:57 PM   #7
1DOWNCLOWN
Member#: 50287
02 WRX
i didnt think you are suppose to hook anything to your ECU so i used the wire comming out of the ECU to the O2sensor.. was that wrong??? and picture this -------=====------ that is what i meen by adding in a larger wire, will that cause some type of problem????? like resistance problems or something
Old 02-13-2004, 05:41 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Your AF gauge is useless unles you installed a wideband o2 sensor to connect it to.
Old 02-14-2004, 04:55 PM   #9
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
You should be fine, I've seen much much worse and everything worked ok. As long as everything has a solid connection and doesn't fall out and short you won't have any issues.
Buster
http://subaru.awdcars.com
EvasionOfTruth is offline   Reply With Quote
crank/cam sensor HELP PLEASE 199subaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-15-2008 04:59 AM
EA82T code 11 crank angle sensor help please!!! iluvdrt Pre-2002 Factory Turbo Powertrain 4 11-02-2005 05:25 PM
02 sensor help please JikJak Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-23-2004 05:53 PM
02 sensor help please JikJak Vancouver Impreza Club Forum -- VIC 5 04-17-2004 06:26 PM
02 sensor question please help ac_gohan Normally Aspirated Powertrain 1 02-04-2001 08:59 PM
